Thanks for sharing, with this other camera integration works great for my propose, get notifications when some rings the bell in HA
Good morning community, i have a vto2000 and added it to my HA. Everything seems to work well. I get a notification when the doorbell is rang and i can open the door via button. What i have problems with is the following:
I Added the lock to homekit via homekit bridge. I can also open the door via Homekit with a slider button. But after the door opens, it doesn´t move back to “closed”, it keeps saying “opening” until i manually slide it back to closed.
Is there anyway Homekit can do this automatically?
Thanks in advance!
Should works ok if you are using example from readme.
This example uses timer.door_lock
, be sure that you catch unlock event (code 8) and start the timer like it’s shows here.
You can also try to start the timer in the lock after calling open_door command:
timer:
door_lock:
icon: mdi:timer
lock:
value_template: "{{ not is_state('timer.door_lock', 'active') }}"
optimistic: false
lock:
unlock:
- service: dahua_vto.open_door
data_template:
entity_id: sensor.dahua_vto
channel: 1
short_number: HA
- service: timer.start
entity_id: timer.door_lock
duration: 00:00:02 # VTO Unlock Period
Hello myhomeiot, the timer.start with duration worked perfect! Thank you so much!
Hi guys,
Quick question from a noob on this topic
I live in a building where each apartment has VTH5221 that’s connected to main intercom downstairs via UTP cable, which also provides power(PoE).
Today I found out that I can access the ‘secret’ many on my VTH and connect it to my home wifi network, which I did.
Now, I came up to this thread wondering if I can integrate this device in my HA, but no luck so far.
Is this possible to achieve in my case at all?
Yes, you can try to define VTH connection at config:
- platform: dahua_vto
host: 192.168.1.100 # IP address of VTH
username: admin # For VTH usually admin
password: 112233 # Same password as you use to get into VTH settings usually 6 digits
scan_interval: 30
Than you can use this automation’s to get events from VTH.
See for received events and maybe you can find something useful. Sure you should get call information when someone rings you from VTO.
Thanks. Seems like the connection to my VTH works, I can see events when I add that automation.
But opening the door doesn’t seem to work. This is what I get from debug:
2024-04-13 12:54:50.141 DEBUG (MainThread) [custom_components.dahua_vto.sensor] <<< {"id":138,"params":{"timeout":60},"result":true,"session":25351993}
2024-04-13 12:55:11.632 DEBUG (MainThread) [custom_components.dahua_vto.sensor] >>> {"method":"accessControl.factory.instance","params":{"channel":0},"id":139,"session":25351993}
2024-04-13 12:55:11.952 DEBUG (MainThread) [custom_components.dahua_vto.sensor] <<< {"error":{"code":268894210,"message":"Method not found!"},"id":139,"result":false,"session":25351993}
On the VTO, we can report state of the door, when activated, we got the event above :
event_type: dahua_vto
Action: Pulse
Code: DoorStatus
Data:
LocaleTime: “2024-04-09 20:56:05”
RealUTC: 1712688965
Relay: true
Status: Close
UTC: 1712692565
Index: 0
And
Action: Pulse
Code: DoorStatus
Data:
DoorIndex: 0
LocaleTime: “2024-04-13 11:01:53”
RealUTC: 1712998913
Status: Open
UTC: 1713002513
Index: 0
That intressting because it offer the posibility to report the state of an entity from HA to VTH.
I don’t use the lock inside the VTO so y would like to report the state of my gate in place of.
But i don’t find the commande to send, I achied it with the alarm thanks to you.
Have someone an idea ?
Thomas
VTH doesn’t have command for opening door like VTO has. But you can try to issue console od
command to open door. In order to play with your VTH and find and test what you can do with it you can use this tool. Here the list of commands for VTH from mcw0/DahuaConsole
tool and my VTH, but at my VTH the od
command doesn’t works .
If you find working command and test it with DahuaConsole than you can issue it from integration:
# Send VTH Command od
service: dahua_vto.send_command
entity_id: sensor.dahua_vth
method: console.runCmd
params: {'command': 'od'}
event: false
Hi, I have set up this integration and now I’m trying to use this command to stop audio from playing. Could you please show how sensor.dahua_vth
is configured in configuration.yaml? VTO is all good but I fail at adding the VTH to HA.
Thank you in advance!
Sorry, missed the post you discribed how to set up VTH.
It tried that but it doesn’t work for me.
This is what I have in the configuration.yaml. I didn’t change any user or password in VTO or VTH. On VTH directly this default password is accepted. For user I don’t know there isn’t a username specified anywhere in VTH. But in HA I get this error:
host: 192.168.178.110
username: admin
password: !secret vto_password
scan_interval: 30
host: 192.168.178.109
username: admin
password: 123456
scan_interval: 30
2024-04-25 14:52:14.767 ERROR (MainThread) [homeassistant] Error doing job: Exception in callback _SelectorSocketTransport._call_connection_lost(None)
File "/usr/local/lib/python3.12/asyncio/events.py", line 88, in _run
self._context.run(self._callback, *self._args)
File "/usr/local/lib/python3.12/asyncio/selector_events.py", line 1181, in _call_connection_lost
super()._call_connection_lost(exc)
File "/usr/local/lib/python3.12/asyncio/selector_events.py", line 901, in _call_connection_lost
self._protocol.connection_lost(exc)
File "/config/custom_components/dahua_vto/sensor.py", line 147, in connection_lost
self.on_connection_lost.set_result(True)
asyncio.exceptions.InvalidStateError: invalid state
2024-04-25 14:52:15.767 ERROR (MainThread) [custom_components.dahua_vto.sensor] GoliathVTH: 268632085: Component error: User or password not valid!, retry in 10 seconds
You can see in the log the error Component error: User or password not valid!
For Dahua VTH user name is admin
but default password can be 888888 or 002236 or 123456.
Try to login into VTH settings with any of this password and then specify it in config.
How this looks you can see here.
Information about nice setup with 2 way audio, door unlock and much more here
can anyone explain the diffrences for the custom frigate card?
I am currently using the 305a2db git revision.
Good morning folks,
i keep on losing connection between VTH and VTO. I then go into the VTH settings and disconnect the SIP, press ok and connect new and everything seems to work for a couple of hours, days, weeks… I couldnt find the reason for this problem.
Is there a way to disconnect the SIP connection and connect new via this integration, so i can add it into a daily schedule?
Thanks in advance!
Steve
Here you can find all VTH commands, I think you can try reg
, restart
, reboot
commands. Start with reboot
command to be sure that you did everything correctly. You can also monitor all messages coming from VTH and see maybe you will receive message which means SIP disconnects when you can add automation for this specific message.
params: {'command': 'reboot'}
event: false
I’m using the model VTO3221E-P
When I add the sensor of this integration, it remains “unavailable”
when I look at the history status, I see that sometimes it’s “OK” for a very short time (like a second) and then back Unavailable.
When I change the port to 37777 then the sensor says “OK” (without any more attributes), when I try to send command to open door, it says timeout.
What should I do?
Hello, you can try to check Home Assistant log. If the problem similar to this issue, then try to install the previous version 1.0.6 and check again.
Edit: Use default port 5000 and not 37777.
Can you explain to me how to downgrade the integration?
If you install it using HACS you can go to integrations in HACS, select Dahua VTO then in … menu on right top corner select Redownload
and in version drop box choose 1.0.6
It didn’t help
sensor is still unavailable.
Can’t see anything in the logs. When I try to put wrong username/password, I see it in the logs. When I enter the correct ones, I don’t see a comment about that, so I assume they’re correct. Can’t understand what the problem is
