I’ve been struggling with this for a very long time, and as I’m starting to be able to make it work, I thought I would give some information here. Hope this helps.
You’re welcome to add examples in reply.
Here I’ll show to hide/display elements in the front end, depending on some status. Of course, this can be applied to many other attributes (icon, color…), not only “hidden”.
For that, I used to make automations and use the “customizer.set_attribute” action. This works, but it needs 2 automations (one to display, one to hide) and it soon becomes hard to handle. You can also hide tracked devices with the option “hide if away” in the known_devices.yaml file, but this will have an impact on the history.
Example of an automation to hide the camera if zoneminder is off :
- alias: 'ZM Stops' trigger: platform: state entity_id: switch.zmmonitor to: 'off' action: - service: customizer.set_attribute data: entity_id: camera.ext_front attribute: hidden value: 'True'
This can be done with a customize template, but I had a hard time figuring out the syntax.
Let’s start with the easiest one, hide something depending on its very state. This is an example for a media player : hide it if it’s off. This is an extract from a customize.yaml :
media_player.yamaha_office: friendly_name: Yamaha Office templates: hidden: "return (state === 'off' );"
Note that you’ll need the “===” sign, the “;” at the end of the statement and to protect the string.
If the state isn’t a string and you want to use a numeric state for a comparison, then just use the sign and no cast is necessary.
Example that hides the number of events of a zoneminder camera that has less than 10 events :
sensor.stairs_events:
templates:
hidden: “return (state < 10);”
Last case, you want to change a value from an object, depending on another object state. For instance, show a “turn on” switch for the media player we’ve hidden previously. The switch is displayed only if the entity “media player” is off :
switch.media_office: templates: hidden: "return (entities['media_player.yamaha_office'].state === 'on'); "
Combined with the first example, you’ll see the whole media player when the amplifier is on, but only a switch to turn it on when it’s off.
BTW, I’m using the great Broadlink Ir Media Player by Vassilis that makes using IR codes really easy.
