ok, i just re installed it and will see how it goes
hy Bar,
thanks for the work and great integration. I use it for my Dahua Cam and would like to use the IVS-rules as sensor in HA. would you happen to know how i can use it as sensor? (command-line for binary sensor?)
the second sensor getâs the stop command but not the start command.
thanks
Hi guys, Iâm attempting to setup the dahuavto2mqtt service with mosquitto and home assistant using docker-compse on a ubuntu machine. Iâve already got various shelly devices connected to the mosquitto MQTT broker and home-assistant and I can pub and sub to mosquitto with the following from my windows machine succesfully:
sub: mosquitto_sub.exe -h <mosquitto-ip> -u <myusername> -P <mypassword> -t DahuaVTO/# -F %j
pub mosquitto_pub.exe -h <mosquitto-ip> -u <myusername> -P <mypassword> -t DahuaVTO/test -m "{'message': 'test1'}"
When attaching to the running dahuavto2mqtt container I can see the following debug output repeating:
2022-05-30 18:19:22,502 INFO __main__ Connecting
2022-05-30 18:19:22,502 DEBUG asyncio Using selector: EpollSelector
2022-05-30 18:19:22,504 DEBUG __main__ Connection established
2022-05-30 18:19:22,504 INFO __main__ Initializing MQTT Broker
2022-05-30 18:19:22,505 INFO __main__ MQTT Broker is trying to connect...
2022-05-30 18:19:22,506 DEBUG __main__ Prepare pre-login message
2022-05-30 18:19:22,506 INFO __main__ MQTT Broker connected with result code 0
2022-05-30 18:19:22,519 DEBUG __main__ Data received: {'error': {'code': 268632079, 'message': 'Component error: login challenge!'}, 'id': 2, 'params': {'authorization': '36f94ca7<..etc..>f56f8d49f', 'encryption': 'Default', 'mac': '<mac address>', 'random': '1853980012', 'realm': 'Login to f9b3bdac<..etc..>c6731dec049'}, 'result': False, 'session': 2147483588}
2022-05-30 18:19:22,519 DEBUG __main__ Prepare login message
2022-05-30 18:19:22,538 DEBUG __main__ Data received: {'error': {'code': 268632085, 'message': 'Component error: User or password not valid!'}, 'id': 3, 'params': {'remainLockSecond': 0, 'remainLoginTimes': 0}, 'result': False, 'session': 2147483588}
2022-05-30 18:19:22,748 INFO __main__ Server sent EOF message
2022-05-30 18:19:22,748 WARNING __main__ Disconnected, will try to connect in 5 seconds
The relevant parts from docker-compose.yml:
version: '3.7'
services:
homeassistant:
container_name: homeassistant
image: homeassistant/home-assistant:stable
volumes:
- /home/myusername/HA/config:/config
- /etc/localtime:/etc/localtime:ro
restart: unless-stopped
network_mode: host
mosquitto:
image: eclipse-mosquitto:latest
depends_on:
- homeassistant
ports:
- 1883:1883
- 9001:9001
volumes:
- /home/myusername/HA/mosquitto/config:/mosquitto/config
- mosquitto_data:/mosquitto/data
- mosquitto_logs:/mosquitto/logs
network_mode: host
dahuavto2mqtt:
image: "eladbar/dahuavto2mqtt:latest"
container_name: "dahuavto2mqtt"
network_mode: host
depends_on:
- mosquitto
# relies on .env file
environment:
- DAHUA_VTO_HOST=${DAHUA_VTO_HOST}
- DAHUA_VTO_USERNAME=${DAHUA_VTO_USERNAME}
- DAHUA_VTO_PASSWORD=${DAHUA_VTO_PASSWORD}
- MQTT_BROKER_HOST=${MQTT_BROKER_HOST}
- MQTT_BROKER_PORT=${MQTT_BROKER_PORT}
- MQTT_BROKER_USERNAME=${MQTT_BROKER_USERNAME}
- MQTT_BROKER_PASSWORD=${MQTT_BROKER_PASSWORD}
- MQTT_BROKER_TOPIC_PREFIX=DahuaVTO
- MQTT_BROKER_CLIENT_ID=DahuaVTO2MQTT
- DEBUG=true
volumes:
mosquitto_data: {}
mosquitto_logs: {}
when I run docker-compose config
I can see that the env-vars from the .env
file are filled in succesfully. Any idea to what this could cause? I have the feeling Iâm missing something obvious here (besides that the broker somehow thinks the credentials are wrong)
hi, I moved the repo to GitLab and forgot to update the original post, now itâs updated.
Image is available at:
registry.gitlab.com/elad.bar/dahuavto2mqtt:latest
ever since I moved it to GitLab I applied several additional fixes, pls check with the up to date image if the problem is gone, if not, pls let me know.
thanks
Hi Bar, thanks for your swift response, Iâll check it as soon as I get home this evening!
update: @bar thank you very much, that fixed it for me! now I can start the automation fun
switch:
- platform: command_line
switches:
dahua_gate_open:
command_on: "/usr/bin/curl -s --globoff --digest --user YOUR_WEB_ADMIN_USERNAME:YOURPASSWORD 'http://XXX.XXX.X.XXX/cgi-bin/accessControl.cgi?action=openDoor&channel=1&UserID=101&Type=Remote'"
friendly_name: 'Open yard door'
@Guesswho620 - Thanks - tonight was one of those great times where you google for the easiest method to trigger something, the first link sends me to the right place (your post). Much appreciated, worked first pop
Thanks for the kind words, after so many similar events happened to me, itâs fantastic that I could make the same happen to someone
I love this place
Hi guys. Iâm approaching to buy vto3211 4btn and integrate it in HA.
But itâs not clear to me if I can obtain whatâs the button pressed by the user.
Some posts above I read something about that, but not a replyâŚ
Is that possible?
Hey, I listen to the doorbell using the broker from this topic and the following binary sensor:
- name: "Doorbell Button State"
unique_id: "Doorbell_Button_State"
payload_off: "0"
payload_on: "1"
state_topic: "DahuaVTO/BackKeyLight/Event"
value_template: '{{ value_json.Data.State }}'
and use it in my automation as a trigger like:
- platform: state
entity_id: binary_sensor.doorbell_button_state
to: 'on'
Guys, whatâs the situation with this project because Iâm a little bit lost and it doesnât work anymore.
The events are still being published, I have a reference for a binary sensor but that sensor is not existing anymore and I cannot find/remember how it was created before.
I have installed v1.0.2 (DahuaVTO2MQTT from Troy Kellyâs Add Ons), âSupportâ refers to a GH page that doesnât exist anymore.
From the âAboutâ section:
Using elad-barâs PHP code this addon simply connects to your intercom and relays events via your MQTT gateway.
Thanks for any help!
In OP you have link to docker image as standalone container (not HA Addon) that is up to date and working,
Addon is not maintained
Trying to install DahuaVTO2MQTT addon but receive an error message
The command â/bin/ash -o pipefail -c apk update && apk upgrade && apk add --no-cache python3 py3-pip py3-setuptools git && pip3 install --upgrade pip --no-cache-dir paho-mqtt requestsâ returned a non-zero code: 3
anyone able to decrypt and helpâŚthanks!
Are you running it on raspberry pi?
I am BarâŚthanks for your reply
Currently it is not supported, will try to get to it next weekend and add support for raspberry pi
Thanks!! I need you jelp too
Iâve been out and replaced my Raspberry Pi with an NUC, installed evereything from the back up I created off the Pi, tried to install VTO to MQTT Broker only to receive the error message;
Is there something nasty left over from Raspberry Pi install that is stopping the install or is the Dahua VTO add on not liking my NUC??
Many thanksâŚ!
I will check it, just to make sure, source of the docker is gitlab registry, right?
Yes Bar, trying to install from the HACS Addon Store
Can you pls share the link?
Iâm not supporting any HACS integration nor addon,
Just plain docker image that you can run on non raspberry pi devices
