I have been using the Daikin airconditioner integration in H/A but with latest version upgrade the integration is not available with logs stating that it has been deprecated. Is there a way of continuing to use this Daikin integration in subsequent H/A versions and if so how?
I don’t see any mention of Daikin being deprecated,the only thing that has been deprrcatef is configuration through YAML and this was in version 0.111.0, so a long time ago already, not ib the latest release. You need to remove the config from YAML and configure it again through the UI.
