Hoping someone may be able to assist. I have been using the daapd add-on for sometime now, however the add-on has stopped working for some reason. Clicking the add-on “open web ui” link gives me…
502: Bad Gateway
Looking through the logs I see the following fatal errors:
[2023-04-21 15:05:40] [FATAL] httpd: Websocket init failed
[2023-04-21 15:05:40] [FATAL] main: HTTPd thread failed to start
Also this is the general log:
Logger: homeassistant.config_entries
Source: components/forked_daapd/__init__.py:21
First occurred: 15:19:22 (1 occurrences)
Last logged: 15:19:22
Error unloading entry iTunes on homeassistant: for forked_daapd
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 539, in async_unload
result = await component.async_unload_entry(hass, self)
File "/usr/src/homeassistant/homeassistant/components/forked_daapd/__init__.py", line 21, in async_unload_entry
hass.data[DOMAIN][entry.entry_id][
KeyError: 'UPDATER'
Anyone using this or similar who could provide some insight into why its stopped working?
Any help appreciated. Thanks in advance.
