Not sure if I missed something during updates but I can’t see to keep my icons from changing to the old ones. I have customize.yaml in my Configuration.yaml but it states I don’t. Below is my config setup. I can attache the entire if that helps.
default_config: customize: !include customize.yaml
Your customise section needs to be under homeassistant, not default_config.
homeassistant: customize: !include customize.yaml
That makes sense. My configuration.yaml did not have the homeassistant tag in it when I stated so I will added and see how it goes.
