Dudenell
(Daniel Carr)
1
Setup a D1 mini in ESP home, here’s my config file
esphome:
friendly_name: jukebox
esp8266:
board: d1_mini
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "xxxx="
ota:
password: "xxxx"
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Jukebox Fallback Hotspot"
password: "NEFSZhHj5P3B"
captive_portal:
spi:
clk_pin: GPIO14
mosi_pin: GPIO13
miso_pin: GPIO12
pn532_spi:
cs_pin: GPIO15
update_interval: 1s
D1 will start up and connect to wifi when not attached to the PN532.
PN532 shows power with the LED light.
D1 will connect to wifi when just the ground and 3.3 pins are connected to the pn532.
What am I missing here?
nickrout
(Nick Rout)
2
Plug it in to a usb cable so you can get serial logs, then post the logs.
Make sure that GPIO15 is not pulled high on boot - see
or perhaps don’t use GPIO15.
stevemann
(Stephen Mann (YAML-challenged))
3
I am not familiar with the PN532, but D8 (GPIO15) is pulled to GND and Boot fails if pulled HIGH.
D1 and D2 (GPIO5 and GPIO4) are safer to use as there are no similar restrictions.
Dudenell
(Daniel Carr)
4
Yeah it wouldn’t spit out any logs at all, just changed it to pin4 and it booted. However it doesn’t appear to be reading any tags…
Dudenell
(Daniel Carr)
5
Moved it to GPIO4 and it booted (and is on wifi now), however the pn532 isn’t responding to tags.
Dudenell
(Daniel Carr)
6
Figured it out, moved to GPIO4. The second step was enabling SPI protocol on PN532 by moving the DIP switch to 0 and 1 positions
