Hello guys,
I tried to use deep sleep on my D1 mini (runnind on battery) and the esp never wake up. I reduced interval to be sure measure is done.
I’m pretty sure I do somethign wrong, but I spend few hours and I didn’t find it.
My configuration :
esphome:
platform: ESP8266
board: d1_mini
wifi:
ssid: !secret wifi_ssid
fast_connect: True
manual_ip:
static_ip: XXX
gateway: 192.168.1.1
subnet: 255.255.255.0
# Enable logging
logger:
api:
reboot_timeout: 15min
encryption:
key: !secret api_key
deep_sleep:
run_duration: 30s
sleep_duration: 1min
ota:
password: !secret ota_password
# DS18B20 Temperature Sensor
dallas:
- pin: D5
update_interval: 5s
- platform: dallas
address: 0x85062017e066754
Some logs :
[18:00:22][C][deep_sleep:049]: Setting up Deep Sleep...
[18:00:22][C][deep_sleep:052]: Sleep Duration: 60000 ms
[18:00:22][C][deep_sleep:055]: Run Duration: 30000 ms
[18:00:23][D][dallas.sensor:143]: 'Temperature piscine': Got Temperature=24.2°C
[18:00:23][D][sensor:109]: 'Temperature piscine': Sending state 24.25000 °C with 1 decimals of accuracy
[18:00:28][D][dallas.sensor:143]: 'Temperature piscine': Got Temperature=24.2°C
[18:00:28][D][sensor:109]: 'Temperature piscine': Sending state 24.18750 °C with 1 decimals of accuracy
[18:00:33][D][dallas.sensor:143]: 'Temperature piscine': Got Temperature=24.2°C
[18:00:33][D][sensor:109]: 'Temperature piscine': Sending state 24.18750 °C with 1 decimals of accuracy
[18:00:38][D][dallas.sensor:143]: 'Temperature piscine': Got Temperature=24.1°C
[18:00:38][D][sensor:109]: 'Temperature piscine': Sending state 24.12500 °C with 1 decimals of accuracy
[18:00:43][D][dallas.sensor:143]: 'Temperature piscine': Got Temperature=24.1°C
[18:00:43][D][sensor:109]: 'Temperature piscine': Sending state 24.12500 °C with 1 decimals of accuracy
[18:00:48][D][dallas.sensor:143]: 'Temperature piscine': Got Temperature=24.1°C
[18:00:48][D][sensor:109]: 'Temperature piscine': Sending state 24.06250 °C with 1 decimals of accuracy
[18:00:51][I][deep_sleep:116]: Beginning Deep Sleep
[18:00:51][I][deep_sleep:118]: Sleeping for 60000000us
[18:00:52][W][wifi_esp8266:482]: Event: Disconnected ssid='Vxormrbi-dkXtQ7hhtc' bssid=[redacted] reason='Association Leave'
