Hi, I’m using HA on raspberry.
I create switch on gpio, and I want to customize it, but it seems to be not possible …
I add the several following lines
customize:
switch.door:
icon: mdi:door
switch.ir_camera_right:
icon: mdi:alarm-light-outline
switch.ir_camera_left:
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
# Configure camera
camera:
- platform: ffmpeg
input: udp://0.0.0.0:8554
# Configure GPIO
switch:
- platform: rpi_gpio
ports:
10: Door
11: IR Camera Left
12: IR Camera Right
But in HA, I have this message :
Logger: homeassistant.setup
Source: setup.py:153
First occurred: 16:31:21 (1 occurrences)
Last logged: 16:31:21
Setup failed for customize: Integration not found.
What is the problem ?
