Does anybody use preset to their xiaomi dafang camera? is there some mqtt should be called?
Meanwhile I figured out by using shell_command an their web like "
...action.cgi?cmd=motor_PTZ&x_axis=100&y_axis=2500
but maybe there’s a better way?
There are mqtt commands for left/right/up/down. I am not sure about absolute positioning.
Yes, i have it, it doesn’t help.
You can use the Cover position.
If your Xiaomi Dafang is intergrated with mqtt. That means that you have the 2 entities
cover.dafang_move_up_down
cover.dafang_move_right_left
For example :
alias: DaFang_RestPosition
sequence:
- data:
position: 0
entity_id: cover.dafang_move_left_right
service: cover.set_cover_position
- data:
position: 0
entity_id: cover.dafang_move_up_down
and for the Record Position
alias: DaFang_RecordPosition
sequence:
- data:
position: 50
- data:
position: 50
