Daikin component - adapter not recognized
I have a Daikin AC with an adapter BRP069A42 that used to work (with 0.74.2?).
Suddenly the device is not recognized any more and throws exception:
2018-09-04 10:00:43 ERROR (MainThread) [homeassistant.components.climate] Error while setting up platform daikin
File "/home/pi/ha_venv/lib/python3.5/site-packages/homeassistant/helpers/entity_platform.py", line 129, in _async_setup_platform
SLOW_SETUP_MAX_WAIT, loop=hass.loop)
File "/usr/lib/python3.5/asyncio/tasks.py", line 400, in wait_for
return fut.result()
File "/usr/lib/python3.5/asyncio/futures.py", line 293, in result
raise self._exception
File "/usr/lib/python3.5/concurrent/futures/thread.py", line 55, in run
File "/home/pi/ha_venv/lib/python3.5/site-packages/homeassistant/components/climate/daikin.py", line 64, in setup_platform
api = daikin_api_setup(hass, host, name)
File "/home/pi/ha_venv/lib/python3.5/site-packages/homeassistant/components/daikin.py", line 105, in daikin_api_setup
device = appliance.Appliance(host)
File "/home/pi/ha_venv/lib/python3.5/site-packages/pydaikin/appliance.py", line 100, in __init__
raise ValueError("no device found for %s" % id)
ValueError: no device found for ['192.168.1.119']
The IP address appeared only after removing those few endpoints from appliance.py that were not returning OK; before that the stack trace was similar except the IP address was not recognized.
I’m using the latest version of pydaikin module for python 3.5.3.
Any hint how to fix this?
Thanks.
