did you try: if (state === 2)
can be confusing at times when to use quotes and when not…
I can’t seem to get the customUI to work.
I have the warning in the log file that the custom component for customizer has not been tested by Home Assistant so I know it is getting that from the Custom Components folder however when I try to do the following in my customize.yaml file nothing seems to happen:
sensor.kitchen_motion_sensor_burglar:
friendly_name: Kitchen Motion Sensor
templates:
_stateDisplay: "if (state === 8) return 'Detected'; else return 'None';"
icon: "if (state === 8) return 'mdi:run-fast'; else return 'mdi:walk';"
What might I be doing wrong?
I have this in my configuration.yaml file:
customizer:
custom_ui: local
Hi, I’m pretty new to Home Assistant an I can’t get most Custom-UI features running even that I followed the documentation. Maybe someone can point me to the right direction?
I try to get something like this here from the Custom-UI docs:
But the sliders (and the ‘show_last_changed’ I also try to display) are not showing up (the light is of type ‘MQTT Light’):
Any ideas what could go wrong or what else I can try?
About my system:
I have HA 0.87.1 running with the newest Custom-UI from Github.
Home Assistant is installed without hass.io image through virtualenv on a ubuntu host in case this is important.
Custom-UI has been installed the local / automatic way described here:
https://github.com/andrey-git/home-assistant-custom-ui/blob/master/docs/installing.md
The files in .homeassistant/www/custom_ui/ are in the right place and the folders and files are owned an readable by the homeassistant user.
I also doule-checked that by testing if I can reach the files through http://<myip>:8123/local/custom_ui/state-card-custom-ui.html
This is my entry in the configuration.yaml:
homeassistant:
# Name of the location where Home Assistant is running
# metric for Metric, imperial for Imperial
unit_system: metric
# Pick yours from here: http://en.wikipedia.org/wiki/List_of_tz_database_time_zones
time_zone: Europe/Berlin
# Customization file
customize: !include customize.yaml
frontend:
extra_html_url:
- /local/custom_ui/state-card-custom-ui.html
extra_html_url_es5:
- /local/custom_ui/state-card-custom-ui-es5.html
themes: !include themes.yaml
And here my customize.yaml:
light.bogenlampe:
custom_ui_state_card: state-card-custom-ui
state_card_mode: single-line
show_last_changed: true
templates:
entity_picture: if (state === 'on') return '/local/img/stand_on.png'; else return '/local/img/stand_off.png';
As you can see in the screenshot, the entity_picture feature works, the icon changes when I switch the light on and off.
So the customize entry itself seems to work and is loaded.
I also see the Custom-UI menu entry in the settings of Home Assistant and a log entry in java console in Chrome with the text ‘Loaded CustomUI 20190113’.
So I guess Custom-UI should also be loaded.
I’m new to Custom-UI too and I have similar configuration like @Thyraz and I also can’t make it work.
I can see the Custom-UI loaded in the HA Info, I don’t see any error in the log, but I can’t see any changes in the Lovelace UI.
When I go to Configuration > Customization I see this message:
The following attributes are customized from outside of customize.yaml
Possibly via a domain, a glob or a different include.
And I see the show_last_changed
checkbox enabled, so I believe that it should work.
My environment:
Hass.io version 0.87.1 installed from image to Raspberry Pi 1
Home Assistant version: 0.87.1
Lovelace mode: storage
Frontend JavaScript version: latest
Custom UIs: 20190113
configuration.yaml
homeassistant:
customize_glob: !include customize_glob.yaml
customizer:
custom_ui: hosted
frontend:
javascript_version: latest
extra_html_url:
- https://raw.githubusercontent.com/andrey-git/home-assistant-custom-ui/master/state-card-custom-ui.html
extra_html_url_es5:
- https://raw.githubusercontent.com/andrey-git/home-assistant-custom-ui/master/state-card-custom-ui-dbg.html
customize_glob.yaml
customize.yaml
light.workroom_led_light:
state_card_mode: break-slider
stretch_slider: true
@andrey is this project still active, please? I see your last reply here 6 months ago (August 2018).
Thanks!
I just found that the Lovelace can be switched from storage
mode to yaml
mode, so I did that and made a restart and nothing happened. Custom-UI changes are still not visible
its not that custom-ui doesn’t work per se, it’s HA, and Lovelace all the more, taking out customization support more and more unfortunately. You’ve found a few, there are more. You could check the regular HA interface it custom-ui is working properly.
Have a look:
HA 84.3 regular:
Ha 84.3 Lovelace:
HA 84.6 regular:
further upgrading takes out more options which aren’t yet in Lovelace… reason on this side not to upgrade yet…
the much used _stateDisplay customization has been taken out too, so no more
but this:
in regular HA that is, theming per entity isnt supported on Lovelace either:
Thanks for the info, so I’ll stick with the non-customized Lovelace for now and see what future will bring…
I wouldn’t say that Lovelace isn’t customizable, in fact I think it’s a lot more flexible and customizable. CustomUI doesn’t work with Lovelace, but there are probably hundreds of custom Lovelace cards that provide much of the same options and many more.
@andrey, it looks like a change in 0.90 affected your custom_ui config panel addition and it makes the entire config panel nearly unusable if custom_ui is enabled. I also just get a white screen when going into the Custom UI menu item, so it’s not usable either. Can you check it out when you have a chance?
https://github.com/andrey-git/home-assistant-custom-ui/issues/170#issuecomment-475479131
Just FYI - I forked your repo, commented out the line that adds the new entry in the config panel, rebuilt it, and nav is working for me now.
You arent adding enough useful information for anyone to help you.
What do you mean that you didnt succeed? Logs?
What information is needed? I followed the instructions from here: https://github.com/andrey-git/home-assistant-custom-ui, but something is missing me.
It would be helpful to us to help you if you answered the questions I posted above.
How do you know that you didn’t succeed?
Can you please post any logs that would be relevant to the issue you are having from the homeassistant.log file found in your config directory?
@finity Thanks a lot for your time.
I changed this:
extra_html_url:
extra_html_url_es5:
with this:
customizer:
custom_ui: local
… and it works.
I have no idea what that even means since those are two different (but related) things but I’m glad you got it working.
Works with any of the settings. I do not know why it did not work from the beginning.
Hello Every Body
I use Custon UI for change color of icon and icon and it work fine
But I try to use it for slider of a hue lamp and I don’t use it ?
Here is my code in customize.yaml
light.spot_1_2:
hide_control: false
show_last_changed: false
theme: happy
confirm_controls_show_lock: true
slider_theme:
min: 10
max: 255
pin: true
off_when_min: false
report_when_not_changed: false
IWhen i try to add the light with config UI for lovelace
witch code i need to use ?
I try
entities:
- confirm_controls_show_lock: true
entity: light.spot_1_2
hide_control: false
slider_theme:
max: 255
min: 10
off_when_min: false
pin: true
theme: happy
type: entities
doesn’t work
I try
type: entities
entities:
- entity: light.spot_1_2
but it doesn’t work too
Can you help me please
Hello! Unfortunately, Custom UI works very unstable in HA 0.102 (appropriate issue has been created on Github). So I wonder if this very useful component will be updated soon.
I want to be able to change the icon based on the state of an automation and an input bolean.
This works fine in my browser on my labtop and on my new iPhone. But on an old iPhone 5 I can not get it to work - neither in the IOS-app or in Safari. I have tried to clear the cashe.
Any sugestions on how to make this work?
