I’ve recently installed a new water pump which is connected to wifi and has its own app.
I was wondering if somebody already integrated this in homeassistant (I couldn’t immediately find information on the API or others who’ve found ways around).
I have the same pump installed this month. I’m using a smart ZigBee power plug to operate it as I couldn’t find any information on using the inbuilt WiFi with Home Assistant. Hopefully something will turn up.
I’m also looking for an solution.
As flow and consummed water would be interresting information to gather.
I asked to customer service if there was any MQTT or Home Assistant connexion.
If I do get a positive feedback, I will inform you.
For a moment I hoped that I could get the data from GoogleHome as there is a possible connexion, but no information are received.
Anko, am I able to integrate 2 esybox mini pumps. I have one integrated and working great but I need to install another pump. One for the tank and another for the mains water we have just had access to.
@Deedzy
Yes, you certainly can have multiple pumps in the Home Assistant Dab Pumps Integration. It involves 2 steps:
Add your new pump into your existing installation/account in DConnect/DAB Live.
I found the following video that shows how to add a pump in DAB Live How to install DAB Live!, relevant part is from from 1:44. Should be similar if you use DConnect. Or refer to the documentation of your pump.
Only once both pumps are visible in the DConnect or DAB Live app or website, continue to step 2
Force the integration to discover on the DAB backend servers that there are now 2 pumps in the installation
Do this by reloading the installation (Settings → Integrations → Dab Pumps → Reload). Or restart HA (Developer Tools → Yaml → Restart).
Or turn the HA device off and on again.
The HA integration should now have the 2 pumps and their sensors. Let me know if you see something unexpected happening, you might be the first person to add 2 same pumps.
I’ve moved into a house that has a DAB E.Sybox Mini 3 and wanted to get it integrated into HA, I’ve installed the integration and DAB Live but I cannot get the pump to pair with the DAB Live app, I hold down the up arrow button for 5 seconds (have tried longer) and go into scanning mode but it just never comes up. The pump software version is 1.8 so a bit old and not sure if that’s part of the problem.
Did anyone else struggle pick up their pump? Sorry know this is a little off top.
There seem to be a maintenance and platform upgrade (email received from dab):
We are about to perform a maintenance task on the DConnect platform on the following dates:
from 23 June to 27 June 2025
During this activity the Contracts section will not be available. If your subscription is expiring soon we suggest you to renew it soon, to ensure you continue to enjoy all the benefits of our service.
Also, we are thrilled to inform you that during this period we will perform an update of the platform, which will allow us to introduce many new features soon!
