I am trying to customize the icon for the dimmable MQTT light I have configured. I have the customizer in my configuration.yaml file and have used the templates method in customize.yaml to successfully change icons based on states. However, I cannot get the color of my dimmable light icon to change color based on the brightness level in it’s state.
This is what I have for the light’s state:
"brightness": 50,
"friendly_name": "Master Bedroom",
"supported_features": 1,
"icon": "mdi:lightbulb",
My customize.yaml looks like this:
light.master_bedroom:
icon: mdi:lightbulb
templates:
rgb_color: >
if (brightness < 25) return 'rgb(255,255,255)';
I am just trying to get it to turn a specific color if the brightness is less than 25% as a test.
I have also tried:
icon: mdi:lightbulb
templates:
rgb_color: >
if (brightness < '25') return 'rgb(255,255,255)';
icon: mdi:lightbulb
templates:
icon_color: >
icon: mdi:lightbulb
templates:
icon_color: >
if (brightness === '25') return 'rgb(255,255,255)';
None of which has worked. I still get the stock gradient of a horrible looking brown all the way up to a bright yellow based on the brightness level of the light in my light card.
Does anyone have any ideas?
Thanks!
Tdw
February 13, 2019, 12:19am
2
try:
templates:
icon_color: if (brightness === '25') return 'rgb(255, 255, 255)'; else return 'rgb(x,
y, z)';
the correct usage for icon_color is:
templates:
icon_color: >
if (state > 1500) return 'rgb( 192, 39, 30 )';
if (state > 150) return 'rgb( 244, 101, 35 )';
if (state > 70) return 'rgb( 255, 194, 15 )';
if (state > 0) return 'rgb(251, 210, 41)';
return 'rgb(54, 95, 140)';
and in your setting you need the attributes.brightness, and an ‘else’ which you can set by simply using return after the semicolon:
templates:
icon_color: >
if (attributes.brightness === '25') return 'rgb(255,255,255)';
return 'rgb(1,2,3)';
Tried this:
icon: mdi:lightbulb
templates:
icon_color: >
if (attributes.brightness < 150) return 'rgb(255,255,255)';
and this with the single quote around the brightness value (turns out it’s 0-255).
icon: mdi:lightbulb
templates:
icon_color: >
if (attributes.brightness < '150') return 'rgb(255,255,255)';
No joy…Still the standard light card color that scales with brightness.
did you install custom-ui according to https://github.com/andrey-git/home-assistant-custom-ui/blob/master/docs/installing.md ?
btw, this is code for regular HA, not Lovelace. I don’t know if these can be customized at all.
Maybe you can check on another entity to see if the template is correct? The lights have their own way of coloring the icons.
I believe so. I have the customizer in the custom_components directory:
And I have the hosted customizer configured in my configuration.yaml:
I have custom entity pictures configured for my device trackers based on states and they are working just fine…
So I tried the following: (adding state before the attribute)
icon: mdi:lightbulb
templates:
icon_color: >
if (state.attributes.brightness < 150) return 'rgb(255,255,0)';
return 'rgb(255,0,255)';
And it seemed like it did something.
But still not the desired customized colors…Just a default yellow ‘on’ color.
Also, the brightness attribute is only available when the light is on.
"brightness": 255,
"templates": {
"icon_color": "if (state.attributes.brightness < 150) return 'rgb(255,255,0)'; return 'rgb(255,0,255)';\n"
If the light is off, the attribute is gone…So when the light is turned off home assistant crashes and the following shows up in my log:
ERROR (MainThread) [frontend.js.latest.201901211] https://raw.githubusercontent.com/andrey-git/home-assistant-custom-ui/master/state-card-custom-ui.html:27:15155 Uncaught TypeError: Cannot read property ‘brightness’ of undefined
So I might have to figure out if there is a way to conditionally format the icon. i.e. if the light is on and brightness is less than X make the icon color Y. If the light is off make the icon color Z.
add |int
, to trick it into when Off 0
Thanks! Where should I add the |int
in my code?
usually behind the ((state.attributes.brightness)|int < 150)
though I havent done this myself in this setting. You might have better chances adding a if state == ‘on’ to the template so if its not on, it will go to the else.
try:
if (state === 'on' && state.attributes.brightness < 150)
Okay, finally got the icon color changing.
customize.yaml:
icon: mdi:lightbulb
templates:
icon_color: >
if (state === 'on' && attributes.brightness < 51) return 'rgb(255,255,204)';
if (state === 'on' && attributes.brightness < 102) return 'rgb(255,255,153)';
if (state === 'on' && attributes.brightness < 153) return 'rgb(255,255,102)';
if (state === 'on' && attributes.brightness < 204) return 'rgb(255,255,51)';
if (state === 'on' && attributes.brightness < 255) return 'rgb(255,255,0)';
return 'rgb(128,128,128)';
The Lovelace light card still has the default color, but I don’t really like the light card anyways.
I’d much rather have a linear horizontal input slider, described in this post: Tutorial for new Custom State Card UI?
But it’s from quite a long time ago, and even still it’s not super clear what the step by step instructions would be to get there. Have a moment to point me in the right direction?
Thanks for all the help! This is awesome!
I am trying to get the custom state card working with no success:
custom_ui_state_card: custom_light
state_card_mode: single-line
slider_theme:
min: 10
max: 255
pin: true
off_when_min: false
report_when_not_changed: false
icon: mdi:lightbulb
templates:
icon_color: >
SeLLeRoNe
(Andrea Iannucci)
February 19, 2019, 3:18pm
14
For future references to the same question, check this out: https://github.com/thomasloven/lovelace-slider-entity-row
