D-Link Switch: username and password?
I would like to use a D-Link Switch but I don’t understand to which username and password the documentation referes to.
straight from the documentation
username
(string)(Required)
The username for your plug.
Default value:
admin
password
(string)(Required)
The password for your plug.
Default value:
The default password is the PIN included on the configuration card.
I tried that and it didn’t work. But after investigating more now I see that the device appears in the modem network’s page with its fixed IP, but I can’t ping it (while I can ping other devices in the network).
It works properly with the mydlink app, so it’s properly connected to the local network and to the internet.
So I think this issue of being unreachable by a ping prevents it to be connected to the Home Assistant integration.
A device that doesn’t respond to a ping is most likely not there. It’s probably a different address.
