I’m currently using an install of Hass OS on an old HP prebuilt. I have it currently connected via USB directly into the machine. Is there any way to configure it so that the Hass interface recognizes it? Want to have it shut down nicely in case of a power loss. I know there is the network UPS tools add-on but I don’t want to have to go over network and would rather just have it go through the USB cable.
I believe NUT should be able to help you accomplish your goal.
Ah I see that now. Did not know that it supported USB UPS’s as well. Thank you!
Welcome!
Search for posts regarding Cyberpower and NUT, newer versions may have solved, however there were some NUT parameters that need adjusting for Cyberpower at one time.
