It disappeared after cleaning caches two-three times…
Will lovelace will be supported?
I’m not sure what is going on. I disabled Custom-UI as since going to Lovelace I didn’t have a need for it. Now I do and I can’t seem to get it going again. I uncommented the lines in my configuration.yaml file to enable it again, but it’s not enabling. I’ve updated to the latest with update.sh
, There are no errors, I just can’t work it out.
I remember in dev-info
it would say what version you had loaded. I don’t see that. I’ve enabled custom-ui with:
customizer:
custom_ui: local
I’ve also had this under frontend:
but can’t remember if I need them enabled or not. Looking at the docs, it says to use one or the other.
frontend:
extra_html_url:
# - /local/custom_ui/state-card-custom-ui.html
extra_html_url_es5:
# - /local/custom_ui/state-card-custom-ui-es5.html
You need to uncomment both of those lines.
After I enable custom_ui, some issues happened on HA system service. For instance:
Check 'configuration validation '
Endless loading. After I comment custom_ui related code, it works fine.
Restart Homeassistant from UI:
Failed with this error:
Error executing service <ServiceCall homeassistant.restart (c:16013f5ea06840f38138d7779f237bc0)> Traceback (most recent call last): File "/usr/src/app/homeassistant/core.py", line 1130, in _safe_execute await self._execute_service(handler, service_call) File "/usr/src/app/homeassistant/core.py", line 1143, in _execute_service await handler.func(service_call) File "/usr/src/app/homeassistant/components/__init__.py", line 129, in async_handle_core_service errors = await conf_util.async_check_ha_config_file(hass) File "/usr/src/app/homeassistant/config.py", line 800, in async_check_ha_config_file check_ha_config_file, hass) File "/usr/local/lib/python3.6/concurrent/futures/thread.py", line 56, in run result = self.fn(*self.args, **self.kwargs) File "/usr/src/app/homeassistant/scripts/check_config.py", line 335, in check_ha_config_file component = loader.get_component(hass, domain) File "/usr/src/app/homeassistant/loader.py", line 92, in get_component module = importlib.import_module(path) File "/usr/local/lib/python3.6/importlib/__init__.py", line 126, in import_module return _bootstrap._gcd_import(name[level:], package, level) File "<frozen importlib._bootstrap>", line 994, in _gcd_import File "<frozen importlib._bootstrap>", line 971, in _find_and_load File "<frozen importlib._bootstrap>", line 955, in _find_and_load_unlocked File "<frozen importlib._bootstrap>", line 665, in _load_unlocked File "<frozen importlib._bootstrap_external>", line 674, in exec_module File "<frozen importlib._bootstrap_external>", line 781, in get_code File "<frozen importlib._bootstrap_external>", line 741, in source_to_code
HA and custom_ui are the latest version.
customizer:
custom_ui: hosted
frontend:
javascript_version: latest
extra_html_url:
- https://raw.githubusercontent.com/andrey-git/home-assistant-custom-ui/master/state-card-custom-ui.html
extra_html_url_es5:
- https://raw.githubusercontent.com/andrey-git/home-assistant-custom-ui/master/state-card-custom-ui-dbg.html
Any clue?
issue with extra_badge not showing unit and showing ‘none’ instead, does anyone have a solution for this. Or is it just not available any longer above HA 0.84.3…
see issue filed:
latest 2 version custom-ui and HA 0.84.6:
ha 0.84.3:
Hi, I’m new on HA and CustomUI
I’m trying to customize the entity_picture on a smoke sensor. This sensor can have several values (0, 2, 3 and 255). By default the value is displaying in the circle but I would like to display an icon depending on this value.
So I’ve added in configuration.yaml:
customizer:
custom_ui: local
and in customize.yaml:
sensor.smoke_kitchen:
templates:
entity_picture: if (state === '2') return '/local/fire.png'; return '/local/shield.png';
but nothing happens.
if I only do this:
entity_picture: /local/shield.png
I can see the icon in the circle instead of the number but of course it does not change when the value changes.
Any idea to help?
Thanks!
did you try: if (state === 2)
can be confusing at times when to use quotes and when not…
I can’t seem to get the customUI to work.
I have the warning in the log file that the custom component for customizer has not been tested by Home Assistant so I know it is getting that from the Custom Components folder however when I try to do the following in my customize.yaml file nothing seems to happen:
sensor.kitchen_motion_sensor_burglar:
friendly_name: Kitchen Motion Sensor
templates:
_stateDisplay: "if (state === 8) return 'Detected'; else return 'None';"
icon: "if (state === 8) return 'mdi:run-fast'; else return 'mdi:walk';"
What might I be doing wrong?
I have this in my configuration.yaml file:
customizer:
custom_ui: local
Hi, I’m pretty new to Home Assistant an I can’t get most Custom-UI features running even that I followed the documentation. Maybe someone can point me to the right direction?
I try to get something like this here from the Custom-UI docs:
But the sliders (and the ‘show_last_changed’ I also try to display) are not showing up (the light is of type ‘MQTT Light’):
Any ideas what could go wrong or what else I can try?
About my system:
I have HA 0.87.1 running with the newest Custom-UI from Github.
Home Assistant is installed without hass.io image through virtualenv on a ubuntu host in case this is important.
Custom-UI has been installed the local / automatic way described here:
https://github.com/andrey-git/home-assistant-custom-ui/blob/master/docs/installing.md
The files in .homeassistant/www/custom_ui/ are in the right place and the folders and files are owned an readable by the homeassistant user.
I also doule-checked that by testing if I can reach the files through http://<myip>:8123/local/custom_ui/state-card-custom-ui.html
This is my entry in the configuration.yaml:
homeassistant:
# Name of the location where Home Assistant is running
# metric for Metric, imperial for Imperial
unit_system: metric
# Pick yours from here: http://en.wikipedia.org/wiki/List_of_tz_database_time_zones
time_zone: Europe/Berlin
# Customization file
customize: !include customize.yaml
frontend:
extra_html_url:
extra_html_url_es5:
themes: !include themes.yaml
And here my customize.yaml:
light.bogenlampe:
custom_ui_state_card: state-card-custom-ui
state_card_mode: single-line
show_last_changed: true
templates:
entity_picture: if (state === 'on') return '/local/img/stand_on.png'; else return '/local/img/stand_off.png';
As you can see in the screenshot, the entity_picture feature works, the icon changes when I switch the light on and off.
So the customize entry itself seems to work and is loaded.
I also see the Custom-UI menu entry in the settings of Home Assistant and a log entry in java console in Chrome with the text ‘Loaded CustomUI 20190113’.
So I guess Custom-UI should also be loaded.
I’m new to Custom-UI too and I have similar configuration like @Thyraz and I also can’t make it work.
I can see the Custom-UI loaded in the HA Info, I don’t see any error in the log, but I can’t see any changes in the Lovelace UI.
When I go to Configuration > Customization I see this message:
The following attributes are customized from outside of customize.yaml
Possibly via a domain, a glob or a different include.
And I see the show_last_changed
checkbox enabled, so I believe that it should work.
My environment:
Hass.io version 0.87.1 installed from image to Raspberry Pi 1
Home Assistant version: 0.87.1
Lovelace mode: storage
Frontend JavaScript version: latest
Custom UIs: 20190113
configuration.yaml
homeassistant:
customize_glob: !include customize_glob.yaml
customizer:
custom_ui: hosted
frontend:
extra_html_url:
extra_html_url_es5:
customize_glob.yaml
customize.yaml
light.workroom_led_light:
state_card_mode: break-slider
stretch_slider: true
@andrey is this project still active, please? I see your last reply here 6 months ago (August 2018).
Thanks!
I just found that the Lovelace can be switched from storage
mode to yaml
mode, so I did that and made a restart and nothing happened. Custom-UI changes are still not visible
its not that custom-ui doesn’t work per se, it’s HA, and Lovelace all the more, taking out customization support more and more unfortunately. You’ve found a few, there are more. You could check the regular HA interface it custom-ui is working properly.
Have a look:
HA 84.3 regular:
Ha 84.3 Lovelace:
HA 84.6 regular:
further upgrading takes out more options which aren’t yet in Lovelace… reason on this side not to upgrade yet…
the much used _stateDisplay customization has been taken out too, so no more
but this:
in regular HA that is, theming per entity isnt supported on Lovelace either:
Thanks for the info, so I’ll stick with the non-customized Lovelace for now and see what future will bring…
I wouldn’t say that Lovelace isn’t customizable, in fact I think it’s a lot more flexible and customizable. CustomUI doesn’t work with Lovelace, but there are probably hundreds of custom Lovelace cards that provide much of the same options and many more.
@andrey, it looks like a change in 0.90 affected your custom_ui config panel addition and it makes the entire config panel nearly unusable if custom_ui is enabled. I also just get a white screen when going into the Custom UI menu item, so it’s not usable either. Can you check it out when you have a chance?
https://github.com/andrey-git/home-assistant-custom-ui/issues/170#issuecomment-475479131
Just FYI - I forked your repo, commented out the line that adds the new entry in the config panel, rebuilt it, and nav is working for me now.
You arent adding enough useful information for anyone to help you.
What do you mean that you didnt succeed? Logs?
