Customize alarm states
I have added the Verisure component to my HA configuration and it works ok.
But I wonder if I can customize the state text. Now it displays “armed away” when it is armed and “disarmed” when the alarm is turned off.
I want to display my own text. Could this be customized with some “friendly_name” setting?
As far as I know there are three states; armed_away (when you aren’t home), armed_home (when you are still home) and disarmed. You create different automations for armed_away and armed_home depending on what sensors you want to be part of the monitoring state.
You can’t do this in customize but you might be able to do it with a template.
Yeah, I guess that I can do the customized text as a template sensor, but if I only show the template sensor in HA, I loose the functionality to click on the alarm device and arm/disarm it from HA.
But, thanx for the answer.
:slight_smile:
You can use a template switch.
