Running 0.95.4. When I change the default icon for a switch entity from mdi:flash to mdi:bullhorn using the “Customize” UI, the icon changes temporarily but, reverts back to the default icon. The customize UI now displays an error message,
“It seems that your configuration.yaml doesn’t properly include customize.yaml
Changes made here won’t affect your configuration. The following attributes are already set in customize.yaml”
The config/customize.yaml file now contains an entry for the customization I made via the UI.
switch.downstairs_siren:
icon: mdi:bullhorn
I go back to the customize UI and delete the icon change, click save, and the customize.yaml file entry is now cleared:
switch.downstairs_siren: {}
This happens to every entity I try to customize. I’ve tried adding the “customize:” integration into my configuration.yaml file but, that produces an INVALID CONFIG error. Currently, I have the default_config: integration loaded. I’ve also tried adding the !include customization.yaml parameter but to no avail.
Does anyone have any idea how to customize entity icons?
Putting homeassistant: at the top level of the configuration.yaml file makes all of the entities declared within the config unavailable (e.g. covers, cameras, manual alarm panel). My config is good according to the config validation UI. It starts like this:
The HA home, time zone, elevation, e.t.c are all configured using the new “Configuration and Server Control” UI so, they don’t appear in my config.yaml file. EVERY line after homeassistant: throws an error. For example, the config above throws the error:
extra keys not allowed @ data[‘tts’]
If I comment that line out then, the next line throws an error:
extra keys not allowed @ data[‘group’]
I continued to comment each line and got the same result until I got to customize: !include customize.yaml. This did not throw an error!
Unfortunately, everything after that did. Alarm Panel, e.t.c…
extra keys not allowed @ data[‘alarm_control_panel’]
You still don’t seem to be formatting it correctly so it’s hard to tell if there’s problem with your YAML or just incorrect formatting with your paste. But the problem seems to be that you have it in the wrong area completely. Like Tom said, it needs to be under homeassistant: area.
Change the first line to be these two lines, in this exact order.
The config above works. If you nest everything in the config.yaml file under the root homeassistant: parameter, nothing below it will work, EXCEPT customize integration. Everything after the customize integration MUST sit at the same level with the root homeassistant: parameter
