Faecon
(Jo)
1
In the info about the sma converter (https://www.home-assistant.io/components/sensor.sma/) you can find this
“custom sensors can be defined by using the custom section of the configuration.”
Example:
custom:
yesterday_consumption:
key: 6400_00543A01
unit: kWh
factor: 1000
Do I have to put this in config.yaml ?
adamba
(Adam)
2
@Faecon Did you find the answer to this question?
firstof9
(firstof9)
3
Per the page you’d do it like this:
sensor sma:
- platform: sma
host: IP_ADDRESS_OF_DEVICE
password: YOUR_SMA_PASSWORD
sensors:
current_consumption: [total_consumption]
current_power:
total_yield:
custom:
key: 6400_00543A01
unit: kWh
factor: 1000
