> customize:
> # Add an entry for each entity that you want to overwrite.
> sensor.temperature_sensor_2_0:
> friendly_name: Room Sensor 1
> sensor.temperature_sensor_2_1:
> friendly_name: Room Sensor 2
17-03-13 21:44:23 ERROR (MainThread) [homeassistant.loader] Unable to find component customize
17-03-13 21:44:23 ERROR (MainThread) [homeassistant.setup] Setup failed for customize: Component not found.
homeassistant:
# Name of the location where Home Assistant is running
name: Hatfield Home Automation Server
# Location required to calculate the time the sun rises and sets
latitude: 51.608962
longitude: -0.550933
# Impacts weather/sunrise data (altitude above sea level in meters)
elevation: 30
# metric for Metric, imperial for Imperial
unit_system: metric
# Pick yours from here: http://en.wikipedia.org/wiki/List_of_tz_database_time_zones
time_zone: Europe/London
customize:
This is actually incorrect. Unless I missed a recent change, customize is a child of homeassistant.
Is it possible that you’ve got a tab instead of a space in there somewhere?
And be sure that sensor.temperature_sensor_2_0 and sensor.temperature_sensor_2_1 are the correct entity_ids for your devices (check the states dev tool).
