Have you try to added to tuya app instead and then get info from it.
here my data if useful to anyone (abilityId=DP)
"category": "cl",
"custom_name": "",
"icon": "smart/icon/ay1548222363985udC7M/ff4105454880b6e4cd84d93b704a1c8a.png",
"is_online": true,
"name": "SWING Comunidad 2 - DASPI",
"product_id": "cc0pofoln5kvfmsu",
"product_name": "SWING Comunidad 2 - DASPI",
"sub": false,
"modelId": "e8cgbg",
"services": [
"actions": [],
"code": "",
"description": "",
"events": [],
"name": "默认服务",
"properties": [
"abilityId": 1,
"accessMode": "rw",
"code": "control",
"description": "【必选项】用于控制电机的开启、暂停、关闭。该DP点枚举值参数不允许修改,不允许增减。",
"extensions": {
"iconName": "icon-yunhang"
"name": "控制",
"typeSpec": {
"type": "enum",
"range": [
"OPEN",
"CLOSE",
"STOP",
"Lamp_ON",
"Lamp_OFF"
"abilityId": 7,
"accessMode": "ro",
"code": "work_state",
"description": "【必选项】用于显示电机的当前工作状态。该DP点枚举值参数不允许修改,不允许增减。如需要修改在APP面板中显示的内容,可以前往第四步的拓展中心,多语言管理修改代表值,新增的枚举值所代表的的内容也是在多语言中修改代表值。",
"name": "工作状态",
"typeSpec": {
"type": "enum",
"range": [
"Opening",
"Closing",
"Stopped",
"Full_Opened",
"Full_Closed",
"Open_Softstop",
"Close_Softstop"
"abilityId": 8,
"accessMode": "rw",
"code": "countdown",
"description": "设备倒计时,该DP点枚举值可增减,但不可修改枚举值名称,例如可以删除4,但是不能把4改为其他词,可以增加,仅支持增加数字,未选则不展示该功能。 如需要修改在APP面板中显示的代表名称,可以前往第四步的拓展中心,多语言管理修改代表值,新增的枚举值所代表的的内容也是在多语言中修改代表值。",
"extensions": {
"iconName": "icon-dp_bottle"
"name": "自动关灯",
"typeSpec": {
"type": "enum",
"range": [
"1",
"2",
"3",
"4",
"cancel"
"abilityId": 9,
"accessMode": "ro",
"code": "countdown_left",
"description": "倒计时剩余时间显示",
"name": "倒计时剩余时间",
"typeSpec": {
"type": "value",
"max": 86400,
"min": 0,
"scale": 0,
"step": 1,
"unit": "s"
"abilityId": 10,
"accessMode": "ro",
"code": "time_total",
"description": "用于APP面板中窗帘全程的时间,单位是MS,例如上报5000,就代表 5S,也就是APP面板中窗帘动态全程的时间。",
"extensions": {
"iconName": "icon-dp_time",
"attribute": "1024"
"name": "总运行次数",
"typeSpec": {
"type": "value",
"max": 500000000,
"min": 0,
"scale": 0,
"step": 1,
"unit": " cycles"
"abilityId": 12,
"accessMode": "ro",
"code": "fault",
"description": "【必选】设备上报故障值,该DP点枚举值可增减,但不可修改枚举值名称,例如可以删除motor_fault,可以增加其他值,未选则不展示该功能。 如需要修改在APP面板中显示的内容,可以前往第四步的拓展中心,多语言管理修改代表值,新增的枚举值所代表的的内容也是在多语言中修改代表值。",
"extensions": {
"scope": "fault"
"name": "故障告警",
"typeSpec": {
"type": "bitmap",
"label": [
"Motor_Fault",
"Overload",
"Photo_Beam",
"Low_Power"
"maxlen": 4
"abilityId": 13,
"accessMode": "ro",
"code": "battery_percentage",
"description": "",
"extensions": {
"iconName": "icon-dp_battery",
"attribute": "1152"
"name": "质保开始日期",
"typeSpec": {
"type": "value",
"max": 20991231,
"min": 20200101,
"scale": 0,
"step": 1,
"unit": ""
"abilityId": 101,
"accessMode": "ro",
"code": "Lamp_Status",
"description": "",
"name": "Lamp Status",
"typeSpec": {
"type": "enum",
"range": [
"Lamp_ON",
"Lamp_OFF"
"abilityId": 102,
"accessMode": "rw",
"code": "Close_by_Photo_Cell",
"description": "",
"name": "Close by Photo Cell",
"typeSpec": {
"type": "bool"
"abilityId": 103,
"accessMode": "rw",
"code": "Squeeze_in_Closing",
"description": "",
"name": "Squeeze in Closing",
"typeSpec": {
"type": "bool"
"abilityId": 104,
"accessMode": "rw",
"code": "Community",
"description": "",
"name": "Community Mode",
"typeSpec": {
"type": "bool"
"abilityId": 105,
"accessMode": "rw",
"code": "Squeeze_in_Opening",
"description": "",
"name": "Squeeze in Opening",
"typeSpec": {
"type": "bool"
"abilityId": 106,
"accessMode": "rw",
"code": "Lamp_Flashing",
"description": "",
"name": "Lamp Flashing",
"typeSpec": {
"type": "bool"
"abilityId": 107,
"accessMode": "rw",
"code": "Soft_Stop",
"description": "",
"name": "Soft Stop",
"typeSpec": {
"type": "bool"
"abilityId": 108,
"accessMode": "rw",
"code": "hydraulic_mode",
"description": "",
"name": "液压电机模式",
"typeSpec": {
"type": "bool"
"abilityId": 109,
"accessMode": "rw",
"code": "security_1",
"description": "",
"name": "开门红外开关",
"typeSpec": {
"type": "bool"
"abilityId": 110,
"accessMode": "rw",
"code": "Limit_Setting",
"description": "",
"name": "行程设定",
"typeSpec": {
"type": "enum",
"range": [
"Entry_Program",
"Exit_Program",
"Set_Motor1",
"Set_Motor2"
"abilityId": 111,
"accessMode": "rw",
"code": "security_2",
"description": "",
"name": "关门安全开关",
"typeSpec": {
"type": "bool"
"abilityId": 112,
"accessMode": "ro",
"code": "Limits_Learn_Mode",
"description": "",
"name": "Limits Learn Mode",
"typeSpec": {
"type": "enum",
"range": [
"Program_mode",
"MT1_open",
"MT1_softstop",
"MT1_uplimt",
"MT2_open",
"MT2_softstop",
"MT2_uplimit",
"MT1_close",
"MT1_downlimit",
"MT2_close",
"MT2_downlimit",
"Program_success",
"Program_error"
"abilityId": 113,
"accessMode": "rw",
"code": "power_adjustment",
"description": "",
"name": "功率调节",
"typeSpec": {
"type": "value",
"max": 100,
"min": 10,
"scale": 0,
"step": 10,
"unit": "%"
"abilityId": 114,
"accessMode": "rw",
"code": "softstop_Time",
"description": "",
"name": "Softstop Time",
"typeSpec": {
"type": "value",
"max": 15,
"min": 1,
"scale": 0,
"step": 1,
"unit": "seconds"
"abilityId": 115,
"accessMode": "rw",
"code": "obstructe_force",
"description": "",
"name": "Time Auto Close ",
"typeSpec": {
"type": "value",
"max": 100,
"min": 0,
"scale": 0,
"step": 10,
"unit": "%"
"abilityId": 116,
"accessMode": "rw",
"code": "safety_stop",
"description": "",
"name": "STOP",
"typeSpec": {
"type": "bool"
"abilityId": 117,
"accessMode": "rw",
"code": "output_power",
"description": "set output power as 12VDC or 24VDC",
"name": "外接设备电源电压",
"typeSpec": {
"type": "bool"
"abilityId": 118,
"accessMode": "ro",
"code": "Version_Identify",
"description": "",
"name": "Version Identify",
"typeSpec": {
"type": "enum",
"range": [
"ds191",
"ds291",
"ds291a",
"ds291b",
"ds291c"
"abilityId": 119,
"accessMode": "rw",
"code": "Admin_Mode",
"description": "",
"name": "Admin Mode",
"typeSpec": {
"type": "bool"
