First post so please forgive me if I failed at some formatting protocol. I am trying to create an automation to turn on the Daikin airconditioner at 6:45am, set the temp to 20, set the mode to heat and the fan to Mid. Any of the functions will turn it on if off.
When the below automation runs, only the first action happens. If I make 3 automations, 1 for each action, they all work fine. Can someone help me please. The below was writen using the Automation Editor.
# Turn on and set Aircon
- alias: ' Aircon on at 6:45am. Set to 20c.'
- at: 06:45
platform: time
condition:
- condition: state
entity_id: binary_sensor.workday_sensor
state: 'on'action:
- data:
entity_id: climate.daikinap33707
temperature: 20
service: climate.set_temperature
- data:
operation_mode: heat
service: climate.set_operation_mode
- data:
fan_mode: Mid
service: climate.set_fan_mode
Also the alias: line has one too many spaces after the -.
Writing your automation in human readable format (rather than automation editor mangled format) it would look like this:
- platform: time
at: '06:45:00'
condition:
- condition: state
state: 'on'
- service: climate.set_temperature
temperature: 20
- service: climate.set_fan_mode
fan_mode: 'Mid'
You can set the operation mode when setting the temperature. No need for an extra service call. This was all taken from the examples here:
The example for setting the operation_mode lists Heat with a capital H but you say it is working when used in a standalone automation so this is probably not an issue.
Run the automation and if it does not work as expected check the log for errors.
