Customize Picture Entity Card
currently I don’t know where my mistake is. I’m trying to swap the picture in the Picture Entity Card. But no matter what I do, it will not be displayed to me. The pictures are located under the folder:
/ config / www
Home Assistant
What could i do wrong?
type: picture-entity
entity: switch.osram_smart_bugelsteckdose
image: http://homeassistant:8123/local/WZ_Licht_an.png
show_name: true
show_state: true
tap_action:
action: toggle
hold_action:
action: more-info
I’m stupid…the solution is… " If you’ve had to create the www/ folder for the first time, you’ll need to restart Home Assistant."
what you have will work, however all you really need is
image: "/local/WZ_Licht_an.png"
Also, next time, please take time to learn how to format code when posting to the forums. Thanks.
