Rooms and groups should now work correctly in the most recent update.
@nikshriv thanks for the integration this is great! I just built my HA machine and this integration was key as I have a few Cync smart plugs around the house.
Has anyone used this integration with the Bluetooth Cync bulbs? Does it work with the color changing bulbs as well?
I was ready excited to find this as I have quite a few Cync bulbs. Unfortunately, despite all of the bulbs being the wifi variety, when I login it to my Cync account I get an error saying itâs not supported because I donât have any Cync wifi devices.
I have 4 of the hard wired downlights and 6 of the Edison bulbs.
Any suggestions would be greatly appreciated.
I have one Cync Wifi Plug and that got the integration to work for all my bluetooth-only lights. You probably need to purchase a Cync Wifi Plug?
Iâve installed the Cync integration from the HACS and all of my devices and groups discovered and there were no issues with login to my Cync account or anything. I have 1 wifi plug and 5 bluetooth bulbs. Despite being able to see everything fine in by entities and dashboard cards, if I try to interact with the devices at all there is no response. Any idea what Iâm missing here? Iâm new to HA so I have to assume it is user error but I just canât get it goingâŚ
Iâm trying to understand Cync. Can the device work locally, or do they require an Internet connection?
The documentation isnât clear â do they all have Wi-Fi as an option? Do all bulbs support Bluetooth, and what is needed for Bluetooth mesh? Do the Wi-Fi world and BT interconnect?
A URL pointing to the technical information would be helpful. Thanks.
Cync communicates via cloud.
As for bulbs there are two blue tooth and direct connect which is essentially wifi. For the bulbs to work you do need something like a smart plug.
Overall I personally like the system, it works well though the app fails to connect and needs a retry.
Got it installed, seems to happily see the floodlights I got.
Is there an easy way to send the info needed to select a color or temp or brightness? I can meander through the built in light cardâŚbut I want to make something more custom for AppDaemon. Normally I can steal hints from the cardâŚbut not much info there.
Edit:
Partial solution GitHub - tjntomas/HADashboard-widgets: Widgets for HADashboard / Appdaemon
There is a light control there that does workâŚdoes not yet have color temp controlâŚso if you use RGB then the lights always show the RGBâŚsamething happens with the actual CYNC appâŚYou have to select a color temp to put the lights back to a âwhiteâ color.
I will attempt to add the color temp part to that widgetâŚbut not sure if I can figure it out.
Many Thanks!
my cync integration has recently stopped workingâŚI have removed all plugin data and reinstalled and still errors out when adding the light switches
hass log erros here â hass error cync integration - Pastebin.com
I cannot get this to work at all. I can save the repository but that does not give me a prompt to install it as an add-on or integration.
it wont be an addon, it should show up as integration. i just put the cync_lights folder inside the custom_components folder and included this on the hacs.json
ânameâ: âCync Lights Custom Integrationâ,
âdomainsâ: [âlightâ],
ârender_readmeâ: true
I have the same issue, did something change on the Cync side that broke the login pop-up?
Iâm using the GE CYNC Smart LED Light Bulbs connected over WiFi. The hassio integration can control on/off and the warm/cool color temps fine. However, it doesnât reliably change the bulb color. Especially if Iâm controlling the lights from a group or a scene. The bulbs also donât typically respond well when I use the color picker.
Any way to fix this?
Everything works great but im wondering if you can add a option for dimmable LEDâs?
Just setup the integration and was able to add my two wifi smart plugs without issue, but I donât seem to be able to control them with HA. Both plugs are currently on but they appear as âoffâ in HA and donât respond to turning them on/off via the integrations. Not sure where to go from here as everything âappearsâ fine.
can this be used with cync bluetooth bulbs?
This integration is just great! worked with all my switches and bulbs, and I have different kinds. Except for one that I bought recently, one of those âDynamic Effectsâ
I canât even see it
Am i the only one who keeps having lights turn on at 1%? Does anybody know what to do about that?
I just installed and am attempting to add a Cync device. I am having problems with the login and 2FA process. I have verified user ID and password with the Cync website. Is there something that needs to be cleared in HA or on my system?
