hello, i have daikin wifi air conditioners, i have the devices inside homeassistence via daikin extension i entered the device via ip and they have been correctly entered in the platform, but i can’t control it, i can’t access it, it has change the temperature. I don’t understand the problem. I hope someone can help me Thanks
Add a climate card to your Lovelace dashboard.
I try to add , but, the sensors don’t work, on and off no work, did I forget something?
Some error like this
climate/set_hvac_mode . 'stemp'
Use the climate device created by the integration, not the sensors. e.g.
type: thermostat
entity: climate.upstairs
And apologies, it is called a thermostat card, not a climate card.
Actually I just translated the text in your first image. It does not look like you have correctly added the Daikin climate devices.
What do you see when you go to the page Configuration / Integrations / Daikin ?
I add Daikin from IP’s but I can’t see
You are going to have to be more descriptive that that.
What model air-conditioners and wifi adapters do you have?
It does not look like they are correctly added, or they may be a model that is not supported.
The supported models are listed here:
I think daikin perfera, but working with Daikin app
how should they be entered correctly?
This app (or its iOS equivalent)?
The only European models supported are:
Do you have one of those wifi controller units?
Yes I have iOS device and my Wi-Fi card is inside the devices
The adapter type may be listed on your invoice if you still have it.
Without this information it is not possible to say if your device is supported or not.
Searching online it seems it may be the BRP069B41 ( Wifi card Daikin online controller for air-conditioners Series Perfera ) which is supported.
If it is the 69C4x version you are out of luck:
This is my
Daikin Condizionatore 2 x FTXM25R 2MXM40N Dual Split Perfera Gas R-32 Bluevolution 9+9 WiFi
FTXM42R+RXM42R
Daikin Condizionatore FTXM42R RXM42R Mono Split Perfera Gas R-32 Bluevolution 15000 Btu
Unfortunately none of that information is useful.
