D1 Wemos Mini Pro with Battery Shield
Solar Powered ESP gate sensor from a D1 Wemos Mini Pro with a D1 Battery shield.
All code within ESPHome for my sensor works as expected except that the D1 Shield when charging gets hot. Sensor is powered off a small Solar Panel and Shield charges 2x 18650 batteries.
ESP sensor runs a reed switch and a temp sensor DHT11 so nothing major.
Anyone had experience with similar? Sensor last for 3 days even with deep sleep enabled?
You would need to share more insight details about hw configuration to better understand context :wink:
Specifications of the solar panel? 6V, 8V, 10V, 12V…? Maximum current? Specifications of your battery shield? Any pictures of wiring?
Does your deep sleep works? Logs? Yaml?
Anything?
