D1 Mini I2C Multisensor - AM312 not working
Hi all
So I’m trying to make a multisensor, using the following:
  • Wemos D1 Mini
  • HTU21D (I2C Temperature and Humidity Sensor) (VCC to 3.3V, GND to GND, SDA to D2, SCL to D1)
  • BH1750 (I2C Light Sensor) (VCC to 3.3V, GND to GND, SDA to D2, SCL to D1)
  • AM312 PIR Sensor (VCC to 3.3V, GND to GND, Signal to D3)
Diagram as follows:
Unfortunately, while the I2C devices work happily like this, the AM312 doesn’t seem to detect motion correctly. I’ve checked all the wires are sound and everything seems to be good, and the I2C sensors update, but the AM312 always shows as motion detected, and never stops showing that in HomeAssistant.
Any ideas?
Thanks!
Rob
Snippet of relevant parts of my .yaml in case that’s useful:
esphome:
  platform: ESP8266
  board: d1_mini
wifi:
  ssid: SECRET
  password: SECRET PASSWORD
  ap:
    ssid: $hostname AP
captive_portal:
logger:
api:
ota:
web_server:
  port: 80
substitutions:
  hostname: 'Multisensor 1'
switch:
  - platform: restart
binary_sensor:
  - platform: status
  - platform: gpio
    pin: D3
    device_class: motion
  - platform: wifi_signal
    name: $hostname WiFi Signal
    update_interval: 60s
  - platform: uptime
  - platform: htu21d
    temperature:
      name: $hostname Temperature
      icon: "mdi:thermometer-lines"
    humidity:
      icon: "mdi:water-percent"
  - platform: bh1750
    name: $hostname Illuminance
    icon: "mdi:brightness-percent"
    address: 0x23
    measurement_time: 69
text_sensor:
  - platform: version
    name: $hostname ESPHome Version
  - platform: wifi_info
    ssid:
    ip_address:
      name: $hostname IP Address
i2c:
  sda: D2
  scl: D1
  frequency: 100kHz
  scan: True
Try using the USB/5VDC power pin instead of 3.3VDC for the AM312.
Try a different pin for the motion sensor. D3 == GPIO0 which is not recommended as input.
As Keith said, connect it to 5v. My configuration is very similar to yours (temp, pir, lux, wemos mini) only that the pir is connected to 5v instead of 3v
@exxamalte same problem on D4 == GPIO2.
@FredTheFrog & @mcarty I thought the GPIO pins on the ESP would only be 3.3V tolerant? (I’m assuming I’m wrong if you have this working!) - I’ll give this a shot.
Thanks to you all for responding :smiley:
Please have a look at the linked tutorial.
D5/D6/D7 are good.
D3/D4 are not.
And moving the signal wire to D5 solved it. I thought I shouldn’t use D5/D6/D7 because they were used for SPI… Thanks Exxamalte - if only I’d read the article properly to know which ones are good for general use!
If I get any erratic behaviours with it, I’ll try it on 5V. Thanks again all!
Second the solution to check the pins! My AM312 was constantly on till I moved it to D7 which is a “safe” pin to use. Although now it’s very twitchy with movement as it resets every 2 seconds, so I may swap to the other one!
