Apart from these messages when the doorbell is pushed it is flooded with “keepAlive back”.
With the log in debug level I cannot assist
I have just configured the debug level and in just a minute I have so many pages that I fail to select the text multiple times - is a log refresh obstructing me?
Do you want all that text pasted (here)?
The addon starts fine and works as well but after a while it stops working and i get these lines the log:
2021-01-21 11:33:46,693 INFO __main__ Keep alive
2021-01-21 11:33:46,694 WARNING asyncio socket.send() raised exception.
I tried to reinstall using the docker through Portainer but i recevie an error in the logs.
“standard_init_linux.go:219: exec user process caused: exec format error,”
I have been told it is due to “The container you are downloading does not match the architecture of your system.”
Do you know of any alternative soluitions to install ?
Added first action to open door,
you can publish with the latest version a message with topic:
[MQTT_BROKER_TOPIC_PREFIX]/Command/Open
Please change the log level to debug (add environment variable of DEBUG set to true) and post the log
thanks
sorry but i have searched and cant figure out how to add or change the debug level… apparently not as smart as i thought
Solved it, released new version
Reset connection when server sends EOF message gracefully instead of WARNING asyncio socket.send() raised exception
Nevermind, the problem was with the integration: I reconfigured it and now the sensor is by default off.
Hi @bar, did you mean the FULL home assistant log?
I just see now that above that line, ?short version of the log?, there is an error message: regarding the MQTT broker:
and this is from the DahuaVTO2MQTT log when the doorbell is pushed
keepAlive back
keepAlive back
Event BackKeyLight with State 1
MQTT message published, Topic: DahuaVTO/BackKeyLight/Event, Payload: {"Action":"Pulse","Data":{"LocaleTime":"2021-01-21 20:34:54","State":1,"UTC":1611261294}}
Event Call from VTO
MQTT message published, Topic: DahuaVTO/CallNoAnswered/Event, Payload: {"Action":"Start","Data":{"CallID":"9","LocaleTime":"2021-01-21 20:34:54","UTC":1611261294}}
Event VideoBlind started
MQTT message published, Topic: DahuaVTO/VideoBlind/Event, Payload: {"Action":"Start","Data":{"LocaleTime":"2021-01-21 20:34:54","UTC":1611261294}}
Event KeepLightOn
MQTT message published, Topic: DahuaVTO/KeepLightOn/Event, Payload: {"Action":"Pulse","Data":{"LocaleTime":"2021-01-21 20:34:55","Status":"On","UTC":1611261295}}
Event Rtsp-Session from 192.168.1.109 connected
MQTT message published, Topic: DahuaVTO/RtspSessionDisconnect/Event, Payload: {"Action":"Stop","Data":{"Device":"::ffff:192.168.1.109","LocaleTime":"2021-01-21 20:34:55","StreamType":"Snapshot","UTC":1611261295,"UserAgent":" Rtsp Client\/3.0"}}
Event Rtsp-Session from 192.168.1.109 disconnected
MQTT message published, Topic: DahuaVTO/RtspSessionDisconnect/Event, Payload: {"Action":"Start","Data":{"Device":"::ffff:192.168.1.109","LocaleTime":"2021-01-21 20:34:56","StreamType":"Snapshot","UTC":1611261296,"UserAgent":" Rtsp Client\/3.0"}}
keepAlive back
Event VideoBlind stopped
MQTT message published, Topic: DahuaVTO/VideoBlind/Event, Payload: {"Action":"Stop","Data":{"LocaleTime":"2021-01-21 20:35:36","UTC":1611261336}}
Event KeepLightOff
MQTT message published, Topic: DahuaVTO/KeepLightOn/Event, Payload: {"Action":"Pulse","Data":{"LocaleTime":"2021-01-21 20:35:36","Status":"Off","UTC":1611261336}}
Event BackKeyLight with State 0
MQTT message published, Topic: DahuaVTO/BackKeyLight/Event, Payload: {"Action":"Pulse","Data":{"LocaleTime":"2021-01-21 20:35:36","State":0,"UTC":1611261336}}
keepAlive back
keepAlive back
Thanks - I added this to my config file, but i received an error when i try to check configuration.
i have added in the config as:
shell_command:
please replace it with the enivironment variable you’ve set for the topic prefix (of docker container),
use MQTT explorer to make sure you are table to publish it
I have done that :
[MY_MQTT_BROKER_IP_DahuaVTO)
I am using the add on (https://github.com/troykelly/hassio-addons)
and not the docker as i am using HA OS.
could this be why it does not work?
Can you share the logs or incoming topic you are listening to?
Thank you for helping:
Here are the logs from the add on.
[s6-init] making user provided files available at /var/run/s6/etc…exited 0.
[s6-init] ensuring user provided files have correct perms…exited 0.
[fix-attrs.d] applying ownership & permissions fixes…
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts…
[cont-init.d] done.
[services.d] starting services
[services.d] done.
[14:33:01] INFO: Staring Dahua to MQTT
<*** Dahua VTO Event Listener START ***>
Start login
Login success
Started keepAlive thread
keepAlive back
Event Manager subscription reply
keepAlive back
keepAlive back
Event SIPRegisterResult, Success
MQTT message published, Topic: null/SIPRegisterResult/Event, Payload: {“Action”:“Pulse”,“Data”:{“LocaleTime”:“2021-01-26 14:35:19”,“Success”:true,“UTC”:1611671719}}
MQTT message published, Topic: null/SIPRegisterResult/Event, Payload: {“Action”:“Pulse”,“Data”:{“Date”:“26-01-2021 14:35:20”,“LocaleTime”:“2021-01-26 14:35:20”,“Success”:true,“UTC”:1611671720}}
keepAlive back
keepAlive back
keepAlive back
keepAlive back
keepAlive back
MQTT message published, Topic: null/SIPRegisterResult/Event, Payload: {“Action”:“Pulse”,“Data”:{“LocaleTime”:“2021-01-26 14:40:19”,“Success”:true,“UTC”:1611672019}}
MQTT message published, Topic: null/SIPRegisterResult/Event, Payload: {“Action”:“Pulse”,“Data”:{“Date”:“26-01-2021 14:40:20”,“LocaleTime”:“2021-01-26 14:40:20”,“Success”:true,“UTC”:1611672020}}
keepAlive back
keepAlive back
keepAlive back
keepAlive back
keepAlive back
MQTT message published, Topic: null/SIPRegisterResult/Event, Payload: {“Action”:“Pulse”,“Data”:{“LocaleTime”:“2021-01-26 14:45:19”,“Success”:true,“UTC”:1611672319}}
MQTT message published, Topic: null/SIPRegisterResult/Event, Payload: {“Action”:“Pulse”,“Data”:{“Date”:“26-01-2021 14:45:20”,“LocaleTime”:“2021-01-26 14:45:20”,“Success”:true,“UTC”:1611672320}}
keepAlive back
Event TimeChange, BeforeModifyTime: 26-01-2021 14:47:07, ModifiedTime: 26-01-2021 14:47:07
MQTT message published, Topic: null/TimeChange/Event, Payload: {“Action”:“Pulse”,“Data”:{“BeforeModifyTime”:“26-01-2021 14:47:07”,“LocaleTime”:“2021-01-26 14:47:07”,“ModifiedTime”:“26-01-2021 14:47:07”,“UTC”:1611672427}}
keepAlive back
keepAlive back
keepAlive back
keepAlive back
MQTT message published, Topic: null/SIPRegisterResult/Event, Payload: {“Action”:“Pulse”,“Data”:{“LocaleTime”:“2021-01-26 14:50:17”,“Success”:true,“UTC”:1611672617}}
MQTT message published, Topic: null/SIPRegisterResult/Event, Payload: {“Action”:“Pulse”,“Data”:{“Date”:“26-01-2021 14:50:19”,“LocaleTime”:“2021-01-26 14:50:19”,“Success”:true,“UTC”:1611672619}}
keepAlive back
keepAlive back
Event BackKeyLight with State 8
MQTT message published, Topic: null/BackKeyLight/Event, Payload: {“Action”:“Pulse”,“Data”:{“LocaleTime”:“2021-01-26 14:52:58”,“State”:8,“UTC”:1611672778}}
Event: BackLightOn
MQTT message published, Topic: null/BackLightOn/Event, Payload: {“Action”:“Pulse”,“Data”:{“LocaleTime”:“2021-01-26 14:52:58”,“UTC”:1611672778}}
Event: AccessControl, Name OpenDoor Method 4, ReaderID 1, UserID
MQTT message published, Topic: null/AccessControl/Event, Payload: {“Action”:“Pulse”,“Data”:{“CardNo”:"",“CardType”:null,“LocaleTime”:“2021-01-26 14:52:58”,“Method”:4,“Name”:“OpenDoor”,“Password”:"",“ReaderID”:“1”,“RecNo”:482,“SnapURL”:"",“Status”:1,“Type”:“Entry”,“UTC”:1611672778,“UserID”:""}}
Event: BackLightOff
MQTT message published, Topic: null/BackLightOff/Event, Payload: {“Action”:“Pulse”,“Data”:{“LocaleTime”:“2021-01-26 14:53:01”,“UTC”:1611672781}}
keepAlive back
keepAlive back
keepAlive back
MQTT message published, Topic: null/SIPRegisterResult/Event, Payload: {“Action”:“Pulse”,“Data”:{“LocaleTime”:“2021-01-26 14:55:17”,“Success”:true,“UTC”:1611672917}}
MQTT message published, Topic: null/SIPRegisterResult/Event, Payload: {“Action”:“Pulse”,“Data”:{“Date”:“26-01-2021 14:55:18”,“LocaleTime”:“2021-01-26 14:55:18”,“Success”:true,“UTC”:1611672918}}
keepAlive back
keepAlive back
keepAlive back
keepAlive back
MQTT message published, Topic: null/SIPRegisterResult/Event, Payload: {“Action”:“Pulse”,“Data”:{“LocaleTime”:“2021-01-26 15:00:17”,“Success”:true,“UTC”:1611673217}}
MQTT message published, Topic: null/SIPRegisterResult/Event, Payload: {“Action”:“Pulse”,“Data”:{“Date”:“26-01-2021 15:00:18”,“LocaleTime”:“2021-01-26 15:00:18”,“Success”:true,“UTC”:1611673218}}
keepAlive back
keepAlive back
keepAlive back
keepAlive back
keepAlive back
MQTT message published, Topic: null/SIPRegisterResult/Event, Payload: {“Action”:“Pulse”,“Data”:{“LocaleTime”:“2021-01-26 15:05:17”,“Success”:true,“UTC”:1611673517}}
MQTT message published, Topic: null/SIPRegisterResult/Event, Payload: {“Action”:“Pulse”,“Data”:{“Date”:“26-01-2021 15:05:18”,“LocaleTime”:“2021-01-26 15:05:18”,“Success”:true,“UTC”:1611673518}}
keepAlive back
keepAlive back
keepAlive back
it seems that you didn’t configure the integration well, currently the topic you need to publish is:
null/Command/Open
I noticed that - i think it was due to using a different add on. I have now used this one. below are the logs.
2021-01-26 15:39:24,407 INFO main Publishing MQTT message DahuaVTO/AlarmLocal/Event: {‘Action’: ‘Start’, ‘Code’: ‘AlarmLocal’, ‘Data’: {‘LocaleTime’: ‘2021-01-26 15:39:24’, ‘UTC’: 1611675564.0}, ‘Index’: 4, ‘Param’: {}, ‘deviceType’: ‘VTO6221E’, ‘serialNumber’: ‘6C01F4CPAZ2D99D’}
2021-01-26 15:39:24,408 INFO main Publishing MQTT message DahuaVTO/CallNoAnswered/Event: {‘Action’: ‘Start’, ‘Code’: ‘CallNoAnswered’, ‘Data’: {‘CallID’: ‘1’, ‘LocaleTime’: ‘2021-01-26 15:39:24’, ‘UTC’: 1611675564.0}, ‘Index’: 0, ‘Param’: {}, ‘deviceType’: ‘VTO6221E’, ‘serialNumber’: ‘6C01F4CPAZ2D99D’}
2021-01-26 15:39:24,409 INFO main Publishing MQTT message DahuaVTO/CallNoAnswered/Event: {‘Action’: ‘Start’, ‘Code’: ‘CallNoAnswered’, ‘Data’: {‘CallID’: ‘1’, ‘LocaleTime’: ‘2021-01-26 15:39:24’, ‘UTC’: 1611675564.0}, ‘Index’: 9900, ‘Param’: {}, ‘deviceType’: ‘VTO6221E’, ‘serialNumber’: ‘6C01F4CPAZ2D99D’}
2021-01-26 15:39:24,410 INFO main Publishing MQTT message DahuaVTO/PassiveHungup/Event: {‘Action’: ‘Start’, ‘Code’: ‘PassiveHungup’, ‘Data’: {‘LocaleTime’: ‘2021-01-26 15:39:24’, ‘UTC’: 1611675564.0}, ‘Index’: 0, ‘Param’: None, ‘deviceType’: ‘VTO6221E’, ‘serialNumber’: ‘6C01F4CPAZ2D99D’}
2021-01-26 15:39:24,411 INFO main Publishing MQTT message DahuaVTO/ProfileAlarmTransmit/Event: {‘Action’: ‘Start’, ‘Code’: ‘ProfileAlarmTransmit’, ‘Data’: {‘DevSrcType’: ‘Digit’, ‘LocaleTime’: ‘2021-01-26 15:39:24’, ‘SenseMethod’: ‘PreventRemove’, ‘UTC’: 1611586022, ‘UserID’: ‘8001’}, ‘Index’: 1, ‘Param’: None, ‘deviceType’: ‘VTO6221E’, ‘serialNumber’: ‘6C01F4CPAZ2D99D’}
2021-01-26 15:39:24,411 INFO main Publishing MQTT message DahuaVTO/RequestCallState/Event: {‘Action’: ‘Start’, ‘Code’: ‘RequestCallState’, ‘Data’: {‘LocaleTime’: ‘2021-01-26 15:39:24’, ‘UTC’: 1611675564.0}, ‘Index’: 0, ‘Param’: {}, ‘deviceType’: ‘VTO6221E’, ‘serialNumber’: ‘6C01F4CPAZ2D99D’}
2021-01-26 15:39:44,520 INFO main Publishing MQTT message DahuaVTO/BackKeyLight/Event: {‘Action’: ‘Pulse’, ‘Code’: ‘BackKeyLight’, ‘Data’: {‘LocaleTime’: ‘2021-01-26 15:39:44’, ‘State’: 8, ‘UTC’: 1611675584.0}, ‘Index’: -1, ‘deviceType’: ‘VTO6221E’, ‘serialNumber’: ‘6C01F4CPAZ2D99D’}
2021-01-26 15:39:44,678 INFO main Publishing MQTT message DahuaVTO/BackLightOn/Event: {‘Action’: ‘Pulse’, ‘Code’: ‘BackLightOn’, ‘Data’: {‘LocaleTime’: ‘2021-01-26 15:39:44’, ‘UTC’: 1611675584.0}, ‘Index’: 0, ‘deviceType’: ‘VTO6221E’, ‘serialNumber’: ‘6C01F4CPAZ2D99D’}
2021-01-26 15:39:44,698 INFO main Publishing MQTT message DahuaVTO/AccessControl/Event: {‘Action’: ‘Pulse’, ‘Code’: ‘AccessControl’, ‘Data’: {‘CardNo’: ‘’, ‘CardType’: None, ‘LocaleTime’: ‘2021-01-26 15:39:44’, ‘Method’: 4, ‘Name’: ‘OpenDoor’, ‘Password’: ‘’, ‘ReaderID’: ‘1’, ‘RecNo’: 485, ‘SnapURL’: ‘’, ‘Status’: 1, ‘Type’: ‘Entry’, ‘UTC’: 1611675584.0, ‘UserID’: ‘’}, ‘Index’: 0, ‘deviceType’: ‘VTO6221E’, ‘serialNumber’: ‘6C01F4CPAZ2D99D’}
2021-01-26 15:39:47,810 INFO main Publishing MQTT message DahuaVTO/BackLightOff/Event: {‘Action’: ‘Pulse’, ‘Code’: ‘BackLightOff’, ‘Data’: {‘LocaleTime’: ‘2021-01-26 15:39:47’, ‘UTC’: 1611675587.0}, ‘Index’: 0, ‘deviceType’: ‘VTO6221E’, ‘serialNumber’: ‘6C01F4CPAZ2D99D’}
2021-01-26 15:40:17,427 INFO main Publishing MQTT message DahuaVTO/SIPRegisterResult/Event: {‘Action’: ‘Pulse’, ‘Code’: ‘SIPRegisterResult’, ‘Data’: {‘LocaleTime’: ‘2021-01-26 15:40:17’, ‘Success’: True, ‘UTC’: 1611675617.0}, ‘Index’: 0, ‘deviceType’: ‘VTO6221E’, ‘serialNumber’: ‘6C01F4CPAZ2D99D’}
2021-01-26 15:40:18,476 INFO main Publishing MQTT message DahuaVTO/SIPRegisterResult/Event: {‘Action’: ‘Pulse’, ‘Code’: ‘SIPRegisterResult’, ‘Data’: {‘Date’: ‘26-01-2021 15:40:18’, ‘LocaleTime’: ‘2021-01-26 15:40:18’, ‘Success’: True, ‘UTC’: 1611675618.0}, ‘Index’: 0, ‘deviceType’: ‘VTO6221E’, ‘serialNumber’: ‘6C01F4CPAZ2D99D’}
2021-01-26 15:42:57,661 INFO main Publishing MQTT message DahuaVTO/BackKeyLight/Event: {‘Action’: ‘Pulse’, ‘Code’: ‘BackKeyLight’, ‘Data’: {‘LocaleTime’: ‘2021-01-26 15:42:57’, ‘State’: 8, ‘UTC’: 1611675777.0}, ‘Index’: -1, ‘deviceType’: ‘VTO6221E’, ‘serialNumber’: ‘6C01F4CPAZ2D99D’}
2021-01-26 15:42:57,804 INFO main Publishing MQTT message DahuaVTO/BackLightOn/Event: {‘Action’: ‘Pulse’, ‘Code’: ‘BackLightOn’, ‘Data’: {‘LocaleTime’: ‘2021-01-26 15:42:57’, ‘UTC’: 1611675777.0}, ‘Index’: 0, ‘deviceType’: ‘VTO6221E’, ‘serialNumber’: ‘6C01F4CPAZ2D99D’}
2021-01-26 15:42:57,892 INFO main Publishing MQTT message DahuaVTO/AccessControl/Event: {‘Action’: ‘Pulse’, ‘Code’: ‘AccessControl’, ‘Data’: {‘CardNo’: ‘’, ‘CardType’: None, ‘LocaleTime’: ‘2021-01-26 15:42:57’, ‘Method’: 4, ‘Name’: ‘OpenDoor’, ‘Password’: ‘’, ‘ReaderID’: ‘1’, ‘RecNo’: 486, ‘SnapURL’: ‘’, ‘Status’: 1, ‘Type’: ‘Entry’, ‘UTC’: 1611675777.0, ‘UserID’: ‘’}, ‘Index’: 0, ‘deviceType’: ‘VTO6221E’, ‘serialNumber’: ‘6C01F4CPAZ2D99D’}
2021-01-26 15:43:00,948 INFO main Publishing MQTT message DahuaVTO/BackLightOff/Event: {‘Action’: ‘Pulse’, ‘Code’: ‘BackLightOff’, ‘Data’: {‘LocaleTime’: ‘2021-01-26 15:43:00’, ‘UTC’: 1611675780.0}, ‘Index’: 0, ‘deviceType’: ‘VTO6221E’, ‘serialNumber’: ‘6C01F4CPAZ2D99D’}
2021-01-26 15:43:13,385 INFO main Publishing MQTT message DahuaVTO/VideoMotion/Event: {‘Action’: ‘Start’, ‘Code’: ‘VideoMotion’, ‘Data’: {‘LocaleTime’: ‘2021-01-26 15:43:13’, ‘UTC’: 1611675793.0}, ‘Index’: 0, ‘deviceType’: ‘VTO6221E’, ‘serialNumber’: ‘6C01F4CPAZ2D99D’}
2021-01-26 15:43:19,005 INFO main Publishing MQTT message DahuaVTO/CallNoAnswered/Event: {‘Action’: ‘Start’, ‘Code’: ‘CallNoAnswered’, ‘Data’: {‘CallID’: ‘4’, ‘LocaleTime’: ‘2021-01-26 15:43:18’, ‘UTC’: 1611675798.0}, ‘Index’: 0, ‘deviceType’: ‘VTO6221E’, ‘serialNumber’: ‘6C01F4CPAZ2D99D’}
2021-01-26 15:43:19,007 INFO main Publishing MQTT message DahuaVTO/Invite/Event: {‘Action’: ‘Pulse’, ‘Code’: ‘Invite’, ‘Data’: {‘CallID’: ‘4’, ‘LocaleTime’: ‘2021-01-26 15:43:18’, ‘UTC’: 1611675798.0}, ‘Index’: 0, ‘deviceType’: ‘VTO6221E’, ‘serialNumber’: ‘6C01F4CPAZ2D99D’}
2021-01-26 15:43:19,164 INFO main Publishing MQTT message DahuaVTO/BackLightOn/Event: {‘Action’: ‘Pulse’, ‘Code’: ‘BackLightOn’, ‘Data’: {‘LocaleTime’: ‘2021-01-26 15:43:19’, ‘UTC’: 1611675799.0}, ‘Index’: 0, ‘deviceType’: ‘VTO6221E’, ‘serialNumber’: ‘6C01F4CPAZ2D99D’}
2021-01-26 15:43:25,624 INFO main Publishing MQTT message DahuaVTO/VideoMotion/Event: {‘Action’: ‘Stop’, ‘Code’: ‘VideoMotion’, ‘Data’: {‘LocaleTime’: ‘2021-01-26 15:43:25’, ‘UTC’: 1611675805.0}, ‘Index’: 0, ‘deviceType’: ‘VTO6221E’, ‘serialNumber’: ‘6C01F4CPAZ2D99D’}
2021-01-26 15:43:26,016 INFO main Publishing MQTT message DahuaVTO/BackLightOff/Event: {‘Action’: ‘Pulse’, ‘Code’: ‘BackLightOff’, ‘Data’: {‘LocaleTime’: ‘2021-01-26 15:43:25’, ‘UTC’: 1611675805.0}, ‘Index’: 0, ‘deviceType’: ‘VTO6221E’, ‘serialNumber’: ‘6C01F4CPAZ2D99D’}
2021-01-26 15:45:17,443 INFO main Publishing MQTT message DahuaVTO/SIPRegisterResult/Event: {‘Action’: ‘Pulse’, ‘Code’: ‘SIPRegisterResult’, ‘Data’: {‘LocaleTime’: ‘2021-01-26 15:45:17’, ‘Success’: True, ‘UTC’: 1611675917.0}, ‘Index’: 0, ‘deviceType’: ‘VTO6221E’, ‘serialNumber’: ‘6C01F4CPAZ2D99D’}
2021-01-26 15:45:18,485 INFO main Publishing MQTT message DahuaVTO/SIPRegisterResult/Event: {‘Action’: ‘Pulse’, ‘Code’: ‘SIPRegisterResult’, ‘Data’: {‘Date’: ‘26-01-2021 15:45:18’, ‘LocaleTime’: ‘2021-01-26 15:45:18’, ‘Success’: True, ‘UTC’: 1611675918.0}, ‘Index’: 0, ‘deviceType’: ‘VTO6221E’, ‘serialNumber’: ‘6C01F4CPAZ2D99D’}
2021-01-26 15:50:17,448 INFO main Publishing MQTT message DahuaVTO/SIPRegisterResult/Event: {‘Action’: ‘Pulse’, ‘Code’: ‘SIPRegisterResult’, ‘Data’: {‘LocaleTime’: ‘2021-01-26 15:50:17’, ‘Success’: True, ‘UTC’: 1611676217.0}, ‘Index’: 0, ‘deviceType’: ‘VTO6221E’, ‘serialNumber’: ‘6C01F4CPAZ2D99D’}
2021-01-26 15:50:18,490 INFO main Publishing MQTT message DahuaVTO/SIPRegisterResult/Event: {‘Action’: ‘Pulse’, ‘Code’: ‘SIPRegisterResult’, ‘Data’: {‘Date’: ‘26-01-2021 15:50:18’, ‘LocaleTime’: ‘2021-01-26 15:50:18’, ‘Success’: True, ‘UTC’: 1611676218.0}, ‘Index’: 0, ‘deviceType’: ‘VTO6221E’, ‘serialNumber’: ‘6C01F4CPAZ2D99D’}
2021-01-26 15:50:57,521 INFO main Publishing MQTT message DahuaVTO/BackKeyLight/Event: {‘Action’: ‘Pulse’, ‘Code’: ‘BackKeyLight’, ‘Data’: {‘LocaleTime’: ‘2021-01-26 15:50:57’, ‘State’: 8, ‘UTC’: 1611676257.0}, ‘Index’: -1, ‘deviceType’: ‘VTO6221E’, ‘serialNumber’: ‘6C01F4CPAZ2D99D’}
2021-01-26 15:50:57,660 INFO main Publishing MQTT message DahuaVTO/BackLightOn/Event: {‘Action’: ‘Pulse’, ‘Code’: ‘BackLightOn’, ‘Data’: {‘LocaleTime’: ‘2021-01-26 15:50:57’, ‘UTC’: 1611676257.0}, ‘Index’: 0, ‘deviceType’: ‘VTO6221E’, ‘serialNumber’: ‘6C01F4CPAZ2D99D’}
2021-01-26 15:50:57,692 INFO main Publishing MQTT message DahuaVTO/AccessControl/Event: {‘Action’: ‘Pulse’, ‘Code’: ‘AccessControl’, ‘Data’: {‘CardNo’: ‘’, ‘CardType’: None, ‘LocaleTime’: ‘2021-01-26 15:50:57’, ‘Method’: 4, ‘Name’: ‘OpenDoor’, ‘Password’: ‘’, ‘ReaderID’: ‘1’, ‘RecNo’: 487, ‘SnapURL’: ‘’, ‘Status’: 1, ‘Type’: ‘Entry’, ‘UTC’: 1611676257.0, ‘UserID’: ‘’}, ‘Index’: 0, ‘deviceType’: ‘VTO6221E’, ‘serialNumber’: ‘6C01F4CPAZ2D99D’}
2021-01-26 15:51:00,790 INFO main Publishing MQTT message DahuaVTO/BackLightOff/Event: {‘Action’: ‘Pulse’, ‘Code’: ‘BackLightOff’, ‘Data’: {‘LocaleTime’: ‘2021-01-26 15:51:00’, ‘UTC’: 1611676260.0}, ‘Index’: 0, ‘deviceType’: ‘VTO6221E’, ‘serialNumber’: ‘6C01F4CPAZ2D99D’}
2021-01-26 15:55:17,434 INFO main Publishing MQTT message DahuaVTO/SIPRegisterResult/Event: {‘Action’: ‘Pulse’, ‘Code’: ‘SIPRegisterResult’, ‘Data’: {‘LocaleTime’: ‘2021-01-26 15:55:17’, ‘Success’: True, ‘UTC’: 1611676517.0}, ‘Index’: 0, ‘deviceType’: ‘VTO6221E’, ‘serialNumber’: ‘6C01F4CPAZ2D99D’}
2021-01-26 15:55:18,494 INFO main Publishing MQTT message DahuaVTO/SIPRegisterResult/Event: {‘Action’: ‘Pulse’, ‘Code’: ‘SIPRegisterResult’, ‘Data’: {‘Date’: ‘26-01-2021 15:55:18’, ‘LocaleTime’: ‘2021-01-26 15:55:18’, ‘Success’: True, ‘UTC’: 1611676518.0}, ‘Index’: 0, ‘deviceType’: ‘VTO6221E’, ‘serialNumber’: ‘6C01F4CPAZ2D99D’}
2021-01-26 16:00:17,418 INFO main Publishing MQTT message DahuaVTO/SIPRegisterResult/Event: {‘Action’: ‘Pulse’, ‘Code’: ‘SIPRegisterResult’, ‘Data’: {‘LocaleTime’: ‘2021-01-26 16:00:17’, ‘Success’: True, ‘UTC’: 1611676817.0}, ‘Index’: 0, ‘deviceType’: ‘VTO6221E’, ‘serialNumber’: ‘6C01F4CPAZ2D99D’}
2021-01-26 16:00:18,471 INFO main Publishing MQTT message DahuaVTO/SIPRegisterResult/Event: {‘Action’: ‘Pulse’, ‘Code’: ‘SIPRegisterResult’, ‘Data’: {‘Date’: ‘26-01-2021 16:00:18’, ‘LocaleTime’: ‘2021-01-26 16:00:18’, ‘Success’: True, ‘UTC’: 1611676818.0}, ‘Index’: 0, ‘deviceType’: ‘VTO6221E’, ‘serialNumber’: ‘6C01F4CPAZ2D99D’}
2021-01-26 16:05:17,436 INFO main Publishing MQTT message DahuaVTO/SIPRegisterResult/Event: {‘Action’: ‘Pulse’, ‘Code’: ‘SIPRegisterResult’, ‘Data’: {‘LocaleTime’: ‘2021-01-26 16:05:17’, ‘Success’: True, ‘UTC’: 1611677117.0}, ‘Index’: 0, ‘deviceType’: ‘VTO6221E’, ‘serialNumber’: ‘6C01F4CPAZ2D99D’}
2021-01-26 16:05:18,500 INFO main Publishing MQTT message DahuaVTO/SIPRegisterResult/Event: {‘Action’: ‘Pulse’, ‘Code’: ‘SIPRegisterResult’, ‘Data’: {‘Date’: ‘26-01-2021 16:05:18’, ‘LocaleTime’: ‘2021-01-26 16:05:18’, ‘Success’: True, ‘UTC’: 1611677118.0}, ‘Index’: 0, ‘deviceType’: ‘VTO6221E’, ‘serialNumber’: ‘6C01F4CPAZ2D99D’}
2021-01-26 16:10:17,421 INFO main Publishing MQTT message DahuaVTO/SIPRegisterResult/Event: {‘Action’: ‘Pulse’, ‘Code’: ‘SIPRegisterResult’, ‘Data’: {‘LocaleTime’: ‘2021-01-26 16:10:17’, ‘Success’: True, ‘UTC’: 1611677417.0}, ‘Index’: 0, ‘deviceType’: ‘VTO6221E’, ‘serialNumber’: ‘6C01F4CPAZ2D99D’}
2021-01-26 16:10:18,494 INFO main Publishing MQTT message DahuaVTO/SIPRegisterResult/Event: {‘Action’: ‘Pulse’, ‘Code’: ‘SIPRegisterResult’, ‘Data’: {‘Date’: ‘26-01-2021 16:10:18’, ‘LocaleTime’: ‘2021-01-26 16:10:18’, ‘Success’: True, ‘UTC’: 1611677418.0}, ‘Index’: 0, ‘deviceType’: ‘VTO6221E’, ‘serialNumber’: ‘6C01F4CPAZ2D99D’}
2021-01-26 16:15:17,425 INFO main Publishing MQTT message DahuaVTO/SIPRegisterResult/Event: {‘Action’: ‘Pulse’, ‘Code’: ‘SIPRegisterResult’, ‘Data’: {‘LocaleTime’: ‘2021-01-26 16:15:17’, ‘Success’: True, ‘UTC’: 1611677717.0}, ‘Index’: 0, ‘deviceType’: ‘VTO6221E’, ‘serialNumber’: ‘6C01F4CPAZ2D99D’}
2021-01-26 16:15:18,489 INFO main Publishing MQTT message DahuaVTO/SIPRegisterResult/Event: {‘Action’: ‘Pulse’, ‘Code’: ‘SIPRegisterResult’, ‘Data’: {‘Date’: ‘26-01-2021 16:15:18’, ‘LocaleTime’: ‘2021-01-26 16:15:18’, ‘Success’: True, ‘UTC’: 1611677718.0}, ‘Index’: 0, ‘deviceType’: ‘VTO6221E’, ‘serialNumber’: ‘6C01F4CPAZ2D99D’}
2021-01-26 16:20:17,444 INFO main Publishing MQTT message DahuaVTO/SIPRegisterResult/Event: {‘Action’: ‘Pulse’, ‘Code’: ‘SIPRegisterResult’, ‘Data’: {‘LocaleTime’: ‘2021-01-26 16:20:17’, ‘Success’: True, ‘UTC’: 1611678017.0}, ‘Index’: 0, ‘deviceType’: ‘VTO6221E’, ‘serialNumber’: ‘6C01F4CPAZ2D99D’}
2021-01-26 16:20:18,501 INFO main Publishing MQTT message DahuaVTO/SIPRegisterResult/Event: {‘Action’: ‘Pulse’, ‘Code’: ‘SIPRegisterResult’, ‘Data’: {‘Date’: ‘26-01-2021 16:20:18’, ‘LocaleTime’: ‘2021-01-26 16:20:18’, ‘Success’: True, ‘UTC’: 1611678018.0}, ‘Index’: 0, ‘deviceType’: ‘VTO6221E’, ‘serialNumber’: ‘6C01F4CPAZ2D99D’}
2021-01-26 16:25:01,647 INFO main Publishing MQTT message DahuaVTO/VideoMotion/Event: {‘Action’: ‘Start’, ‘Code’: ‘VideoMotion’, ‘Data’: {‘LocaleTime’: ‘2021-01-26 16:25:01’, ‘UTC’: 1611678301.0}, ‘Index’: 0, ‘deviceType’: ‘VTO6221E’, ‘serialNumber’: ‘6C01F4CPAZ2D99D’}
2021-01-26 16:25:06,597 INFO main Publishing MQTT message DahuaVTO/VideoMotion/Event: {‘Action’: ‘Stop’, ‘Code’: ‘VideoMotion’, ‘Data’: {‘LocaleTime’: ‘2021-01-26 16:25:06’, ‘UTC’: 1611678306.0}, ‘Index’: 0, ‘deviceType’: ‘VTO6221E’, ‘serialNumber’: ‘6C01F4CPAZ2D99D’}
2021-01-26 16:25:17,428 INFO main Publishing MQTT message DahuaVTO/SIPRegisterResult/Event: {‘Action’: ‘Pulse’, ‘Code’: ‘SIPRegisterResult’, ‘Data’: {‘LocaleTime’: ‘2021-01-26 16:25:17’, ‘Success’: True, ‘UTC’: 1611678317.0}, ‘Index’: 0, ‘deviceType’: ‘VTO6221E’, ‘serialNumber’: ‘6C01F4CPAZ2D99D’}
2021-01-26 16:25:18,509 INFO main Publishing MQTT message DahuaVTO/SIPRegisterResult/Event: {‘Action’: ‘Pulse’, ‘Code’: ‘SIPRegisterResult’, ‘Data’: {‘Date’: ‘26-01-2021 16:25:18’, ‘LocaleTime’: ‘2021-01-26 16:25:18’, ‘Success’: True, ‘UTC’: 1611678318.0}, ‘Index’: 0, ‘deviceType’: ‘VTO6221E’, ‘serialNumber’: ‘6C01F4CPAZ2D99D’}
2021-01-26 16:27:18,718 INFO main Publishing MQTT message DahuaVTO/BackKeyLight/Event: {‘Action’: ‘Pulse’, ‘Code’: ‘BackKeyLight’, ‘Data’: {‘LocaleTime’: ‘2021-01-26 16:27:18’, ‘State’: 8, ‘UTC’: 1611678438.0}, ‘Index’: -1, ‘deviceType’: ‘VTO6221E’, ‘serialNumber’: ‘6C01F4CPAZ2D99D’}
2021-01-26 16:27:18,872 INFO main Publishing MQTT message DahuaVTO/BackLightOn/Event: {‘Action’: ‘Pulse’, ‘Code’: ‘BackLightOn’, ‘Data’: {‘LocaleTime’: ‘2021-01-26 16:27:18’, ‘UTC’: 1611678438.0}, ‘Index’: 0, ‘deviceType’: ‘VTO6221E’, ‘serialNumber’: ‘6C01F4CPAZ2D99D’}
2021-01-26 16:27:18,911 INFO main Publishing MQTT message DahuaVTO/AccessControl/Event: {‘Action’: ‘Pulse’, ‘Code’: ‘AccessControl’, ‘Data’: {‘CardNo’: ‘’, ‘CardType’: None, ‘LocaleTime’: ‘2021-01-26 16:27:18’, ‘Method’: 4, ‘Name’: ‘OpenDoor’, ‘Password’: ‘’, ‘ReaderID’: ‘1’, ‘RecNo’: 488, ‘SnapURL’: ‘’, ‘Status’: 1, ‘Type’: ‘Entry’, ‘UTC’: 1611678438.0, ‘UserID’: ‘’}, ‘Index’: 0, ‘deviceType’: ‘VTO6221E’, ‘serialNumber’: ‘6C01F4CPAZ2D99D’}
2021-01-26 16:27:22,024 INFO main Publishing MQTT message DahuaVTO/BackLightOff/Event: {‘Action’: ‘Pulse’, ‘Code’: ‘BackLightOff’, ‘Data’: {‘LocaleTime’: ‘2021-01-26 16:27:22’, ‘UTC’: 1611678442.0}, ‘Index’: 0, ‘deviceType’: ‘VTO6221E’, ‘serialNumber’: ‘6C01F4CPAZ2D99D’}
2021-01-26 16:30:17,382 INFO main Publishing MQTT message DahuaVTO/SIPRegisterResult/Event: {‘Action’: ‘Pulse’, ‘Code’: ‘SIPRegisterResult’, ‘Data’: {‘LocaleTime’: ‘2021-01-26 16:30:17’, ‘Success’: True, ‘UTC’: 1611678617.0}, ‘Index’: 0, ‘deviceType’: ‘VTO6221E’, ‘serialNumber’: ‘6C01F4CPAZ2D99D’}
2021-01-26 16:30:18,429 INFO main Publishing MQTT message DahuaVTO/SIPRegisterResult/Event: {‘Action’: ‘Pulse’, ‘Code’: ‘SIPRegisterResult’, ‘Data’: {‘Date’: ‘26-01-2021 16:30:18’, ‘LocaleTime’: ‘2021-01-26 16:30:18’, ‘Success’: True, ‘UTC’: 1611678618.0}, ‘Index’: 0, ‘deviceType’: ‘VTO6221E’, ‘serialNumber’: ‘6C01F4CPAZ2D99D’}
2021-01-26 16:33:05,156 INFO main Publishing MQTT message DahuaVTO/BackKeyLight/Event: {‘Action’: ‘Pulse’, ‘Code’: ‘BackKeyLight’, ‘Data’: {‘LocaleTime’: ‘2021-01-26 16:33:05’, ‘State’: 8, ‘UTC’: 1611678785.0}, ‘Index’: -1, ‘deviceType’: ‘VTO6221E’, ‘serialNumber’: ‘6C01F4CPAZ2D99D’}
2021-01-26 16:33:05,297 INFO main Publishing MQTT message DahuaVTO/BackLightOn/Event: {‘Action’: ‘Pulse’, ‘Code’: ‘BackLightOn’, ‘Data’: {‘LocaleTime’: ‘2021-01-26 16:33:05’, ‘UTC’: 1611678785.0}, ‘Index’: 0, ‘deviceType’: ‘VTO6221E’, ‘serialNumber’: ‘6C01F4CPAZ2D99D’}
2021-01-26 16:33:05,338 INFO main Publishing MQTT message DahuaVTO/AccessControl/Event: {‘Action’: ‘Pulse’, ‘Code’: ‘AccessControl’, ‘Data’: {‘CardNo’: ‘’, ‘CardType’: None, ‘LocaleTime’: ‘2021-01-26 16:33:05’, ‘Method’: 4, ‘Name’: ‘OpenDoor’, ‘Password’: ‘’, ‘ReaderID’: ‘1’, ‘RecNo’: 489, ‘SnapURL’: ‘’, ‘Status’: 1, ‘Type’: ‘Entry’, ‘UTC’: 1611678785.0, ‘UserID’: ‘’}, ‘Index’: 0, ‘deviceType’: ‘VTO6221E’, ‘serialNumber’: ‘6C01F4CPAZ2D99D’}
2021-01-26 16:33:08,437 INFO main Publishing MQTT message DahuaVTO/BackLightOff/Event: {‘Action’: ‘Pulse’, ‘Code’: ‘BackLightOff’, ‘Data’: {‘LocaleTime’: ‘2021-01-26 16:33:08’, ‘UTC’: 1611678788.0}, ‘Index’: 0, ‘deviceType’: ‘VTO6221E’, ‘serialNumber’: ‘6C01F4CPAZ2D99D’}
2021-01-26 16:35:17,399 INFO main Publishing MQTT message DahuaVTO/SIPRegisterResult/Event: {‘Action’: ‘Pulse’, ‘Code’: ‘SIPRegisterResult’, ‘Data’: {‘LocaleTime’: ‘2021-01-26 16:35:17’, ‘Success’: True, ‘UTC’: 1611678917.0}, ‘Index’: 0, ‘deviceType’: ‘VTO6221E’, ‘serialNumber’: ‘6C01F4CPAZ2D99D’}
2021-01-26 16:35:18,430 INFO main Publishing MQTT message DahuaVTO/SIPRegisterResult/Event: {‘Action’: ‘Pulse’, ‘Code’: ‘SIPRegisterResult’, ‘Data’: {‘Date’: ‘26-01-2021 16:35:18’, ‘LocaleTime’: ‘2021-01-26 16:35:18’, ‘Success’: True, ‘UTC’: 1611678918.0}, ‘Index’: 0, ‘deviceType’: ‘VTO6221E’, ‘serialNumber’: ‘6C01F4CPAZ2D99D’}
2021-01-26 16:40:17,383 INFO main Publishing MQTT message DahuaVTO/SIPRegisterResult/Event: {‘Action’: ‘Pulse’, ‘Code’: ‘SIPRegisterResult’, ‘Data’: {‘LocaleTime’: ‘2021-01-26 16:40:17’, ‘Success’: True, ‘UTC’: 1611679217.0}, ‘Index’: 0, ‘deviceType’: ‘VTO6221E’, ‘serialNumber’: ‘6C01F4CPAZ2D99D’}
2021-01-26 16:40:18,433 INFO main Publishing MQTT message DahuaVTO/SIPRegisterResult/Event: {‘Action’: ‘Pulse’, ‘Code’: ‘SIPRegisterResult’, ‘Data’: {‘Date’: ‘26-01-2021 16:40:18’, ‘LocaleTime’: ‘2021-01-26 16:40:18’, ‘Success’: True, ‘UTC’: 1611679218.0}, ‘Index’: 0, ‘deviceType’: ‘VTO6221E’, ‘serialNumber’: ‘6C01F4CPAZ2D99D’}
2021-01-26 16:45:17,397 INFO main Publishing MQTT message DahuaVTO/SIPRegisterResult/Event: {‘Action’: ‘Pulse’, ‘Code’: ‘SIPRegisterResult’, ‘Data’: {‘LocaleTime’: ‘2021-01-26 16:45:17’, ‘Success’: True, ‘UTC’: 1611679517.0}, ‘Index’: 0, ‘deviceType’: ‘VTO6221E’, ‘serialNumber’: ‘6C01F4CPAZ2D99D’}
2021-01-26 16:45:18,449 INFO main Publishing MQTT message DahuaVTO/SIPRegisterResult/Event: {‘Action’: ‘Pulse’, ‘Code’: ‘SIPRegisterResult’, ‘Data’: {‘Date’: ‘26-01-2021 16:45:18’, ‘LocaleTime’: ‘2021-01-26 16:45:18’, ‘Success’: True, ‘UTC’: 1611679518.0}, ‘Index’: 0, ‘deviceType’: ‘VTO6221E’, ‘serialNumber’: ‘6C01F4CPAZ2D99D’}
2021-01-26 16:50:17,382 INFO main Publishing MQTT message DahuaVTO/SIPRegisterResult/Event: {‘Action’: ‘Pulse’, ‘Code’: ‘SIPRegisterResult’, ‘Data’: {‘LocaleTime’: ‘2021-01-26 16:50:17’, ‘Success’: True, ‘UTC’: 1611679817.0}, ‘Index’: 0, ‘deviceType’: ‘VTO6221E’, ‘serialNumber’: ‘6C01F4CPAZ2D99D’}
2021-01-26 16:50:18,423 INFO main Publishing MQTT message DahuaVTO/SIPRegisterResult/Event: {‘Action’: ‘Pulse’, ‘Code’: ‘SIPRegisterResult’, ‘Data’: {‘Date’: ‘26-01-2021 16:50:18’, ‘LocaleTime’: ‘2021-01-26 16:50:18’, ‘Success’: True, ‘UTC’: 1611679818.0}, ‘Index’: 0, ‘deviceType’: ‘VTO6221E’, ‘serialNumber’: ‘6C01F4CPAZ2D99D’}
2021-01-26 16:50:25,174 INFO main Publishing MQTT message DahuaVTO/VideoMotion/Event: {‘Action’: ‘Start’, ‘Code’: ‘VideoMotion’, ‘Data’: {‘LocaleTime’: ‘2021-01-26 16:50:25’, ‘UTC’: 1611679825.0}, ‘Index’: 0, ‘deviceType’: ‘VTO6221E’, ‘serialNumber’: ‘6C01F4CPAZ2D99D’}
2021-01-26 16:50:33,577 INFO main Publishing MQTT message DahuaVTO/VideoMotion/Event: {‘Action’: ‘Stop’, ‘Code’: ‘VideoMotion’, ‘Data’: {‘LocaleTime’: ‘2021-01-26 16:50:33’, ‘UTC’: 1611679833.0}, ‘Index’: 0, ‘deviceType’: ‘VTO6221E’, ‘serialNumber’: ‘6C01F4CPAZ2D99D’}
2021-01-26 16:53:15,834 INFO main Publishing MQTT message DahuaVTO/BackKeyLight/Event: {‘Action’: ‘Pulse’, ‘Code’: ‘BackKeyLight’, ‘Data’: {‘LocaleTime’: ‘2021-01-26 16:53:15’, ‘State’: 8, ‘UTC’: 1611679995.0}, ‘Index’: -1, ‘deviceType’: ‘VTO6221E’, ‘serialNumber’: ‘6C01F4CPAZ2D99D’}
2021-01-26 16:53:15,982 INFO main Publishing MQTT message DahuaVTO/BackLightOn/Event: {‘Action’: ‘Pulse’, ‘Code’: ‘BackLightOn’, ‘Data’: {‘LocaleTime’: ‘2021-01-26 16:53:16’, ‘UTC’: 1611679996.0}, ‘Index’: 0, ‘deviceType’: ‘VTO6221E’, ‘serialNumber’: ‘6C01F4CPAZ2D99D’}
2021-01-26 16:53:16,022 INFO main Publishing MQTT message DahuaVTO/AccessControl/Event: {‘Action’: ‘Pulse’, ‘Code’: ‘AccessControl’, ‘Data’: {‘CardNo’: ‘’, ‘CardType’: None, ‘LocaleTime’: ‘2021-01-26 16:53:16’, ‘Method’: 4, ‘Name’: ‘OpenDoor’, ‘Password’: ‘’, ‘ReaderID’: ‘1’, ‘RecNo’: 490, ‘SnapURL’: ‘’, ‘Status’: 1, ‘Type’: ‘Entry’, ‘UTC’: 1611679996.0, ‘UserID’: ‘’}, ‘Index’: 0, ‘deviceType’: ‘VTO6221E’, ‘serialNumber’: ‘6C01F4CPAZ2D99D’}
2021-01-26 16:53:19,126 INFO main Publishing MQTT message DahuaVTO/BackLightOff/Event: {‘Action’: ‘Pulse’, ‘Code’: ‘BackLightOff’, ‘Data’: {‘LocaleTime’: ‘2021-01-26 16:53:19’, ‘UTC’: 1611679999.0}, ‘Index’: 0, ‘deviceType’: ‘VTO6221E’, ‘serialNumber’: ‘6C01F4CPAZ2D99D’}
2021-01-26 16:53:30,334 INFO main Publishing MQTT message DahuaVTO/VideoMotion/Event: {‘Action’: ‘Start’, ‘Code’: ‘VideoMotion’, ‘Data’: {‘LocaleTime’: ‘2021-01-26 16:53:30’, ‘UTC’: 1611680010.0}, ‘Index’: 0, ‘deviceType’: ‘VTO6221E’, ‘serialNumber’: ‘6C01F4CPAZ2D99D’}
2021-01-26 16:53:52,570 INFO main Publishing MQTT message DahuaVTO/VideoMotion/Event: {‘Action’: ‘Stop’, ‘Code’: ‘VideoMotion’, ‘Data’: {‘LocaleTime’: ‘2021-01-26 16:53:52’, ‘UTC’: 1611680032.0}, ‘Index’: 0, ‘deviceType’: ‘VTO6221E’, ‘serialNumber’: ‘6C01F4CPAZ2D99D’}
2021-01-26 16:55:17,358 INFO main Publishing MQTT message DahuaVTO/SIPRegisterResult/Event: {‘Action’: ‘Pulse’, ‘Code’: ‘SIPRegisterResult’, ‘Data’: {‘LocaleTime’: ‘2021-01-26 16:55:17’, ‘Success’: True, ‘UTC’: 1611680117.0}, ‘Index’: 0, ‘deviceType’: ‘VTO6221E’, ‘serialNumber’: ‘6C01F4CPAZ2D99D’}
2021-01-26 16:55:18,421 INFO main Publishing MQTT message DahuaVTO/SIPRegisterResult/Event: {‘Action’: ‘Pulse’, ‘Code’: ‘SIPRegisterResult’, ‘Data’: {‘Date’: ‘26-01-2021 16:55:18’, ‘LocaleTime’: ‘2021-01-26 16:55:18’, ‘Success’: True, ‘UTC’: 1611680118.0}, ‘Index’: 0, ‘deviceType’: ‘VTO6221E’, ‘serialNumber’: ‘6C01F4CPAZ2D99D’}
2021-01-26 16:59:05,246 INFO main Publishing MQTT message DahuaVTO/VideoMotion/Event: {‘Action’: ‘Start’, ‘Code’: ‘VideoMotion’, ‘Data’: {‘LocaleTime’: ‘2021-01-26 16:59:05’, ‘UTC’: 1611680345.0}, ‘Index’: 0, ‘deviceType’: ‘VTO6221E’, ‘serialNumber’: ‘6C01F4CPAZ2D99D’}
2021-01-26 16:59:15,568 INFO main Publishing MQTT message DahuaVTO/VideoMotion/Event: {‘Action’: ‘Stop’, ‘Code’: ‘VideoMotion’, ‘Data’: {‘LocaleTime’: ‘2021-01-26 16:59:15’, ‘UTC’: 1611680355.0}, ‘Index’: 0, ‘deviceType’: ‘VTO6221E’, ‘serialNumber’: ‘6C01F4CPAZ2D99D’}
2021-01-26 16:59:25,554 INFO main Publishing MQTT message DahuaVTO/VideoMotion/Event: {‘Action’: ‘Start’, ‘Code’: ‘VideoMotion’, ‘Data’: {‘LocaleTime’: ‘2021-01-26 16:59:25’, ‘UTC’: 1611680365.0}, ‘Index’: 0, ‘deviceType’: ‘VTO6221E’, ‘serialNumber’: ‘6C01F4CPAZ2D99D’}
2021-01-26 16:59:36,556 INFO main Publishing MQTT message DahuaVTO/VideoMotion/Event: {‘Action’: ‘Stop’, ‘Code’: ‘VideoMotion’, ‘Data’: {‘LocaleTime’: ‘2021-01-26 16:59:36’, ‘UTC’: 1611680376.0}, ‘Index’: 0, ‘deviceType’: ‘VTO6221E’, ‘serialNumber’: ‘6C01F4CPAZ2D99D’}
2021-01-26 17:00:17,385 INFO main Publishing MQTT message DahuaVTO/SIPRegisterResult/Event: {‘Action’: ‘Pulse’, ‘Code’: ‘SIPRegisterResult’, ‘Data’: {‘LocaleTime’: ‘2021-01-26 17:00:17’, ‘Success’: True, ‘UTC’: 1611680417.0}, ‘Index’: 0, ‘deviceType’: ‘VTO6221E’, ‘serialNumber’: ‘6C01F4CPAZ2D99D’}
2021-01-26 17:00:18,416 INFO main Publishing MQTT message DahuaVTO/SIPRegisterResult/Event: {‘Action’: ‘Pulse’, ‘Code’: ‘SIPRegisterResult’, ‘Data’: {‘Date’: ‘26-01-2021 17:00:18’, ‘LocaleTime’: ‘2021-01-26 17:00:18’, ‘Success’: True, ‘UTC’: 1611680418.0}, ‘Index’: 0, ‘deviceType’: ‘VTO6221E’, ‘serialNumber’: ‘6C01F4CPAZ2D99D’}
2021-01-26 17:00:35,912 INFO main Publishing MQTT message DahuaVTO/VideoMotion/Event: {‘Action’: ‘Start’, ‘Code’: ‘VideoMotion’, ‘Data’: {‘LocaleTime’: ‘2021-01-26 17:00:35’, ‘UTC’: 1611680435.0}, ‘Index’: 0, ‘deviceType’: ‘VTO6221E’, ‘serialNumber’: ‘6C01F4CPAZ2D99D’}
2021-01-26 17:00:43,565 INFO main Publishing MQTT message DahuaVTO/VideoMotion/Event: {‘Action’: ‘Stop’, ‘Code’: ‘VideoMotion’, ‘Data’: {‘LocaleTime’: ‘2021-01-26 17:00:43’, ‘UTC’: 1611680443.0}, ‘Index’: 0, ‘deviceType’: ‘VTO6221E’, ‘serialNumber’: ‘6C01F4CPAZ2D99D’}
2021-01-26 17:05:17,380 INFO main Publishing MQTT message DahuaVTO/SIPRegisterResult/Event: {‘Action’: ‘Pulse’, ‘Code’: ‘SIPRegisterResult’, ‘Data’: {‘LocaleTime’: ‘2021-01-26 17:05:17’, ‘Success’: True, ‘UTC’: 1611680717.0}, ‘Index’: 0, ‘deviceType’: ‘VTO6221E’, ‘serialNumber’: ‘6C01F4CPAZ2D99D’}
2021-01-26 17:05:18,402 INFO main Publishing MQTT message DahuaVTO/SIPRegisterResult/Event: {‘Action’: ‘Pulse’, ‘Code’: ‘SIPRegisterResult’, ‘Data’: {‘Date’: ‘26-01-2021 17:05:18’, ‘LocaleTime’: ‘2021-01-26 17:05:18’, ‘Success’: True, ‘UTC’: 1611680718.0}, ‘Index’: 0, ‘deviceType’: ‘VTO6221E’, ‘serialNumber’: ‘6C01F4CPAZ2D99D’}
2021-01-26 17:10:17,364 INFO main Publishing MQTT message DahuaVTO/SIPRegisterResult/Event: {‘Action’: ‘Pulse’, ‘Code’: ‘SIPRegisterResult’, ‘Data’: {‘LocaleTime’: ‘2021-01-26 17:10:17’, ‘Success’: True, ‘UTC’: 1611681017.0}, ‘Index’: 0, ‘deviceType’: ‘VTO6221E’, ‘serialNumber’: ‘6C01F4CPAZ2D99D’}
2021-01-26 17:10:18,406 INFO main Publishing MQTT message DahuaVTO/SIPRegisterResult/Event: {‘Action’: ‘Pulse’, ‘Code’: ‘SIPRegisterResult’, ‘Data’: {‘Date’: ‘26-01-2021 17:10:18’, ‘LocaleTime’: ‘2021-01-26 17:10:18’, ‘Success’: True, ‘UTC’: 1611681018.0}, ‘Index’: 0, ‘deviceType’: ‘VTO6221E’, ‘serialNumber’: ‘6C01F4CPAZ2D99D’}
2021-01-26 17:15:17,350 INFO main Publishing MQTT message DahuaVTO/SIPRegisterResult/Event: {‘Action’: ‘Pulse’, ‘Code’: ‘SIPRegisterResult’, ‘Data’: {‘LocaleTime’: ‘2021-01-26 17:15:17’, ‘Success’: True, ‘UTC’: 1611681317.0}, ‘Index’: 0, ‘deviceType’: ‘VTO6221E’, ‘serialNumber’: ‘6C01F4CPAZ2D99D’}
2021-01-26 17:15:18,380 INFO main Publishing MQTT message DahuaVTO/SIPRegisterResult/Event: {‘Action’: ‘Pulse’, ‘Code’: ‘SIPRegisterResult’, ‘Data’: {‘Date’: ‘26-01-2021 17:15:18’, ‘LocaleTime’: ‘2021-01-26 17:15:18’, ‘Success’: True, ‘UTC’: 1611681318.0}, ‘Index’: 0, ‘deviceType’: ‘VTO6221E’, ‘serialNumber’: ‘6C01F4CPAZ2D99D’}
2021-01-26 17:20:17,346 INFO main Publishing MQTT message DahuaVTO/SIPRegisterResult/Event: {‘Action’: ‘Pulse’, ‘Code’: ‘SIPRegisterResult’, ‘Data’: {‘LocaleTime’: ‘2021-01-26 17:20:17’, ‘Success’: True, ‘UTC’: 1611681617.0}, ‘Index’: 0, ‘deviceType’: ‘VTO6221E’, ‘serialNumber’: ‘6C01F4CPAZ2D99D’}
2021-01-26 17:20:18,416 INFO main Publishing MQTT message DahuaVTO/SIPRegisterResult/Event: {‘Action’: ‘Pulse’, ‘Code’: ‘SIPRegisterResult’, ‘Data’: {‘Date’: ‘26-01-2021 17:20:18’, ‘LocaleTime’: ‘2021-01-26 17:20:18’, ‘Success’: True, ‘UTC’: 1611681618.0}, ‘Index’: 0, ‘deviceType’: ‘VTO6221E’, ‘serialNumber’: ‘6C01F4CPAZ2D99D’}
2021-01-26 17:25:17,362 INFO main Publishing MQTT message DahuaVTO/SIPRegisterResult/Event: {‘Action’: ‘Pulse’, ‘Code’: ‘SIPRegisterResult’, ‘Data’: {‘LocaleTime’: ‘2021-01-26 17:25:17’, ‘Success’: True, ‘UTC’: 1611681917.0}, ‘Index’: 0, ‘deviceType’: ‘VTO6221E’, ‘serialNumber’: ‘6C01F4CPAZ2D99D’}
2021-01-26 17:25:18,424 INFO main Publishing MQTT message DahuaVTO/SIPRegisterResult/Event: {‘Action’: ‘Pulse’, ‘Code’: ‘SIPRegisterResult’, ‘Data’: {‘Date’: ‘26-01-2021 17:25:18’, ‘LocaleTime’: ‘2021-01-26 17:25:18’, ‘Success’: True, ‘UTC’: 1611681918.0}, ‘Index’: 0, ‘deviceType’: ‘VTO6221E’, ‘serialNumber’: ‘6C01F4CPAZ2D99D’}
2021-01-26 17:29:23,989 ERROR main Failed to read data: b’ \x00\x00\x00DHIP\x90\xff\xff\x7f{\x00\x00\x00F\x00\x00\x00\x00\x00\x00\x00F\x00\x00\x00\x00\x00\x00\x00{“id”:123,“params”:{“timeout”:55},“result”:true,“session”:2147483536}\n’, error: Expecting property name enclosed in double quotes: line 1 column 2 (char 1), Line: 323
2021-01-26 17:29:23,990 ERROR main Failed to handle message, error: ‘NoneType’ object has no attribute ‘get’, Line: 170
2021-01-26 17:30:17,357 INFO main Publishing MQTT message DahuaVTO/SIPRegisterResult/Event: {‘Action’: ‘Pulse’, ‘Code’: ‘SIPRegisterResult’, ‘Data’: {‘LocaleTime’: ‘2021-01-26 17:30:17’, ‘Success’: True, ‘UTC’: 1611682217.0}, ‘Index’: 0, ‘deviceType’: ‘VTO6221E’, ‘serialNumber’: ‘6C01F4CPAZ2D99D’}
2021-01-26 17:30:18,426 INFO main Publishing MQTT message DahuaVTO/SIPRegisterResult/Event: {‘Action’: ‘Pulse’, ‘Code’: ‘SIPRegisterResult’, ‘Data’: {‘Date’: ‘26-01-2021 17:30:18’, ‘LocaleTime’: ‘2021-01-26 17:30:18’, ‘Success’: True, ‘UTC’: 1611682218.0}, ‘Index’: 0, ‘deviceType’: ‘VTO6221E’, ‘serialNumber’: ‘6C01F4CPAZ2D99D’}
2021-01-26 17:35:17,344 INFO main Publishing MQTT message DahuaVTO/SIPRegisterResult/Event: {‘Action’: ‘Pulse’, ‘Code’: ‘SIPRegisterResult’, ‘Data’: {‘LocaleTime’: ‘2021-01-26 17:35:17’, ‘Success’: True, ‘UTC’: 1611682517.0}, ‘Index’: 0, ‘deviceType’: ‘VTO6221E’, ‘serialNumber’: ‘6C01F4CPAZ2D99D’}
2021-01-26 17:35:18,418 INFO main Publishing MQTT message DahuaVTO/SIPRegisterResult/Event: {‘Action’: ‘Pulse’, ‘Code’: ‘SIPRegisterResult’, ‘Data’: {‘Date’: ‘26-01-2021 17:35:18’, ‘LocaleTime’: ‘2021-01-26 17:35:18’, ‘Success’: True, ‘UTC’: 1611682518.0}, ‘Index’: 0, ‘deviceType’: ‘VTO6221E’, ‘serialNumber’: ‘6C01F4CPAZ2D99D’}
2021-01-26 17:40:17,337 INFO main Publishing MQTT message DahuaVTO/SIPRegisterResult/Event: {‘Action’: ‘Pulse’, ‘Code’: ‘SIPRegisterResult’, ‘Data’: {‘LocaleTime’: ‘2021-01-26 17:40:17’, ‘Success’: True, ‘UTC’: 1611682817.0}, ‘Index’: 0, ‘deviceType’: ‘VTO6221E’, ‘serialNumber’: ‘6C01F4CPAZ2D99D’}
2021-01-26 17:40:18,389 INFO main Publishing MQTT message DahuaVTO/SIPRegisterResult/Event: {‘Action’: ‘Pulse’, ‘Code’: ‘SIPRegisterResult’, ‘Data’: {‘Date’: ‘26-01-2021 17:40:18’, ‘LocaleTime’: ‘2021-01-26 17:40:18’, ‘Success’: True, ‘UTC’: 1611682818.0}, ‘Index’: 0, ‘deviceType’: ‘VTO6221E’, ‘serialNumber’: ‘6C01F4CPAZ2D99D’}
You can replace the null with DahuaVTO and that should work
Hello, with the addon version, i can receive events about video doorbell button pressed, motion detection and a small video when motion detection its trigger?
Hello @bar,
I’m using DahuaVTO2MQTT Addon and I still have this error after a while.
Should I stop working this addon and get me docker version ?
