Customize standard map
Try the custom card from my post above.
With the standard map not possible?
Cannot check it now, far from any normal life; from what I remember - only zones have icons on a stock map card.
Okay, thanks for your help. It’s a shame that the “normal” icons on the sensors don’t work.
Then I’ll take a closer look at the customize card. The sensors are already displayed dynamically, but actually only the icons are wrong
Do you use this one as custom card?
Yes, this great one.
Yes works fine so far also together with auto entities so include and exclude sensors, just cannot set a icon if the entity do not include it.
EDIT: ok you was fast
@Ildar_Gabdullin thanks for the support
Super fast, was done a few days ago)))
You may set your sensors’ icons via customization.
Yes I did that.
