Hi everyone,
I’m trying to make an automation in Home Assistant to update a RaspberryMatic system variable, but it’s not working for me. The automation update the value every 30 s. When using
data: with a fix value instead of data_template: "{{states('sensor.batterie') | float}}"
the fix value is shown in RaspberryMatic Systemvariables.
With data_template there is no value change.
The automation is:
- id: '1692888290649'
alias: BatterieLadung An CCU
description: ''
- platform: time_pattern
seconds: '0'
seconds: '30'
condition: []
- service: homematicip_local.set_variable_value
data_template:
entry_id: 329ecc30c37f0123949c8451ca72bbf9
value: "{{states('sensor.batterie') | float}}"
mode: single
The system variable is defined as value from 0 to 100 in RaspberryMatic.
It looks like there is a problem with sensor.batterie, but in the entety card of the dashboard the value of sensor.batterie is shown.
The sensor.batterie value comes from NodeRed.
Do you have any ideas ?
Best,
Uwe
