Daikin AC Integration BRP069C4x
Responding not because I can testify to how the integration works, but because I’m in the same boat as you. I’ve received a quote for the Perfera line and am trying to decide whether to buy it or turn towards an installer that offers a different brand.
As things stand, the installer has heard my concerns about no local API and says he thinks there is a wired solution that will work locally with HA. More news from him tomorrow on that.
Right now though, I’m leaning towards giving Daikin a miss. The integration sounds like it is a great hack and has been working well for the people I’ve read from in this thread, so kudos to @rospogrigio.
But it is still the cloud, and given that I have not committed to this split system yet, I feel like I’d be a bit of a fool to do so. I think the integration is a great way to make the purchase work for those who bought first, and realised AFTER that the local API no longer worked. But the cloud remains the cloud, and it seems ludicrous that either an outage from Daikin, or my own internet service going down, could result in losing control over the system. Then there’s the possibility Daikin might make changes to their cloud that put the integration offline for an indeterminate period of time.
Call me vindictive, but I also feel funny giving my money to a company that made the decision to go all cloud in the first place. I don’t want to ever become numb to the absurdity that the commands I give to equipment I have purchased and installed in my home, need to go through remote servers for the unit to respond.
It sounds like Daikin have been very dismissive of the concerns from the smart home community during this whole process. I think another company that has not made the same philosophical choices as Daikin, might be a better fit for me.
I see your point and understand it. You can still purchase the old adapter separately (I believe it’s something like 50 euros) and install it on the newest devices so you can use the old local APIs, some people did so because they wanted to use the device locally, you can easily find the thread I think
Just to say. Bye!
Thanks @rospogrigio - yes, this is an option.
The installer got back to me today and said Daikin has approved for them to swap out the internal wifi module for a wired KNX module. Unfortunately I don’t know enough about the KNX implementation to understand whether this would be a disadvantage over simply getting a Mitsubishi system with wifi that allows local control.
I don’t really care about using an app on my phone and am happy for everything to happen through the remote, and HA… so maybe this is a good solution for me?
I was blissfully unaware of Daikin turning to the dark side with the changes made to the api until my wifi had some issues and connectivity was down for a few hours. After fixing the wifi issues, I noticed that my HA integration with my Daikin AC was no longer working. The Daikin kept showing up as unavailable. (I have no clue why this only happened now)
Tried the following:
Rebooting HA
Removing the Daikin integration and re-adding it by just supplying the ip address which ends up in a “Failed to connect” error.
2022-09-07 16_22_54-Settings – Home Assistant
Googling brought me to this long thread
My setup:
Daikin AC FTX25K2V1B from 2016
BRP069A41 wifi module fw: 3.3.9 (the one that according to link should be working?)
Home Assistant 2022.8.7
Supervisor 2022.08.5
Operating System 8.5
The OVA running as a VM in VMWare ESXi
Observations:
The Daikin Controller iPhone app cannot find the Daikin AC on my local network even though my AC, iPhone and HAOS are all on the same subnet. (so the mentioned UDP port, UDP:30000=>30050 also seems to be a thing of the past because local discovery was broken?)
Only way that does work is using the Daikin Controller App to login using “out of home” in which case the AC shows up immediately and can be managed through slow hit & miss clicks in the App.(more often than not I have to switch to my 4g for the App to respond to the commands of turning the AC on/off).
I can’t believe Daikin crippled the functionality, certainly can understand if they want the user data but for Pete’s sake at least take care of your customers by not crippling the way the app and HA integration works. One would think that providing functionality like this, would help sell more Daikin equipment. (I certainly will not be buying any more if they don’t change their stance)
Questions:
  1. Am I correct in assuming that the current Daikin integration is no longer working for the BRP069A41 and perhaps other older wifi modules?
  2. I read about this wonderful project GitHub - rospogrigio/daikin_residential: Cloud control of Daikin devices that are supported by Daikin Residential Controller app.
    by @rospogrigio, does this also support older wifi modules?
  3. Can this addon be directly installed in the Home Assistant Operating System or do I need to wait for it to be added to the “official” integrations @fredrike @rospogrigio ?
Any help or suggestions please share.
That should actually all still work. I even upgraded my BRP069A41 to firmware 4.0.3 using the new ONECTA app and controlling my airco locally at this moment.
Seems like your issue is just on your local network. Try rebooting your router, power cycle your Daikin (circuit breaker) and give your units a fixed IP (fixed DHCP assignment via your router) for simplicity.
@whitedogbe Thanks for the quick reply!
I’m using pfsense to give out fixed dhcp addresses in my network including the wifi adapter of the Daikin so that should not be an issue.
Even tried resetting the daikin wifi module and re-ran the wifi setup where you first connect to the AP of the wifi module and then connect it to the target wifi network. the wifi module connects to my wifi without an issue ( because I can see it has connected to my wifi and it’s pingable) but I can’t seem to connect to it using the Daikin Control App or HA. (port 80 shows: ret=PARAM NG,msg=404 Not Found )
I could try using the circuit breaker to power off/on my AC, I will do this with proper daylight :slight_smile: (although holding the mode button also resets the wifi module which should be enough?).
If that doesn’t work, do you suggest using the ONECTA app and upgrading the firmware to 4.0.3 to see if that resolves anything?
Any other way I can check if local connectivity is still active?
So I turned off the circuit breaker to turn the power off to the wifi module:
HA integration still gives the same error as described above after inputting the IP.
After it came back up, rebooted my iPhone just to be sure and then I opened the Daikin App but still no local AC visible (AC pops up after logging into “Out-of-Home” this is driving me nuts :frowning:
Anything else besides the the App I can check to see if local connectivity is still working? (sniffing traffic?)
I had a Daikin Caldo 40 installed yesterday, it came with the BRP069C4X controller and I got this up and running almost without any issues :slight_smile:
Hello PaulSinnema,
just curious if you managed to get your Daikin Airco’s working with Loxone.
I am looking for some integration in Loxone app as well for my Daikin equipment without the need to open other apps. ( 4MXM80N9
FDXM25F9, FTXP20M9, FTXP50M, BRC1H52W )
Thank you for your reply.
Yes, it took some design en programming skills to get it working, but it’s working as expected right now. I was a bit worried about the change from the hot to the cold period but I thought it out just correct. Now the Daikins are heating the home instead of cooling. Very nice. If you want I can send you my configuration to implement yours.
Ah, you have the newer versions of the indoor units. This will still work if you replace the Wifi modules with older ones. The installer did that for me here. The new Wifi modules only work with cloud. The older ones work on your local network.
I’ve looked up which Wifi modules I use. There are still more types available but what I have is BRP069B45.
hi Paul,
thx for your reply. Your config in Loxone would be nice to have an example how to do it.
So you didn’t use the Intesis AC wifi controllers?
attachment of lox file to [email protected] .
thank you!
There are no wifi modules for now in my AC’s, so I will check availability and conformity of the BRP069B45 for my units. Still interested in your loxone setup. Thx
You can find some unofficial information on GitHub here: GitHub - ael-code/daikin-control: Unofficial api documentation and web interface to control "Daikin Emura" air conditioner
I had bought an Intesis AC Wifi controller, very expensive but couldn’t get it to work. I don’t use Home Assistant in my setup. My setup only requires the Loxone Miniserver, some PicoC programming and several virtual outputs using HTTP and virtual inputs to steer it all. The Daikin (older) Wifi modules have a REST API that you can call via your LAN. I use that from PicoC to send and receive information to/from the Diakin indoor units. It works perfectly. The solution is complex with lot’s of constants and variabels in virtual inputs. Here’s a description on LoxForum (German): HowTo: Integration of Daikin Air Conditioning over Wifi - loxforum.com
Alright guys, we recently bought Daikin AC’s(3x Perfera FTXM-R, 1x Stylish FTXA).
After reading about the removal of the local api I already expected the new controllers. Now the ‘Perfera’ units do have the ‘C’ controllers,
the ‘Stylish’ unit actually still has a ‘B’ controller.
Now I’d like to add the old controller to the Perfera indoor units, as far as I understand, I’d need the ‘B’ controller and the adapter cable(EKRS21).
Do I need a specific controller for my units, as far as I can tell there are different cables included in the different versions(41,42,43,44,45) and
prices can vary quite a bit between said versions.
Any help would be appreciated.
How? Thought the BRP069C4X is not supported?
I have 3 Perfera’s with BRP069C4x and though local doesn’t work, using the HACS addon and the Daikin cloud I can control them perfectly.
Yeah it works great. I’m using the HACS add-on which you can read more about here.
