I am working on exactly the same setup. My Daikin was set to leaving water temperature as I had no room thermostats either. A lot of messing with this and I have “almost” cracked it.
Daikin related Installer setting required:
- [C-07] needs to be 1*
- [4-08] = 1
- [4-09] = 1
- You need a switch wired to X2m 30 & 35. I have wiring off my circuit values (which are contolled by basic thermostats) which will open and close this circuit. Solar heating will flat out not work if C07 is set to 0.
Lan Adapter (with Solar)
X1A connections:
SG0 = live voltage
N - neutral
- For me smartgrid triggered when this is powered (using controllable plug/socket to trigger with Solar PV generation rises above 400w)
So basically everything is working for me… except that the energy meter (also ABB) is not working. I’ve no idea how to test the pulse but I’m get 4.8v on the end of the wire so I’m assuming I’m good from that perspective.
With the above set, the smartgrid works when the thermostat is NOT calling for heat (30&35 above). When the thermostat calls for heat smartgrid is disabled for the duration.
