Hi everybody,
I am currently (mainly) using the Dark - Green
theme by Juanmtech. I have changed one line
# from
state-icon-active-color: "#FBD150"
# to
state-icon-active-color: "#FB5250"
What I am trying to achieve first:
Different colors for different states disregarding the theme colors (so those colors will stay the same after changing themes as well)
- any light object on = yellow
- any light object off = dark grey
- any window object open = red
- any window object closed = green
etc. etc.
My goal was to always display open doors / windows in that reddish color #FB5250
. While this works fine, I don’t particularly like all my entities with ON
state to be red.
Is it possible to customize colors somehow that will work with regular cards? I have seen a (or multiple??) custom cards that allow this (button-card
), but I would for now prefer to just do this in regular lovelace without a dedicated card for it¹.
In that short time I have been getting into home-assistant now, I have used customize.yaml
quite a bit, but mostly for friendly_name
s, custom icons, and entity_picture
s. I could not fine a way to do what I am trying to do, but I am sure that it is possible.
I don’t know much about css
, but I thought perhaps icon colors could be changed through this? For example (not real code, just to make my point) IF icon.light.on THEN color = #FFFFF, ELSE IF icon.light.off THEN color = #F00000
(by declaring icon.light.on/offs color values in a separate css file). Or is there something else I can do?
I am aware that this could look kinda strange with some themes because some colors won’t match with others. However, I don’t want/need to do this for every and any entity; just doors, windows, binary lights would be nice to set to “agreeable” colors (that should work with most themes I would use, anyway).
¹ even though I have implemented button-card, I also use monster-card
a lot; afaik I cannot combine those two. While monster-card allows me to create a card that will display all entities binary_sensor.*door*
, it will put all those entities in a regular card that I cannot edit color-wise with button-card
Thanks in advance for your ideas
