I am using the SIP Card with an external freePBX and can receive calls using a VTO. I also setup the freePBX so that the ringback sound is customized based on the time of year, so that Christmas songs play during Christmas, Halloween sounds around Halloween, etc.
I am looking for a POE Doorbell like Dahua.i see Dahua - VTO2211G-WP.
I would like to have one android tablet for manage all home assistant and Dahua intercom.
1- do you know if i can use an android tablet to manage both? Dahua sell their own tablet connected to POE. My goal is to see who is ringing and talk them without my phone when i m house. I would like unlock the door.
2- Dahua tablet can use a web browser? To manage home assistant
3- do you know if i can read in home assistant a specific rc card for unlock my doorbell. It would be perfect if i can read my son’s card to unlock alarm.
Hi is there any recent changes in HA / Dahua VTO2202f-p that might cause this?
My simple automation that plays audio when doorbell
is pressed has stopped working and throw this error
Executed: December 4, 2022 at 10:10:00
Result:
result: false
entities:
value_template: ‘{{ trigger.event.data.Data.State | int in [1, 2] }}’
Nothing changes, should work as before. You can try to change media_player.play_media service to persistent_notification.create and check if you get right trigger.event.data.Data.State state:
- alias: Dahua Test
- platform: event
event_type: dahua_vto
event_data:
Code: BackKeyLight
condition:
- condition: template
value_template: "{{ trigger.event.data.Data.State | int in [1, 2] }}"
- service: persistent_notification.create
title: "Dahua Test, state {{ trigger.event.data.Data.State | int }}"
message: "{{ trigger.event.data }}"
Hello, result: false it’s not an error, VTO report different states and you are looking only for doorbell (1, 2). You can try to remove conditions and you will see all states you are get from VTO.
- alias: Dahua Test
- platform: event
event_data:
Code: BackKeyLight
# condition:
# - condition: template
# value_template: "{{ trigger.event.data.Data.State | int in [1, 2] }}"
Hmm so apparently my service persistent notification : create doesn’t seem to work,
I’ve filled it with example from UI and it doesn’t show anything.
Is there any other way to get value from VTO?
No, in logbook, But “template value should be a string for dictionary value @ data[‘message’]” indicated that you have problem with a syntax, try to check how this works in Services (with dummy values, without template) and when insert in into yaml.
Update : I reinstalled my whole system, this time is I run HA as proxmox VM and it’s working again.
Previously it was supervised
Will monitor it again but probably has something to do with supervised changing ip.
Guess VM is the more stable approach after all.
I don’t think so, because VTH doesn’t have DND on/off button and all periods should be configured in the VTH settings. You can try to emulate DND mode by calling Cancel VTO Call service immediately after you get event of door bell.
Does anyone know what the DOOR1_PUSH port is used for on the VTO2211? I have a sliding gate motor that I want to trigger to open/close/stop. Ideally I wouldn’t have to use any door sensor to do this as I don’t care whether its open or closed, I just want to activate it. I got it to open once by linking to the NO/COM ports, but it wouldn’t close when I sent the command again.
Edit this card, mushroom cards and put some buttons there. Would like to know how put the answering button to work with the service to answer the ring call.
type: custom:stack-in-card
mode: vertical
cards:
- type: custom:webrtc-camera
url: >-
rtsp://username:[email protected]:554/cam/realmonitor?channel=1&subtype=0&unicast=true&proto=Onvif
view:
default: live
update_force: true
- type: custom:vertical-stack-in-card
horizontal: true
cards:
- type: custom:mushroom-chips-card
alignment: center
chips:
- type: template
icon_color: |2-
{% set state=states('switch.sonoff_portao_social') %}
{% if state=='on' %}
white
{% elif state=='off' %}
red
{% endif %}
entity: switch.sonoff_portao_social
icon: >
{% set state=states('binary_sensor.sensor_portao_social_contact')
mdi:shield-key
{% else %}
mdi:shield-key-outline
{% endif %}
tap_action:
action: toggle
alignment: center
chips:
- type: template
icon_color: |2-
red
white
{% endif %}
icon: >
mdi:phone-in-talk
{% else %}
mdi:phone-in-talk
{% endif %}
tap_action:
action: toggle
alignment: center
chips:
- type: template
icon_color: |2-
{% set state=states('binary_sensor.voordeur_vehicle_detected') %}
orange
#6f6f6f
{% endif %}
entity: binary_sensor.voordeur_vehicle_detected
icon: |
mdi:car
{% else %}
mdi:car-off
{% endif %}
tap_action:
action: more-info
alignment: center
chips:
- type: template
icon_color: |2-
{% set state=states('binary_sensor.sensor_movimento_garagem_occupancy') %}
orange
#6f6f6f
{% endif %}
entity: binary_sensor.sensor_movimento_garagem_occupancy
icon: >
{% set
mdi:motion-sensor
{% else %}
mdi:motion-sensor-off
{% endif %}
tap_action:
action: more-info
alignment: center
chips:
- type: template
icon_color: |2-
{% set state=states('light.luz_garagem') %}
yellow
#6f6f6f
{% endif %}
entity: light.luz_garagem
icon: |
mdi:coach-lamp
{% else %}
mdi:coach-lamp
{% endif %}
tap_action:
action: toggle
alignment: center
chips:
- type: template
icon_color: |2-
{% set state=states('switch.voordeur_ir_lights') %}
red
#6f6f6f
{% endif %}
entity: switch.voordeur_ir_lights
icon: |
mdi:flashlight
{% else %}
mdi:flashlight-off
{% endif %}
tap_action:
action: toggle
