Daikin BRP069C4x wifi adapter and local api
Is the BRP069C4x supported or not with Daikin integration (local api) ?
Official documentation tells yes with a firmware 2.8.0 but many says this can be used only with the onecta daikin integration (cloud API).
Is someone able to use it locally ?
I’ve been looking for the same information. The Daikin integration page says that BRP069C4x is supported from HA release 2025.9 if the adapter has firmware 2.8.0. Mine seems to have 2.0.0 and I can’t find a way to update it. My unit is a Perfera A (FTXM-A).
My also is a daikin perfera, with BRP069C4x fw 2.0.0
@fredrike is the maintainer of the integration, may be he can tell us something more ?
Some news? I have brp069c4x and 3 Daikin Styilish with fw 2_0_0 any chance to work directly on lan and not with the cloud integration?
Seems this is a typo in the description of the integration. Looking at the source code of pyDaikin, used by the integration, I saw “Daikin class for BRP069[A-B]xx units.” which would exclude BRP069Cxx. Checking because I 've the same stupid BRP069Cxx in my indoor units :frowning:
I was also trying to update my Comfora firmware after reading this but seems not needed then?
I have the same Daikin BRP069C4x WIFI adapter and also stuck on firmware v2.0.0.
I’d also like to connect it to Home Assistant.
I created my account on EU servers, selecting South Africa as country. Not sure if it perhaps limits firmware version based on country. It did update mine from a 1.X version to 2.0.0.
This is not possible with the Daikin Integration, it should be with the HACS integration daikin_onecta (using the cloud API, not local)
See here: BRP069C4x firmware version 2_0_0 supported? · Issue #83 · fredrike/pydaikin · GitHub
Has anybody that was on 2.0.0 been updated to 2.8.0?
I have a BRP069C4x running 2_0_0 and it doesn’t offer any updates…
It says that the region is EU, maybe that’s relevant?
Is there maybe a way to force the update?
Just this morning I've got an update to update on my BRP069C4x from 2_0_0 to 2_3_0. Sadly still not working with HA locally.
I have 3x BRP069C4x indoor units. I/m not sure why these wifi adapters are so bad.
ping times are through the roof. like 100ms on average to 1s sometimes. the units are quite close to my AP.
I have already tried everything to improve this. separate 2.4Ghz network. no band steering, keeping things as simple as possible.
I got the 2_3_0 firmware upgrade on those (from 2_0_0) and it's unable to upgrade.
Somehow I bricked one unit already. Unit still works but I'm unable to add it back into Onecta.
Anyone successfully upgraded the units to 2.3.0?
I's really like to add them directly into HA. but seems impossible.
the number of TX retries is crazy. this is the same on all 3 units
I just firmware upgraded another unit to 2_3_0 and same thing happened.
it's wifi unit is bricked. the airco still works on the remote but ping times are >1s and making device network / wifi useless. the unit is offline in onecta and does sometimes reappear.
If anyone knows how to unbrick these, please let me know
Hi, I had comparable trouble with the same BRP069C4x adapters: I updated 2 of my 3 units, then ran into issues re-adding the devices to my Daikin account. I also run a UniFi network with U7 access points. Since I changed the DTIM interval from Auto to 3, the Daikin units are responding to ping again. It reduced the latency and TX retries noticeably for me. If you haven't tried DTIM yet, set it to 3 on your UniFi APs and test ping again.
I had similar trouble with the BRP069C4x adapters: I updated 2 of 3 units, then couldn't re-add them to my Daikin account. I also run UniFi with U7 APs. Since changing DTIM from Auto to 3, the Daikins reply to ping again. I later set DTIM to 10 and was able to add the devices back.
I had issues even before the firmware updates, and I thought the updates would fix things. There was also a Daikin app update last week and likely backend changes at Daikin, plus ongoing UniFi updates—I'm not sure what finally crashed everything.
Update from another BRP069C4x / Perfera owner (EU, FW 2.3.0)
I'm seeing the same pattern on a Daikin Perfera FTXM35R2V1B with built-in BRP069C4x (wlan-dx4, firmware 2_3_0, MAC 50:26:ef:b3:93:b6). The unit worked with Onecta for ~2 years, then became unreliable over several weeks.
Symptoms
  • Onecta app keeps auto-discovering the adapter (UDP) but setup never completes
  • Cloud step fails with REGISTERING_TO_CLOUD_FAILED, rsc:4000, or HTTP timeout on PUT /config/adapter/user_info (method: polling)
  • After reboot, rediscovery on the home network often takes 5–7 minutes
  • UniFi shows good RSSI (~−57 dBm) and sometimes “excellent” Wi‑Fi experience, but tx_bytes-r ≈ 0, high latency, HTTP to the module often times out
  • No local API on FW 2.x: /common/basic_info, /aircon/*404; only config endpoints respond intermittently
What we tested (without a lasting fix)
Area Tests
Network UniFi (UCG Ultra, U6 Pro, multiple APs): dedicated IoT SSID + xHome, both 2.4 GHz WPA2-PSK, PMF off, no WPA3, same LAN (no guest isolation)
Optimizations Fixed AP (U6 Pro), fixed IP (192.168.1.21), DTIM 3 on xHome (as suggested by @ChristianB78 — helped ping/retries somewhat, did not fix cloud registration), BSS transition off, 2.4 GHz channel plan, min data rate tweaks
Onecta Multiple commissioning runs, SP A (AP mode) / SP 3 (factory reset), account unlink/relink, mobile data disabled during setup, firmware 2.x / 2.3.0
Logs Several Commissioning Diagnostic exports — AP phase often OK, home-network find slow or fails first, cloud phase always fails
Not router-specific — Fritzbox users report the same
This does not look like a single-vendor Wi‑Fi misconfiguration. Similar Perfera + Onecta issues are reported on Fritzbox setups as well.
On the Akkudoktor forum (DE), stefanelo describes the same problem with a Perfera: Fritz!Repeater mesh did not help (tested 1750, 3000, 6000, 7490 mesh). Only moving the main Fritz!Box close enough to the indoor unit so the adapter could join Wi‑Fi during setup worked — repeaters failed in every case.
That aligns with our experience: UDP discovery works, but stable association + cloud registration is the hard part — and extra Wi‑Fi hops (repeaters/mesh) don't fix it.
Current understanding
  1. UDP discovery (why the app “finds” the unit) ≠ stable IP/cloud operation
  2. Murata module: asymmetric link (good RX, poor TX, high retries) + cloud polling failures
  3. FW 2.3.0 did not resolve it; C4x on this firmware still needs Onecta cloud (no reliable local API)
What helped marginally: DTIM 3, fixed AP, less 2.4 GHz congestion — not a complete fix.
What we're considering: Daikin support, external BRP069B42 on S21, or Faikin for local control (ordered today).
If anyone has completed Onecta setup successfully on C4x FW 2.3.0 (UniFi, Fritzbox, or other), please share AP/DTIM settings — it would help clarify whether any network tweak actually fixes cloud registration or if it's purely module/firmware-side.
Seems to be an open issue @daikin. Feedback i got through my open ticket: Techteam Daikin Belgium is working on Cloud connection fix for controller BRP069C4x with possible firmware fix roll-out on 13th June, second fix will be distributed end of June.
Let's hope if that fixes the controller issue! meanwhile I got Onecta Cloud connected via iPad (Wifi only) instead of iPhone App, but it's dropping connections every minute.
Firmware 2.5.0 just became available for the BRP069C4x at least. Can't find any changelogs for it and haven't had time to upgrade and test yet. Does anyone have feedback for this version?
Version 2.6.1 is apparently being rolled out via the TestFlight iOS app. They probably won’t win any awards for that module anymore, but TX retries are already looking significantly better again, and I’m not seeing any more dropouts in the ping.
Just updated my units to firmware 2.6.1 using the Daikin Onecta TestFlight iOS app, but I still can't connect them to the official Home Assistant integration.
I've tested both without an API key and with the password retrieved from the unit_ap endpoint, with the same result in both cases.
Has anyone with a BRP069C4x running firmware 2.6.1 successfully connected to the official integration?
