Hi i have a connection problem with my dht22 humidity sensor on my d1mini, i run esp flasher and said that cant get data im connecting the sensor on board temporary but i dont know why cant get data can you see if its right connected the pins?
[21:08:08][C][api:095]: API Server:
[21:08:08][C][api:096]: Address: room.local:6053
[21:08:32][W][dht:160]: Requesting data from DHT failed!
[21:08:32][W][dht:060]: Invalid readings! Please check your wiring (pull-up resistor, pin number).
[21:08:32][D][sensor:092]: 'Room Temperature': Sending state nan °C with 1 decimals of accuracy
[21:08:32][D][sensor:092]: 'Room Humidity': Sending state nan % with 0 decimals of accuracy
