Jradio
June 17, 2023, 4:39am
1
I have a D1 mini that is working with a bme20 sensor and I’m hoping to add a DS18B20 as well. So I can see the air temp and my pool temp and use one board.
The code I’m using for the BME20 is
captive_portal:
i2c:
sda: GPIO4
scl: GPIO5
scan: true
- platform: bme280
temperature:
name: "BME280 Temperature"
pressure:
name: "BME280 Pressure"
humidity:
name: "BME280 Humidity"
address: 0x77
update_interval: 60s
I’m not sure how to correctly code in the DS18B20 and if that’s possible.
tom_l
June 17, 2023, 5:36am
2
captive_portal:
i2c:
sda: GPIO4
scl: GPIO5
scan: true
dallas:
- pin: GPIO14 # or 12 or 13
- platform: dallas
address: 0x1c0000031edd2a28 # change this
name: "Air Temperature"
unit_of_measurement: "°C"
device_class: "temperature"
state_class: "measurement"
- platform: bme280
temperature:
pressure:
humidity:
address: 0x77
How to find the sensor address: Dallas Temperature Sensor — ESPHome
Jradio
June 17, 2023, 12:46pm
3
Thank you. I’ll give that a try.
Jradio
June 24, 2023, 3:46am
4
That worked perfectly thanks again.
