Hi All,
Just having some issues with my new Daikin HVAC Unit. I have the Airbase adapter (BRP15B61) and when discovering it shows as NOTSUPPORT and is missing the climate controls. However the Zone control and indoor temp are showing up.
I am unsure how to manually configure a climate in yaml in the newer versions of homeassistant so if that is a troubleshooting step I would appreciate some guidance on that.
I have reloaded the integration with no luck and rebooted HA.
I could not find any errors similar to showing as NOTSUPPORT under device info, it should be supported according to the documentation for the integration.
Any advice?
