I haven’t seen any mention of this yet, so I thought I’d share:
I came across this Styling Wizard for Google Maps that I found very helpful for matching Frontend Themes when using the ‘Show Google Maps as a card’ camera
component. I created ‘Silver’ and ‘Dark’ Google Maps themes to match my light and dark colored LovelaceUI themes.
Basic Instructions:
- (prerequisite) Follow the Show Google Maps as a card documentation to obtain a Google Maps API Key and configure the
camera
component in Home Assistant. - Navigate to the Google Maps Styling Wizard website and click “CREATE A STYLE”.
- Choose a color option from the “Select theme” section in the left-hand toolbar, and (optionally) adjust other features using the “MORE OPTIONS” toolbar.
- Select “FINISH”, then “COPY URL” from the bottom of the popup window.
- Paste the copied URL into a text editor and replace the
YOUR_API_KEY
text with the API Key string you configured in the first step. - Replace the
¢er=-33.9,151.14999999999998
(numbers may vary) string with thedevice_tracker
markers
string(s) you configured in the first step (eg:&markers=color:blue%7Clabel:P%7C{{ states.device_tracker.demo_paulus.attributes.latitude }},{{ states.device_tracker.demo_paulus.attributes.longitude }}
). - Replace the
still_image_url
configured in the first step with this newly configured URL.
Notes:
- You’ll want to omit the entire
¢er=...
string (up until the next&
) that’s provided as an example in the HA ‘Show Google Maps as a card’ documentation if you want the map to automatically center on all GPS device trackers. - Any device trackers beginning with numbers should be enclosed in square brackets and single quotes (
) within the URL with the preceding dot (.
) omitted. eg:device_tracker['########']
, or&markers=color:blue%7Clabel:P%7C{{ states.device_tracker['demo_paulus'].attributes.latitude }}
