Cybergeek N100 HAOS not getting Wifi & BT to work
Hi I installed HAOS on Intel N100 with
I get the following in **dmesg | grep iwlwifi**
[    1.194492] iwlwifi 0000:00:14.3: Detected crf-id 0x501, cnv-id 0x80400 wfpm id 0x80000030
[    1.194828] iwlwifi 0000:00:14.3: PCI dev 54f0/0244, rev=0x370, rfid=0x10c000
[    1.198047] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-hr-b0-83.ucode failed with error -2
[    1.198645] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-hr-b0-82.ucode failed with error -2
[    1.199279] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-hr-b0-81.ucode failed with error -2
[    1.199895] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-hr-b0-80.ucode failed with error -2
[    1.200548] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-hr-b0-79.ucode failed with error -2
[    1.201192] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-hr-b0-78.ucode failed with error -2
[    1.209758] iwlwifi 0000:00:14.3: api flags index 2 larger than supported by driver
[    1.210136] iwlwifi 0000:00:14.3: TLV_FW_FSEQ_VERSION: FSEQ Version: 0.0.2.36
[    1.210766] iwlwifi 0000:00:14.3: loaded firmware version 77.f92b5fed.0 so-a0-hr-b0-77.ucode op_mode iwlmvm
[    1.273765] iwlwifi 0000:00:14.3: Detected Intel(R) Wi-Fi 6 AX101, REV=0x370
[    1.281949] iwlwifi 0000:00:14.3: WRT: Invalid buffer destination
[    1.385829] iwlwifi 0000:00:14.3: WFPM_UMAC_PD_NOTIFICATION: 0x1f
[    1.385879] iwlwifi 0000:00:14.3: WFPM_LMAC2_PD_NOTIFICATION: 0x1f
[    1.385888] iwlwifi 0000:00:14.3: WFPM_AUTH_KEY_0: 0x90
[    1.385896] iwlwifi 0000:00:14.3: CNVI_SCU_SEQ_DATA_DW9: 0x10
[    1.385946] iwlwifi 0000:00:14.3: Detected RF HR1 B3, rfid=0x10c000
[    1.386019] iwlwifi 0000:00:14.3: RFIm is deactivated, reason = 4
[    1.426219] iwlwifi 0000:00:14.3: base HW address: 90:09:df:00:50:55
[    1.514472] iwlwifi 0000:00:14.3 wlp0s20f3: renamed from wlan0
[    2.746321] iwlwifi 0000:00:14.3: WRT: Invalid buffer destination
[    2.844127] iwlwifi 0000:00:14.3: WFPM_UMAC_PD_NOTIFICATION: 0x1f
[    2.844154] iwlwifi 0000:00:14.3: WFPM_LMAC2_PD_NOTIFICATION: 0x1f
[    2.844215] iwlwifi 0000:00:14.3: WFPM_AUTH_KEY_0: 0x90
[    2.844269] iwlwifi 0000:00:14.3: CNVI_SCU_SEQ_DATA_DW9: 0x10
[    2.846181] iwlwifi 0000:00:14.3: RFIm is deactivated, reason = 4
[    2.891935] iwlwifi 0000:00:14.3: Registered PHC clock: iwlwifi-PTP, with index: 1
[    6.577169] iwlwifi 0000:00:14.3: Microcode SW error detected. Restarting 0x0.
[    6.578739] iwlwifi 0000:00:14.3: Start IWL Error Log Dump:
[    6.579962] iwlwifi 0000:00:14.3: Transport status: 0x0000004B, valid: 6
[    6.581066] iwlwifi 0000:00:14.3: Loaded firmware version: 77.f92b5fed.0 so-a0-hr-b0-77.ucode
[    6.582080] iwlwifi 0000:00:14.3: 0x00000071 | NMI_INTERRUPT_UMAC_FATAL
[    6.583032] iwlwifi 0000:00:14.3: 0x00008210 | trm_hw_status0
[    6.583975] iwlwifi 0000:00:14.3: 0x00000000 | trm_hw_status1
[    6.584917] iwlwifi 0000:00:14.3: 0x004D930E | branchlink2
[    6.585859] iwlwifi 0000:00:14.3: 0x004CF3DA | interruptlink1
[    6.586799] iwlwifi 0000:00:14.3: 0x004CF3DA | interruptlink2
[    6.587712] iwlwifi 0000:00:14.3: 0x0000B7BA | data1
[    6.588596] iwlwifi 0000:00:14.3: 0x00000010 | data2
[    6.589478] iwlwifi 0000:00:14.3: 0x00000000 | data3
[    6.590356] iwlwifi 0000:00:14.3: 0x00016806 | beacon time
[    6.591206] iwlwifi 0000:00:14.3: 0xA4945839 | tsf low
[    6.592013] iwlwifi 0000:00:14.3: 0x0000000A | tsf hi
[    6.592754] iwlwifi 0000:00:14.3: 0x00000000 | time gp1
[    6.593472] iwlwifi 0000:00:14.3: 0x003A7177 | time gp2
[    6.594155] iwlwifi 0000:00:14.3: 0x00000001 | uCode revision type
Please help I need the BT and Wifi
running 6.6.44-haos BTW. Boot takes forever because it is waiting for the WIFI load to fail.
Any help appreciated
