Cyclic timer on Aubes Smart Switch Power meter
A cyclic timer without the use of automation, scripts, etc. in HA. Possible applications: aquarium aeration, plant illumination. The timer is set to the interval between switching on and off the relay.
Maybe it will be useful to someone. Maybe someone will suggest doing it differently.
substitutions:
  platform: bk72xx
  board: cb2s
  framework_version: recommended
  device_name_short: "pm"
  friendly_name: "PowerMeter"
  device_description: "Aubess PM Smart Switch"
  logger_level: WARN
  update_interval: 15s
packages:
  base: !include common/pm_global.yaml
  base_pm: !include common/uart_bl0942.yaml
binary_sensor:
  - platform: gpio
    pin:
      number: P23
      mode:
        input: true
        pullup: true
    filters:
      - delayed_on: 50ms
      - delayed_off: 50ms
    on_press:
      - switch.toggle: main_relay
      - logger.log:
          level: WARN
          format: "Button pressed"
  - platform: gpio
    pin:
      number: P24
      mode:
        input: true
        pullup: true
    filters:
      - delayed_on: 50ms
      - delayed_off: 50ms
    on_press:
      - logger.log:
          level: WARN
          format: "Switch toggle"
status_led:
  pin:
    number: P8
    inverted: true
switch:
  - platform: gpio
    pin: P26
    restore_mode: RESTORE_DEFAULT_OFF
    on_turn_off:
      - globals.set:
          value: 'false'
      - logger.log:
          level: WARN
          format: "Relay turned off"
    on_turn_on:
      - globals.set:
          value: 'true'
      - logger.log:
          level: WARN
          format: "Relay turned on"
    name: "${device_name_short} On/Off Timer"
    icon: "mdi:timer"
    entity_category: "config"
    restore_mode: RESTORE_DEFAULT_ON
    optimistic: true
    lambda: |-
      return id(timer_enabled);
    turn_on_action:
      - globals.set:
          value: 'true'
      - logger.log:
          level: WARN
          format: "Timer enabled"
    turn_off_action:
      - globals.set:
          value: 'false'
      - logger.log:
          level: WARN
          format: "Timer disabled"
      - lambda: |-
          id(cycle_start) = esphome::millis();
globals:
  - id: is_active
    type: bool
    restore_value: yes
    initial_value: 'true'
  - id: cycle_start
    type: unsigned long
    restore_value: no
    initial_value: '0'
  - id: timer_enabled
    type: bool
    restore_value: yes
  - id: on_duration
    type: unsigned long
    restore_value: yes
    initial_value: '7200000'  # 2h
  - id: off_duration
    type: unsigned long
    restore_value: yes
    initial_value: '3600000'  # 1h
number:
    name: "${device_name_short} ON Timer"
    unit_of_measurement: h
    mode: box
    min_value: 1
    max_value: 4
    step: 1
    optimistic: true
    restore_value: yes
    set_action:
      - lambda: |-
          id(on_duration) = static_cast<unsigned long>(x * 3600000UL);
    name: "${device_name_short} OFF Timer"
    mode: box
    min_value: 1
    max_value: 4
    step: 1
    optimistic: true
    restore_value: yes
    set_action:
      - lambda: |-
          id(off_duration) = static_cast<unsigned long>(x * 3600000UL);
interval:
  - interval: 30s
    then:
      - if:
          condition:
            lambda: |-
              if (!id(timer_enabled)) return false;
              const unsigned long now = esphome::millis();
              const unsigned long elapsed = now - id(cycle_start);
              return id(is_active) ?
                (elapsed >= id(on_duration)) :
                (elapsed >= id(off_duration));
          then:
            - if:
                condition:
                  lambda: return id(is_active);
                then:
                  - switch.turn_off: main_relay
                  - logger.log:
                      level: WARN
                      format: "Timer: Reley off"
                else:
                  - switch.turn_on: main_relay
                  - logger.log:
                      level: WARN
                      format: "Timer: Reley on"
            - globals.set:
                value: !lambda return esphome::millis();
text_sensor:
    name: "${device_name_short} _Status Timer"
    icon: "mdi:list-status"
    entity_category: ""
    lambda: |-
      using namespace esphome;
      static char buffer[35];
      if (!id(timer_enabled)) {
        return optional<std::string>("Timer Off");
      const unsigned long elapsed = esphome::millis() - id(cycle_start);
      const int hours = elapsed / 3600000;
      const int minutes = (elapsed % 3600000) / 60000;
      snprintf(buffer, sizeof(buffer), "%s: %dh %02dm",
        id(is_active) ? "ON" : "OFF",
        hours,
        minutes);
      return optional<std::string>(buffer);
