You can try to enable extra logging for integration in Home Assistant configuration.yaml
as it’s described here and attach here the log file.
Edit: You can also try to use this integration and see if it’s works with your VTO.
I see that in the logs:
This error originated from a custom integration.
Logger: homeassistant
Source: custom_components/dahua_vto/sensor.py:147
integration: Dahua VTO (documentation, issues)
First occurred: 13:48:28 (12 occurrences)
Last logged: 13:49:23
Error doing job: Exception in callback _SelectorSocketTransport._call_connection_lost(None) (None)
File "/usr/local/lib/python3.12/asyncio/events.py", line 88, in _run
self._context.run(self._callback, *self._args)
File "/usr/local/lib/python3.12/asyncio/selector_events.py", line 1181, in _call_connection_lost
super()._call_connection_lost(exc)
File "/usr/local/lib/python3.12/asyncio/selector_events.py", line 901, in _call_connection_lost
self._protocol.connection_lost(exc)
File "/config/custom_components/dahua_vto/sensor.py", line 147, in connection_lost
self.on_connection_lost.set_result(True)
asyncio.exceptions.InvalidStateError: invalid state
I also tried the other integration, and it also doesn’t seem to work for me.
I see all the entities but none of them is updating, and the camera entity shows nothing.
The only thing that works for me so far is ONVIF, which lets me see the camera well
I also see that:
2024-08-04 13:48:28.475 DEBUG (MainThread) [custom_components.dahua_vto.sensor] >>> {"method":"global.login","params":{"clientType":"","ipAddr":"(null)","loginType":"Direct","userName":"admin","password":"05D19825D5583D04335AA0CE558E55BB"},"id":2,"session":593263706}
2024-08-04 13:48:28.484 DEBUG (MainThread) [custom_components.dahua_vto.sensor] <<< {"error":{"code":268632085,"message":"Component error: User or password not valid!"},"id":2,"params":{"remainLockSecond":0,"remainLoginTimes":0},"result":false,"session":1476859084}
But these are the same username and password that i’m using for the ONVIF, and it works there
For the integration you should use user name and password which you use for VTO web interface which you can access by http://VTO-IP
Edit: Can you access your VTO using Dahua DMSS
application from the mobile?
Thank you. It was a username and password problem, now the sensor is working. I’ll check everything else. Thanks a lot!
I have connected my DAHUA VTO2022 to my HA.
My door is not directly connected to VTO but to HA with zigbee button.
I would like : When i press “open the door” on DMSS, HA open the door.
How i can see (entity?) when i press the button on DMSS (when i do it, my VTO say “the door is opened” but " [binary_sensor.portier_video_button_pressed]" stay at OFF).
I have seen message with the magnetic sensor but i don’t want to add fire as possible from door to VTO, i don’t want to drill )
Thanks for your answer
I wich you can understand, i’m french and i try to not use a translator
Thank you @myhomeiot for your great work! and for everyone here
I am a newpie who tried dozen of times to understand this without success
I did install HACS and Dahua + Dahua+VTO integrations.
Then I copied your examples to my yaml file but no success!
Here is my full yaml file hope you can help:
# Loads default set of integrations. Do not remove.
default_config:
# Load frontend themes from the themes folder
frontend:
themes: !include_dir_merge_named themes
script: !include scripts.yaml
scene: !include scenes.yaml
#Dahua
- platform: dahua_vto
host: http://192.168.1.10
##timeout: TIMEOUT_HERE optional, default 10
##port: PORT_HERE optional, default 5000
username: !secret myvto_username
password: !secret myvto_password
##scan_interval: SCAN_INTERVAL_HERE optional, default 60
host: http://192.168.1.11
username: !secret vh1_username
password: !secret vh1_password
automation myvto:
- alias: Dahua VTO All Events
mode: queued
- platform: event
event_type: dahua_vto
- service: persistent_notification.create
title: "{{ trigger.event.data.Code if trigger.event.data.Code is defined else 'Unknown Code' }}"
message: "{{ trigger.event.data }}"
- alias: Dahua VTO Command Result
mode: queued
- platform: event
condition:
- condition: template
value_template: "{{ trigger.event.data.method is defined }}"
title: "{{ trigger.event.data.method }}"
- alias: Dahua VTO
mode: queued
- platform: event
event_data:
Code: BackKeyLight
- choose:
- conditions: >
{{ trigger.event.data.Data.State | int in [0, 1, 2, 5, 6] }}
sequence:
title: "{{ 'Doorbell Ring' if trigger.event.data.Data.State | int in [1, 2] else 'Doorbell No Ring' }}"
- conditions: >
{{ trigger.event.data.Data.State | int == 8 }}
sequence:
- service: timer.start
entity_id: timer.door_lock
duration: 00:00:02 # VTO Unlock Period
title: Unlock
- conditions: >
{{ trigger.event.data.Data.State | int == 9 }}
sequence:
title: Unlock failed
- conditions: >
{{ trigger.event.data.Data.State | int == 11 }}
sequence:
title: Device rebooted
default:
title: "Unknown state {{ trigger.event.data.Data.State | int }}"
- service: dahua_vto.send_command
entity_id: sensor.myvto
method: console.runCmd
params: { "command": "od" }
event: false
method: system.listService
method: magicBox.listMethod
method: magicBox.reboot
params: { delay: 60 }
tag: alert
method: magicBox.getBootParameter
params: { names: ["serverip", "ver"] }
# Make VTO Call
params: { "command": "call 9901" }
event: false
# Cancel VTO Call
params: { "command": "hc" }
event: false
# Clear VTH Call Records
- service: dahua_vto.send_instance_command
entity_id: sensor.dahua_vth
method: RecordUpdater.clear
instance_params: { "name": "VideoTalkMissedLog" }
event: false
# Arming the VTH alarm
method: configManager.setConfig
params:
"table": { "AlarmEnable": true, "CurrentProfile": "Outdoor" },
"name": "CommGlobal",
event: false
# Disarming the VTH alarm
params:
"table": { "AlarmEnable": false, "CurrentProfile": "AtHome" },
event: false
# Getting the VTH alarm status
method: configManager.getConfig
params: { "name": "CommGlobal" }
event: true
timer:
door_lock:
icon: mdi:timer
lock:
value_template: "{{ not is_state('timer.door_lock', 'active') }}"
lock:
unlock:
- service: dahua_vto.open_door
data_template:
channel: 1
short_number: HA
template:
- trigger:
- platform: event
event_data:
Code: DoorStatus
binary_sensor:
- name: VTO Door Status
state: "{{ trigger.event.data.Data.Status | string == 'Open' }}"
device_class: door
Button:
type: "custom:button-card"
icon: "mdi:doorbell-video"
name: Doorstation - Door 1
tap_action:
action: call-service
service_data:
channel: 1
short_number: HA
styles:
card:
- font-size: 12px
- font-weight: bold
color: auto
show_state: false
Sample commands are provided for some VTH actions, such as setting alarm status and clearing missed call records. The VTH can be configured to stream video feeds from IP cameras other than the VTO. Does anybody know of a command(s) to make the VTH display one of these preconfigured camera feeds?
My use case would be an automation flow such that a motion detection event, if classified by AI tools as involving a person, would cause the relevant camera’s video stream to be displayed on the VTH.
Thanks.
In my case in DMSS application when I try open the door which is not connected I get BackKeyLight
event with State
equal 9
(Unlock failed) you can use it to send command which press your zigbee button which will open the door.
Try Dahua VTO All Events or Dahua VTO automation from readme and check if you get this state when you try to open the door with DMSS application.
You copied too much, the readme doesn’t not have configuration - it’s contains different code snippets which you need to use as example to automate your needs. So first try only with sensors definition and after restarting Home Assistant check that sensors in OK
state, when add Dahua VTO All Events
automation from this example and check events you get, etc
PS: If you a new in Home Assistant YAML programming and you just start integration of Dahua VTO/VTH you can try this integration which is much user friendly.
