D.A.R.S. — see what drones are flying nearby on a live map in HA (custom integration + card)
Hi all,
I’ve released a free, open-source (MIT) custom integration that brings drone Remote ID into Home Assistant. If you run one of our D.A.R.S. receivers, it plots every nearby drone the receiver picks up onto a live map, and lets you hang automations off detections.
Repo (HACS custom integration): GitHub - getdars/dars-homeassistant: Home Assistant integration + Lovelace map card for D.A.R.S. drone Remote ID receivers (BLE, local push). · GitHub
What it does
  • Live map of every detected drone — markers with heading, track, and the take-off/operator point (Lovelace card is bundled, no separate install)
  • Entities: active-drone count with full per-drone attributes, nearest drone ID/RSSI, a “drone detected” binary sensor, connection status, plus per-drone device_trackers for the built-in map
  • Day-by-day flight replay in the card, reading HA’s own Recorder history (no extra storage)
  • Fire an automation the moment a drone shows up — notification, light, siren, TTS, whatever you’ve got wired
How it works
It’s a local_push integration. The HA host holds a long-lived BLE GATT connection to the receiver, subscribes to the notify characteristic, and decodes the ASTM F3411 / ASD-STAN Remote ID frames locally. No cloud, nothing leaves your network. It’s auto-discovered over Bluetooth, and works through an ESPHome Bluetooth proxy if the receiver isn’t near your HA box.
Install
HACS → Custom repositories → https://github.com/getdars/dars-homeassistant (category: Integration) → download → restart. It should auto-discover the receiver, and type: custom:dars-map-card works out of the box (the card auto-registers).
You’ll need
  • A D.A.R.S. receiver (disclosure: this is COTS with our firmware) running in its detection mode
  • A Bluetooth adapter on the HA host, or a Bluetooth proxy in range
  • Drones nearby that actually broadcast Remote ID :slightly_smiling_face:
Nice side effect: because it lives in Home Assistant, iPhone/iPad users can view it too through the HA companion app — which is handy, as there’s no native iOS version of our phone app.
It’s still early, so bug reports, feedback and PRs are very welcome — and I’d genuinely like to hear what people end up automating with it.
Cheers
Bought. Will test soon!
If you need help setting it up comment here or write directly to email. Thank you and enjoy :+1:
I have combined it with drone tower in Poland:
What is the best antenna setup?
I have put some proxy in the middle to use usb connection.
Best antenna location is as high as possible and if possible without obstructions near it (of course with antenna facing up :up_arrow:. Thanks for posting :+1:
Do you have possibility to provide any diagnostic data? If we receive anything or if background communication is not too strong to jam drone - operator communication that we should capture
