Customize already existed template
Hello guys,I was trying to modify a template so I could edit the symbols at the end from a Reading
For example I want to change the reading people at the end of the line to → persons ,or for another template to change a temp reading from C to Celsius
Use Configuration > Customise, select the Enitity then see if you can change the ‘Units of measurement’ from ‘people’ to whatever you want.
I don’t have this integration installed so cannot check this for you.
