Cycle thru brightness with one button based on current brightness value
Hello there,
I’d like to set up a Shelly Dimmer 2 with an Aquara (only supports single/double click) button to cycle thru brightness based on the current value of the brightness itself, but right now a bit lost with templates/multiple conditions/actions, I’d like to ask for help if possible. What I’d like to achive is (with only using double click as I’d like to leave single to on/off):
if the light is off, double click to turn on, brightness 255
if brightness is 1-42 lets say, set it to 80
when 43-80, set to 192
etc
Could you point me in the right direction? Thanks in advance
Balazs
- alias: increase brightness
    - your double-click trigger goes here
    - service: light.turn_on
      entity_id: light.your_light
        brightness: >
          {% if is_state('light.your_light', 'on') and state_attr('light.your_light', 'brightness') | int <=42 %}
            80
          {% elif is_state('light.your_light', 'on') and 43 <= state_attr('light.your_light', 'brightness') | int <=80 %}
            192
          {% else %}
            255
          {% endif %}
I think that should do it.
Greatly appreciate your solution, cycling now as I wanted (0->100%->66%->33%->66%->100% and so on). Thanks a lot!
Where to insert this? I’ve tried config, lights, scripts, but I get errors. Pretty new to templates.
it’s an automation. It goes in the automations.yaml file.
I used this and changed it a bit for a script:
It goes
off > 20 > 150 > 255 > off
alias: dimmer_control_self
sequence:
      entity_id: "{{ light }}"
      brightness: |
        {% if state_attr(light,'brightness') | float(10) <=19 %}
          20
        {% elif 20 <=state_attr(light, 'brightness') | float(10) <=149 %}
          150
        {% elif 150 <=state_attr(light, 'brightness') | float(10) <=254 %}
          255
        {% elif 255 <=state_attr(light, 'brightness') | float(10) %}
          0
        {% endif %}
Now I can use this for buttons or in lovelace or anywhere else. I add the light when I call the service:
- service: script.dimmer_control_self
    light: light.your_light
