There is no way currently to manually set the title of a state-badge. The attribute title is for tooltip.
My request is that an attribute for tooltip is added which is the true tooltip and the current attribute, title, that can be customized, blank or user-defined text to display the name of the entity being displayed.
Do you mean an element inside picture-elements card?
If yes - suggest to rename the topic since it is absolutely unclear currently.
State-badge is a standard element present in any card to show an icon.
Yes, I do mean the picture-element state-badge. I wasn’t aware there were different ones. I will update. I also wasn’t aware that the others were similar in attributes as the one in question.
“State-badge” is a name of an element in HA frontend used to show an icon in UI (like in Entities card).
Also, “state-badge” is a name of an element inside Picture elements card.
And a similar element which may be shown on a top of a view is called a “badge”.
Agree, could be confusing.
Ok so I believe I have updated the topic and specified it clearly enough and hopefully its noted that the ability to change these items’ title is impossible and limiting.
hey @heffneil ! Did you find a solution at the end ?
I’m looking for the same, I would like to remove the label ("Living’) on my state-badge on picture element :
The only way I found to make is disappear for now is to set the style color to transparent but it might also be useful to change the text at some point
Thanks @Ildar_Gabdullin for your reply but I’m sorry I don’t know what the ‘main card-mod thread’ is.
I do see a ‘card-mod’ tag that appears in lots of different categories but even when searching for ‘fantastic’ word in threads with card-mod tag I can’t find what you describe.
Also since you seem to use this copy/paste reply quite often maybe you could add a link to the post in your snippet.
