I’m trying to integrate Daikin FWT05GT (FWT-GT | Daikin) fan coil unit (with APGS02 remote) with HA. I wanted to use IR for that purpose - I have a working IR transmitter/receiver - Blitzwolf BW-RC1 flashed with ESPHome. Using IR Remote Climate — ESPHome I’ve tried every possible communication related to Daikin:
ir_receiver_pin: GPIO05 # IR Receiver
ir_transmitter_pin: GPIO14 # IR Transmitter
remote_receiver:
- id: ir_receiver
pin:
number: ${ir_receiver_pin}
inverted: True
# dump: all
remote_transmitter:
- id: ir_transmitter
pin: ${ir_transmitter_pin}
carrier_duty_percent: 50%
climate:
- platform: daikin
receiver_id: ir_receiver
transmitter_id: ir_transmitter
supports_heat: false
visual:
min_temperature: 16
max_temperature: 30
sensor: gabinet_temperature
- platform: daikin_brc
visual:
min_temperature: 16
max_temperature: 30
use_fahrenheit: false # for daikin_brc
- platform: heatpumpir
name: "HP IR daikin"
protocol: daikin
vertical_default: up
horizontal_default: middle
min_temperature: 16
max_temperature: 30
name: "HP IR daikin_arc417"
protocol: daikin_arc417
min_temperature: 16
max_temperature: 30
name: "HP IR daikin_arc480"
protocol: daikin_arc480
min_temperature: 16
max_temperature: 30
But it doesn’t respond to any commands sent by bw-rc1, meanwhile the supplied remote is working (and bw-rc1 can see commands being send by it). Any ideas?
