Dahua cameras - switch between Day and Night video profiles
Rather than using the ‘sun’ integration with ‘sunrise’ and ‘sunset’ events, or trying to offset these events by some fixed amount, I use an ESPHome sensor built from a Wemos D1 Mini (ESP8266) and a BH1750 ambient light sensor. This sensor is located in a window on the south side of my home, which receives the best amount of sunlight on any given day, year-round. I’ve found the ideal switch-point for turning on outdoor lights and switching camera profiles to be around 30 to 50 lux. With this in mind, I defined one Shell script in HA’s configuration.yaml file, and two automations in HA’s automation.yaml file.
First, the ESPHome code that runs on the Wemos D1 Mini ambient light sensor:
esphome:
  platform: ESP8266
  board: d1_mini_pro
wifi:
  fast_connect: false
  domain: .local
  power_save_mode: NONE
  reboot_timeout: 5min
  networks:
  - password: supersecret
    ssid: SSID
  use_address: ambientlight.local
i2c:
  sda: D2
  scl: D1
  scan: True
  - platform: bh1750
    name: "BH1750 Luminance"
    address: 0x23
    update_interval: 15s
    accuracy_decimals: 0
logger:
  logs: {}
  level: DEBUG
api:
  port: 6053
ota:
  safe_mode: true
  port: 8266
Then, the configuration.yaml shell command:
# Shell commands
# BASH shell scripts executed by HA Automations
shell_command:
  dahua_profile_day:   '/home/admin/DahuaDayNight DAY'
  dahua_profile_night: '/home/admin/DahuaDayNight NIGHT'
Last, the two automation.yaml automations:
- id: '999999010'
  alias: Dahua Cameras to Night Profile
  description: Switch Dahua cameras to night time video profile
  - platform: numeric_state
    entity_id: sensor.bh1750_luminance
    below: '50'
    for: 0:03:00
  - service: shell_command.dahua_profile_night
  mode: single
- id: '999999020'
  alias: Dahua Cameras to Day Profile
  description: Switch Dahua cameras to day time video profile
    above: '40'
    for: 0:03:00
  - service: shell_command.dahua_profile_day
  mode: single
Finally, the Linux BASH script that runs on the Home Assistant Linux system:
#!/bin/bash
# Name:
# DahuaDayNight.bash
# Function:
# Switch to day (1) or night (2) profiles on Dahua Cameras
# Argument(s):
#    1    "day" or "night"
# Default MODE to zero - no actions
MODE=0
# Accepts "day", "Day", "DAY", "night", "Night", "NIGHT"
# Any other input performs no action.
# Convert input argument to UPPER case
arg=$( echo ${1:-null} | tr [:lower:] [:upper:] )
# Its DAY - use 1
if [ ${arg} = "DAY" ]
  then
     MODE=1
fi
# Its NIGHT - use 2
if [ ${arg} = "NIGHT" ]
  then
     MODE=2
fi
# Camera.dat - ASCII Text File, LF terminators, pipe-delimited
#    1     IP Address
#    2     Port Number
#    3     Manufacturer
#    4     Username
#    5     Password
#    6     Description
# Only if DAY or NIGHT was input, set
#  the desired mode on all Dahua cameras
if [ ${MODE} != 0 ]
  then
      grep Dahua cameras.dat | awk -F\| '{printf "%s %s %s %s \"%s\"\n", $1, $2, $4, $5, $6}' | while read IP PORT USERNAME P
ASSWORD DESCRIPTION
      do
          /usr/bin/curl -s -g --digest -u ${USERNAME}:${PASSWORD} http://${IP}:${PORT}/cgi-bin/configManager.cgi?action=setCo
nfig\&VideoInMode[0].TimeSection[0][0]=${MODE}
      done
fi
Here’s an example ‘cameras.dat’ file for your review:
# cameras.dat - Blue Iris camera config data
#    1     IP Address
#    2     Port Number
#    3     Manufacturer
#    4     Username
#    5     Password
#    6     Description
192.168.1.11|8011|Dahua|username|password|Back Door
192.168.1.12|8011|Dahua|username|password|Inside Garage
192.168.1.15|8011|Dahua|username|password|Driveway
192.168.1.17|8011|Amcrest|username|password|Bedroom
192.168.1.19|8011|Amcrest|username|password|Kitchen
Thanks for posting this.
On my to do list!
