Hi, i have this python code to scan D0 smart meter.
But the Smartmeter pushes so much times, that there are so much informations coming in every seconds…
I want to make a “timeout” or something, so it just scans or accept data all 1 minute or something
Can anyone help me to implement that i just get info all 1 minute and not every second?
thats init.py
"""Support for D0 smart meters."""
import asyncio
from homeassistant.core import callback
import logging
import serial_asyncio
import re
import time
import voluptuous as vol
from homeassistant.const import CONF_HOST
from homeassistant.helpers import discovery
import homeassistant.helpers.config_validation as cv
_LOGGER = logging.getLogger(__name__)
DOMAIN = "smartmeter"
CONF_PORT = "port"
CONF_OBIS = "obis"
CONFIG_SCHEMA = vol.Schema(
DOMAIN: vol.Schema(
vol.Optional(CONF_PORT, default="/dev/ttyUSB0"): cv.string,
vol.Optional(CONF_OBIS, default=[]): vol.All(
cv.ensure_list, vol.Length(min=1), [cv.string]
extra=vol.ALLOW_EXTRA,
START_CHAR = b'/'
END_CHAR = b'!'
async def async_setup(hass, config):
"""Check connectivity and version of smartmeter."""
port = config[DOMAIN][CONF_PORT]
obis = config[DOMAIN][CONF_OBIS]
meter = Meter(hass, port, obis)
hass.data[DOMAIN] = meter
# Wait for smartmeter setup complete (initial values loaded)
if not await meter.setup():
_LOGGER.error("Could not find a meter device at %s", port)
return False
# Load components
hass.async_create_task(
discovery.async_load_platform(hass, "sensor", DOMAIN, {}, config)
return True
class Meter():
"""Representation of a smartmeter connection."""
def __init__(self, hass, port, list_of_sensors):
"""Initialize charging station connection."""
self._list_of_sensors = list_of_sensors
self._update_listeners = []
self._hass = hass
self._port = port
self._values = {}
self._units = {}
self.device_name = "smartmeter" # correct device name will be set in setup()
self.device_id = "smartmeter_" # correct device id will be set in setup()
self.regex_data_set = re.compile(r"^(.+)\((.*)\)")
self.regex_data_set_data = re.compile(r"^(.*)\*(.*)")
def get_list_of_sensors(self):
return self._list_of_sensors
async def setup(self, loop=None):
"""Initialize smartmeter object."""
# start serial connection
loop = asyncio.get_event_loop() if loop is None else loop
transport, protocol = await serial_asyncio.create_serial_connection(loop, D0Reader, self._port, baudrate=9600)
protocol.set_callback(self.hass_callback)
return True
def get_value(self, address):
value = self._values.get(address, None)
unit = self._units.get(address, None)
return value, unit
def hass_callback(self, data):
"""Handle component notification via callback."""
# Analyse and preprocess received data blob
for line in data.splitlines(True):
first_match = self.regex_data_set.search(line)
if first_match:
address = first_match.group(1)
second_match = self.regex_data_set_data.search(first_match.group(2))
if second_match:
self._values[address] = float(second_match.group(1))
self._units[address] = second_match.group(2)
_LOGGER.debug("extracted %s with value %s with unit %s", address, self._values[address], self._units[address])
# Inform entities about updated values
for listener in self._update_listeners:
listener()
_LOGGER.debug("Notifying %d listeners", len(self._update_listeners))
def add_update_listener(self, listener):
"""Add a listener for update notifications."""
self._update_listeners.append(listener)
# initial data is already loaded, thus update the component
listener()
class D0Reader(asyncio.Protocol):
def __init__(self) -> None:
super().__init__()
self._data = ""
def set_callback(self, callback):
self._callback = callback
def connection_made(self, transport):
self.transport = transport
_LOGGER.debug("port opened %s", transport)
def data_received(self, data):
# Reset buffer if new start byte received
if START_CHAR in data:
_LOGGER.debug("new start found")
self._data = ""
# Buffer content and fetch data
# TODO: change data type to bytearray and convert to string afterwards
self._data += data.decode("latin-1")
# Callback if ending byte found(complete message received)
if END_CHAR in data:
_LOGGER.debug("end found, run callback")
# _LOGGER.debug("data: %s", self._data)
# TODO: check CRC
self._callback(self._data)
def connection_lost(self, exc):
_LOGGER.debug("serial connection closed: %s", exc)
self.transport.loop.stop()
and thats the other file
"""Support for smartmeter sensors."""
import logging
from homeassistant.helpers.entity import Entity
from . import DOMAIN
async def async_setup_platform(hass, config, async_add_entities, discovery_info=None):
"""Set up the smart meter platform."""
if discovery_info is None:
return
smartmeter = hass.data[DOMAIN]
obis = smartmeter.get_list_of_sensors()
_LOGGER.debug("Setting up sensors: %s", repr(obis))
sensors = []
for sensor_obis in obis:
sensors.append(MeterSensor(smartmeter, sensor_obis, "Verbrauch", "mdi:flash"))
async_add_entities(sensors)
class MeterSensor(Entity):
"""The entity class for smart meter sensors."""
def __init__(self, smartmeter, obis, name, icon, device_class=None):
"""Initialize the smartmeter sensor."""
self._smartmeter = smartmeter
self._obis = obis
self._name = name
self._icon = icon
self._unit = None
self._device_class = device_class
self._state = None
self._attributes = {}
@property
def should_poll(self):
"""Deactivate polling. Data updated by smartmeter."""
return False
@property
def unique_id(self):
"""Return the unique ID of the binary sensor."""
return f"{self._smartmeter.device_id}_{self._obis}"
@property
def name(self):
"""Return the name of the device."""
names={
'1-0:1.8.0*255':'Consumption',
'1-0:2.8.0*255':'Generation'
name = names.get(self._obis,"unknown")
return f"{self._smartmeter.device_name} {name}"
@property
def device_class(self):
"""Return the class of this sensor."""
return self._device_class
@property
def icon(self):
"""Icon to use in the frontend, if any."""
return self._icon
@property
def state(self):
"""Return the state of the sensor."""
return self._state
@property
def unit_of_measurement(self):
"""Get the unit of measurement."""
return self._unit
@property
def device_state_attributes(self):
"""Return the state attributes of the binary sensor."""
return self._attributes
async def async_update(self):
"""Get latest cached states from the device."""
self._state, self._unit = self._smartmeter.get_value(self._obis)
def update_callback(self):
"""Schedule a state update."""
self.async_schedule_update_ha_state(True)
async def async_added_to_hass(self):
"""Add update callback after being added to hass."""
self._smartmeter.add_update_listener(self.update_callback)
Would be great if someone can tell me, where i can put like a timeout or that it just looks all 1 minute and not every second… thats to much data, so i cannot check the course anymore (loads to long)
